TR6 Transmission front seal replacement question
nichola
Bronze
I have replaced leaking seals at the front of the differential and and the rear of the transmission (4 speed no overdrive). This transmission has spent 10 months on its nose (bell housing) with gear oil inside and hasn't left a single drop. I'm leaning towards not touching that seal since it hasn't leaked. Sound okay?
Regarding the clutch release shaft - what a pain in the rear that was. The pin locking the fork to the shaft broke at the end and I could not extract the bit that was left inside. Eventually I gave up and cut the shaft and removed it. Still could not get that little bit of the pin out, so I added a new fork to the order.
ps, I made a real simple tool that I used to remove the other seals - see photos. It is 1" by 1/8" flat bar bent over and trimmed so it hooks the inner side of the seal. The other end is also bent 90 degrees but long enough to strike with a hammer. Overall length is 18" approximately. Just a few taps as I moved it around the circumference did the job. The "L" that hooks the back of the seal is about 3/8 - 7/32 and rounded a little to match the seal curvature. This explanation took longer than it took to make the tool.
CJD
The front seal is one of those things...if you’re in the area it’s cheap and easy to replace. If it’s closed up and not leaking, then don’t worry about it.
I am sure you know the fixes to prevent the broken pin?
nichola
nichola
Bronze
Haven't read a fix for the pin except don't overtighten and do use a safety wire.
I have the new front seal on hand and the transmission is sitting on the bench. It's just that I'm getting gunshy about replacing things and then running into more problems. Like the pin fiasco.
CJD
That shaft is really cheap, so don’t sweat cutting it off. After spending hours trying to work the pin out using other techniques, the next time I encountered it I saws-alled the shaft in less than a minute and decided that is the way to go.
The extra bolt is the proven fix to ever breaking another pin.
As for the front seal, It’s an easy job with little to go wrong. You should not have to remove the input shaft, but if you do the only tricky part is to be careful not to tilt the pilot shaft as it goes back in. It should have roller bearings between it and the main shaft, so you don’t want those to drop out.
nichola
nichola
Bronze
Hey, how'd you know my middle name was Go-Wrong? I didn't mind cutting that shaft after a day of trying to get that pin out. But I should have just left the shaft and fork alone because it was easy enough to get to the seal. I saw that the two pins on the fork had a flat side where they pushed on the throwout bearing sleeve. I thought that was wear, but now I've read it may have been filed that way intentionally. I've learned my lesson: go to the forum.
Madflyer
Hay guys thanks for the memories. I am doing my front timing chain and cover seal and radiator* ( *cant be repaired new coming ) and what ever this week been 25 years. Next week comes the trans, clutch, flywheel gear and new starter and needed seals and most likely any thing I find. As for the fork hope is still good, to note I never start my car in gear or sit long at lights with clutch in. Question did your role pin on the throw out bearing collier stay. The last time not only did the fork have flats but made cups at the role pin I simply drilled the collier and moved the pin to remove some of the slop. The last will be adding the Backlight Top ( surrey top )and removing roll bar and soft top completely. With so much time and canceled vacation spend the money honey. Madflyer
nichola
nichola
Bronze
The roll pin was still in the sleeve on mine.
G BJ8 Transmission Front Seal Austin Healey 10
KVH TR4/4A Removing Front Transmission Seal Triumph 1
Rob Glasgow Front Transmission Seal Austin Healey 1
T Front transmission seal not on 100-6 Austin Healey 2
M XK 140 front transmission seal Jaguar 1
G Changing front oil seal on transmission. Triumph 14
G TR6 [TR6] removal of front transmission seal Triumph 5
S TR2/3/3A tr3 transmission front seal Triumph 3
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
Joe Schlosser Advice on Transmission Front Cover Spridgets 4
R TR2/3/3A Transmission Front Cover Triumph 3
Boggsy64 MGB Transmission engine mounts and front engine mounts MG 0
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
