Trunion bearings
4tecdog
Anyone fitted replacement upper trunion needle type bearings in place of the thrust washers ? One uk supplier claims near power steering improvement !
steveg
I did it years ago. From Cape, IIRC. Some improvement, inexpensive, easy installation. "Power steering" is taking it a bit too far, esp with wider tires. As kids, we used to say "Power steering by Armstrong.":cool:
4tecdog
4tecdog
Thanks Steve probably worth doing then as not expensive as you say, but I will still be going to the gym for upper body strength ��
twas_brillig
We did as well. Can't compare before/after, but it seemed like a good idea at the time, and I believe that it was. Doug
Rob Glasgow
I agree with Steve. Did mine about 8 years ago. Don't have any objective numbers but an improvement over the original. Certainly not power steering but worth the small cost and minimal effort to install.
Superwrench Trunion Bearings Austin Healey 2
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
EWD TR6 Trunion Install Triumph 0
R TR6 Trunion Hole Triumph 2
Willie_P Trunion/lower wishbone washer HELP Triumph 3
B Lower trunion assembly Triumph 1
I TR6 TR6 Trunion installation/stop sleeve help Triumph 4
I TR6 TR6 trunion help - how tight, correct lubricant? Triumph 24
I TR6 TR6 Trunion resleeving? Triumph 2
dklawson Spitfire Spitfire - Trunion Bushing/Sleeve Clearance? Triumph 2
I TR6 TR6 frozen brass lower trunion Triumph 3
jhorton3 Trunion Spridgets 9
F er Trunion Bolts Austin Healey 5
T Trunion part missing Triumph 11
G trunion/vertical link seal Triumph 5
TR250 trunion re-assembly Triumph 4
TR250 Trunion question Triumph 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz MGB Any risk rolling car on dry bearings MG 4
B Rod & Main Bearings Recommendations Austin Healey 10
KVH General Tech Connecting Rod Bearings Triumph 8
Lin Bugeye Axle Hub & Bearings Austin Healey 1
Donald1107 TR2/3/3A Wheel bearings Triumph 8
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
C Seat Slide Bearings Austin Healey 3
algot1901 HELP with wheel bearings Other British Cars 1
Z 3000 Front Wheel Bearings Austin Healey 3
B Installing cam bearings 1275, can I do it? Spridgets 1
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
Y MK V rod bearings Jaguar 1
drooartz MGB Talk to me about bottom end bearings MG 34
B TR4/4A Original gearbox bearings Triumph 14
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
FlyingCat Spitfire Wheel Bearings Triumph 3
Got_All_4 TR6 What engine bearings to use in my rebuild? Triumph 9
Bantamfan Bearings Spridgets 16
D cam bearings Austin Healey 23
R General Tech Wheel bearings Triumph 3
R Wheel bearings Austin Healey 5
T Differential Pinion Bearings Austin Healey 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
KVH General Tech Plasti-Gauge on Rod Bearings Triumph 13
jfarris For Sale New TR3 Rod Bearings Big End Std Size Triumph Classifieds 0
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Wheel bearings?? Spridgets 4
Healey Nut Muffler bearings Austin Healey 5
R Rear Hubs/bearings Austin Healey 25
KVH General Tech Lubricating New Rod Bearings Triumph 7
