Results 1 to 6 of 6
Thread: Carb. Float Chamber Fix
  1. #1
    Join Date
    Feb 2017
    Location
    Henderson, NV
    Posts
    23
    Thanks Thanks Given
    4
    Thanks Thanks Received
    Thanked in
    Hello,
    I have a '74 TR6 with Stromberg carbs. Is there a fix for the plug and o ring in the float chamber? I replaced both; 1 is ok and the other is leaking; so I ordered a new plug and o ring. Possibly a float chamber that does not have a plug in the bottom?
    Thanks,
    Dan
  2. #2
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,781
    Thanks Thanks Given
    23
    17
    Thanked in
    Re: Carb. Float Chamber Fix
    Yes there are, but a good cleaning of the perimeter of the hole is usually required for a tight seal....and then there's the JB weld option
    You could give Joe Curto a call, he may have a plugless float chamber he'd part with.
    DRIVE 'EM IF YOU GOT 'EM
  3. #3
    Join Date
    Feb 2017
    Location
    Henderson, NV
    Posts
    23
    Thanks Thanks Given
    4
    Thanked in
    Quote Originally Posted by poolboy View Post
    Thanks for your response; do you have the contact information for Joe Curto?
  4. #4
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,781
    Thanks Thanks Given
    23
    17
    Thanked in
    Google "Joe Curto"
  5. #5
    Join Date
    Feb 2017
    Location
    Henderson, NV
    Posts
    23
    Thanks Thanks Given
    4
    Thanked in
    Thanks for your reply; I have emailed him.
  6. #6
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,781
    Thanks Thanks Given
    23
    17
    Thanked in
    Better if you call him.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
