TR6 After I put in my new oil pump....
Scot Montrey
I know I need to prime it but first I want to clean out the 50 year old passageways. Anybody know of a reason it would be bad to blow compressed air down from the valve train squirtholes? (Actually I would do this after removing the old pump and before putting in the new one). Second question- could I achieve good priming - after installing the new pump - by using a big plastic syringe to squirt new oil down those same holes? The whole Vaseline thing makes me nervous.
Thanks!
NutmegCT
Welcome to BCF.
Compressed air will blow out *some* debris, but also jam other debris in tighter.
Use kerosene and stiff brushes to clean each passage - kerosene dissolves the debris. Then flush with water/detergent. Compressed air afterward will help dry the passages. There's not just old oil and sludge in there - also tiny bits of metal and carbon.
Hope this helps.
Tom M.
Madflyer
Kerosene is a good call. I had a 1958 pickup as a first car. an was told to drain my oil now and a again and put in a gal of kerosene and run it a few min. to flush block. kerosene has an oil base so no damage but no driven or full motor temp either. as you may know is the what jet engines run on as in JP 4-5 . This may also be a good cal on a motor that sat for years. Madflyer
Tybalt
Sorry for the delay, tried to post this yesterday but had computer problems and couldn't the phone/camera and the computer to cooperate with each other. It’s easy enough to make your own pre-oiler tool for priming the system on these cars.
With the oil pump drive being a shaft with bladed end, a slotted shaft to fit the oil pump drive, a flexible coupling and another shaft to fit a drill motor will do the trick. You will need the following:
1/2” rod stock about 7” long
1/2” heater hose about 3 ½” long
1/2” or 3/8” rod stock about 6” long
Hose clamps
Tape to wrap 3/8” rod stock if using that size
Reversible 3/8” or 1/2” drill
To fabricate pre-oiler tool:
Slot one end of the ½ rod stock ¼” wide and ~7/16” deep with a rounded bottom
Insert non-slotted end into heater hose about 1 ½” and clamp in place
If using 1/2” rod stock, insert into other end of heater hose about 1 1/2" and clamp in place. If using 3/8” rod stock, wrap with tape to increase diameter close to 1/2”, insert into heater hose about 1/12” and clamp in place.
To use:
Attach tool to drill and set drill to run anti-clockwise.
Remove valve cover
Oil the slotted shaft and fit slotted end of tool onto the oil pump drive blade and run drill anti-clockwise, wait for oil to appear in the valve train and start to drain down back into the lower portion of the engine. If it starts to get too messy, you can refit the valve cover.
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Got the engine put together Spridgets 4
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
glemon General TR Time to Put Your Tops Up? Triumph 12
jlaird Before I put in classifieds Spridgets 36
Bob McElwee Rode Hard and Put Away Lovingly Austin Healey 6
J How to put a stop on the end of a choke cable? Restoration & Tools 2
M Who put the stick in my heater hose? Spridgets 6
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
drooartz Help me put together a plan for my Bugeye Spridgets 46
PAUL161 General MG Where Would You Put This? MG , VW, Motorcycle? MG 3
R 100-4 PUT-BACK-TOGETHER ?'s Austin Healey 2
RickB Just put headrest speakers in - wow! Spridgets 8
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
DrEntropy Can't put it off any longer. MG 10
M Body ready to be put on Chassis, 1 question first Triumph 9
B TR2/3/3A TR3. Would you put it back to right hand drive? Triumph 11
T Where to put the OD relay? Triumph 13
bugedd Before I put it on ebay.... Spridgets 0
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
Basil Where to put that bumper sticker Spotted 1
middie Before I put engine back Spridgets 22
Jims71TR Put a new fuse box in now I have troubles Triumph 15
regularman Has anyone here put a bugeye front end on a square Spridgets 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
BugeyeNJ58 Put on Harley Muffler--now backfires?? Spridgets 26
doughairfield Where to put the ground. Triumph 6
B Before I put the heater in my 57... Triumph 10
JPSmit Wasn't quite sure where to put this -youtube video Spotted 6
BugeyeNJ58 Radius arm came out...how to put new one in? Spridgets 6
bigjones Spare coil - put it under the hood? Spridgets 8
Marvin Gruber Put off too long Jaguar 4
T OT - what do you think, put a Rover V8 in it? Triumph 29
T Did they put TR frames under these? Triumph 8
jackq Something to put in front of your MG MG 0
Tinkerman Need to put a new hole in my dash! Triumph 20
JohnnyMead What to Put Under Carpeting? Triumph 11
I TR6 TR6 put put sounds, part 2 Triumph 74
T What do you think - put a team together for this? Triumph 2
livinginthepast Stupid Q dejour - horn push/badge won't stay put! Spridgets 14
T Largest tire size I can put on my 89 xj40 Jaguar 1
J So, I put my money where my mouth is....... Jaguar 12
