TR2/3/3A Oil leak in tranny
2liter4cyl
Bronze
I have a 1960 TR3A, and the o rings on the shifter shafts have failed. Just how difficult is this repair, what is tricky.
LeT
Graham H
It's quite easy, just follow the workshop manual instructions, the balls retaining the shifter shafts will tend to roll out but a screw driver down the shaft will soon push them back in. The main thing you need to do is replace the O rings with quad rings QR112 I.D 1/2 inch O.D 11/16 C.S 3/32 they will fix the oil leak. You may find the locking bolts for the shifter folks may snap when you unscrew them so you will have to carefully drill them out and fit new ones, all good fun.
Graham
Sarastro
The o-rings sold for that application are really not the right size; they don't have enough compression to create a good seal. You might want to skulk around the internet a bit to find something that's sized better. One option I've hear of is a teflon backup ring, available from McMaster-Carr, part no. 9560K53, which you can put under the standard o-ring.
G Opinion on tranny oil leak Triumph 9
1 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 4
I MGB Sprung an (oil) Leak! MG 2
B Oil (or Coolant) Leak Austin Healey 10
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
B Phanton Oil Leak Spridgets 12
I Bugeye oil leak help Spridgets 4
Zitch Engine Oil Leak After Long Drive Austin Healey 19
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
steveg Strange Oil Leak Austin Healey 7
TomMull TR2/3/3A Transmission oil leak Triumph 17
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
D BT7 Oil Leak at Distributor Austin Healey 5
J TR4/4A Oil leak from rear of motor. Triumph 28
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
T Oil pan leak? Spridgets 7
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
D Oil Leak at rear of oil pan Spridgets 11
Martinld123 Austin Healey BN2 oil leak at base of distributor Austin Healey 7
C oil leak Spridgets 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR2/3/3A Locating source of oil leak Triumph 6
Jim_Stevens TR2/3/3A Trunnions oil leak Triumph 2
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
Martinld123 Problems with Oil Leak From Distributor Austin Healey 2
T TR2/3/3A coil mounting bolt oil leak Triumph 2
4tecdog BJ8 Overdrive oil leak Austin Healey 6
H blow by oil pressure causes oil to leak out of the dip stick tube. Austin Healey 12
TulsaFred Front engine oil leak Spridgets 33
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
Sixpack TR6 Bad Oil Leak Triumph 24
T Gear Oil Leak Austin Healey 17
Rut Bugeye oil leak Spridgets 8
J Found an oil leak Austin Healey 7
V Problems - Oil Leak and Manifold Pressure Austin Healey 1
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
J Engine block modification for oil to water jacket leak Austin Healey 8
apbos We have Vroom, Vroom and an oil leak from the Oil Filter! Spridgets 11
Gliderman8 TR6 Oil Leak found! Now what? Triumph 26
S Rear crank seal oil leak BN2 Austin Healey 20
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
johnrip Wedge TR7 Oil Pump Leak Triumph 2
RJS Oil Leak Questions Triumph 10
dklawson Oil Leak - I Screwed Something Up. Triumph 8
Bob_Spidell Oil Leak BN2 Austin Healey 2
