76 Midget 1500 Oil filter
Alvin
I have a 1976 Midget with the `1500 engine (I think) and need to change the oil filter. It had a UNIPART GFE 4 filter on it, but when I go to NAPA and Autozone the filter they list for the car does not fit? The screw in part is too big? Can't find a cross reference for the GFE 4 filter? Any help would be appreciated. Thanks ........Alvin
Deleted member 8987
and you're certain it's a GFE 4? I cannot find any reference to a number for GFE that low.
A
Alvin
Yes, here it is. I could not find any reference to it either.
Deleted member 8987
The ONLY on-line reference to a GFE4.
http://cod.zeni.net/trf/spitfire1500/pdfs/1-Spitfire1500-Engine.pdf
Page 22
SINGLE CARBURETTOR ENGINE
—Oil Pump and Filter—All U.S.A.
NOTE 1 WL207 (3)
NOTE 2 UNIPART BRAND OIL
FILTERS
Part No. Description
GFE121
Oil Filter,
original spec.,
Spitfire through 1974
GFE2
Oil Filter,
Premium
Superflow for extra
wear protection
SLP178
Adaptor,
threaded,
used when fitting
the above two filters
GFE119
Oil Filter,
original spec.,
Fitted from 1975 on
GFE4
Oil Filter,
Premium
Superflow for extra
wear protection
SLP197
Adaptor,
threaded,
used when fitting
Deleted member 8987
Found this list for 1500 Midgets from Paul Teglerizer: long since dead link
Oil Filters to use: Pure One filter, the number model is PL10017, if you're interested. Other filters that might be used are
a.AC-Delco PF-53 (will work on all models of Spit.), PF-13 - requires an adapter
b.Carquest 85084 (said to be a Wix product)
c.Castrol PH922A (all Fram numbers should be same on Castrol filters)
d.Champion D102 (though not recommended)
e.Crossland 573, 595
f.Fram PH2825, PH922A, PH966B, PH16 -may be too large for later 1500's w/air pump
g.Fram PH8A (large can) using the oil filter adapter from MkI 1147 engines, (or non airpump 1500's?)
h.Motorcraft FL-2005, FL-1 (large- non-Air pump Spits only)
i.NAPA 551312 , Gold-1521, Gold 1374
j.Purolator #L10017, PER-1
k.UNIPART GFE150, GFE119
l.WIX 51084
For 1500 Spits:
https://www.triumphexp.com/forum/sp...8/correct-oil-filter-for-75-1500-spit.735502/
https://www.mgexp.com/forum/mg-midget-forum.3/1500-oil-filter-assume-nothing.1667558/
"that filter thing threw me at first too, been a few years, but I remember. Napa, AutoZone, O'Reilly's and others have an adapter fitting for the filter to screw on to. You ought to ask about it next time. It is just more convenient to be able to pick up your oil and filter at a local parts store."
A
Alvin
Well, I finally found out what to do. I could not find a match for my filter. None of the filters on the previous lists were carried by the big 4 parts stores and I did not want to special order it only to find it did not fit. Kept searching and finally found out that RockAuto listed the "adapter" to be used (WIX 24037). O'Reilly carry's the adapter. It allows a standard filter (Bosch 3422 + many other equivalents) to be used. Problem solved. Thanks for everyone's input.
Bayless
Glad to hear you found an easy solution.
T 76 midget 1500 oil pressure lines? Spridgets 15
R oil feed kit for 1500 midget? negatives in this? Spridgets 5
Morris Midget 1500 oil pan Spridgets 7
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
G 1500 Midget Oil Filter adapter Spridgets 1
G 1500 Midget Oil Pump Pinion Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
J 1500 mg midget fuel issue Spridgets 2
J 1500 midget master cylinder Spridgets 10
T ZS Question for 76 1500 midget Spridgets 33
frankenstang57 Educate me on the Midget 1500 MG 4
R Overdrive/5 speed options for 1500 Midget? Spridgets 21
P how to replace rear main seal in 1500 midget Spridgets 2
R pcv valve for 1500 midget? Spridgets 18
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
T 76 midget 1500 engine crud Spridgets 4
RickB Seat recovering, 1500 Midget Spridgets 18
R 1500 midget clutch inspection? Spridgets 3
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
D Vacuum unit for 1500 Midget Spridgets 7
P holes in 76 midget 1500 front bumper Spridgets 6
R compression test procedure on 1500 midget Spridgets 5
G 79 midget 1500 clutch? Spridgets 5
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
bcbug Midget 1500 Hose Connections Spridgets 9
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
7 79 midget 1500 Emission Removal Spridgets 3
G 79 mg midget 1500 wiring Spridgets 7
bcbug 1500 midget carb replacement Spridgets 38
A 1300 cam bearings in Midget 1500 Spridgets 3
M 78 1500 Midget Tire Sizes Spridgets 1
J Midget 1500 electronic ignition? Spridgets 10
