Plywood - woodn't you like to help
JPSmit
well if we haven't evicted the skunk it will be dead shortly as we thoroughly filled the holes with wood and metal and dirt - huzzah!
This is bringing about a 'use of shed' conversation. After a number of years or more or less ignoring the shed, Mrs JP has decided that a she shed/ potting shed might be nice and is slightly frustrated that in addition to all the sheddy things in the shed, there is an Austin 7 / 1/3 of a Vauxhall Viva GT and 2 1/2 Honda CT90's. sheesh.
However, not to be dissuaded we are now in negotiations for what this could look like - current plans involve splitting the shed about 60/40 - with me retaining the 60% (phew). This could actually be a win for me as it would allow me to put proper shelves in and organize the parts in an accessible way. What I am currently thinking of is to rub shelves along two walls and possible all three. I believe that I can make two shelves about 30 and 60" high. The shelves would be 2' deep. This would allow me to purchase a number of totes and stack them - two high per shelf and inserted lengthwise. This would allow 28 totes (floor and lower shelf) - and still leave the top shelves free for bigger body parts, bumpers and motorcycle frames etc. I don't imagine I would need that many totes but, in principle I can put a lot of stuff there - and potentially have a third wall of shelves also.
All of this leads to my question. How thick does the plywood for the shelf need to be? I will likely support them with 2X2's - and a vertical (2X3?) every 3 feet or so. So, not long spans - I am sure 1/2 inch is sufficient but, with budget always a factor - would thinner do?
thoughts?
thanks all!
Bayless
I wouldn't go any thinner than 1/2 inch. Just my 2p, YMMV, of course.
LarryK
Wouldn't cave to wife, get her a shed and eventually save money, work space, and cleaner cars. Potting soil will put a layer of dust on everything and fertilizers and garden chemicals eat paint and metal. Sheds range from free used to what you can afford. Loosing space is forever lost.
NutmegCT
Maybe I'm missing something, but don't you need to know the weight the shelves would support, before choosing the strength of the plywood?
Here's a set I build for books and CDs. Used pine, not plywood.
OK - back to my cave.
Tom M.
LarryK
I gave up my part of the basement, why I said don't cave. Have rented a 10X25 storage unit for parts and spare car. Made a potting table for wife. Then I got another metal shed at end of far driveway for more parts. I only had 1/4 of basement. Now the table saw, mitre and router table full of her stuff. Only good there is I can't do any wood cutting without her cleaning off table.
JPSmit
JPSmit
really no place to put another shed, there will be a wall in between and the shed is really just for storage - which isn't currently used to advantage. Besides, her compromise is that I get to use the basement which is a huge win!
LarryK
She wanted a Valiant, the agreement she was to do the upholstery. Seats have been in the basement two yrs., so I haven't got floorboards done. Only thing left is floorbords, cover seats and start. Even new tires sitting by car. Basement would give me more storage room. Understand the outside room. I'm full up then I just saw an XKE on craigs that is affordable. She asked where would I put it? I just said your MINI would go in the driveway as it is on the bottom of the list. Not very happy woman. Too bad this pandemic thing, she usually is out with her sister on Mondays all day. The E would be in the garage when she got home.
LarryK
George was never afraid to tell it like it is. Might not have been as clean as some people wanted, but he was usually spot on.
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
