TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC
martx-5
I've never dealt with them, so I can't recommend one way or the other. However, that is the early style master that was used between TS13046 and TS34310. After that, they changed the masters, which had the different casting. Also, the seal was modified to cure excessive pedal travel (according to Piggott) . In the Triumph parts manual, the earlier type is superceded by the later style. When I got my current TR3 (TS23xxx) in the mid '70s, it had one of the early type, and one of the later type...both very grungy having been on there awhile. So it is a legitimate supercesion.
angelfj1
angelfj1
Thank you for the clarification. It seems that the one advertised on eBay is the only one offered by anyone with a correctly shaped casting.
sp53
I like them Angel. Even though I have collected a bunch of that stuff over the years, if I needed a set, I would give them a try before I bought some of the ones I have seen. Just because they would blend in better; I enjoy the original look. But again, it sounds like Tropic 6 has what you need. He has given me things before; he is a good dude.
steve
TFB
The Scotts offering may be more authentic looking but My guess is its from the same chinese mfg. that make them all.Maybe India.
Country of origin does not necessatily mean anything,but the lack of attention to detail on the boot fit and retaining method(lack of) I would be suspicious of the internals quality.
At least the Moss china sourced offering comes with a year warranty.
If I had an origianal with two seals I would not remove a seal and if rebuilding and I had the 2 seal kit I would use both.
The pushrod doesnt move straight along the bore center so under pressure the piston leading edge rubs the bore with only one seal in the rear.
if you found an original cylinder are the rebuild kits available?
Tom
sp53
China, Twain ,Vietnam, and Cambodia all have very competitive inner Markets. The manufacturing in these countries are not, “same—same” as they would speak it . Small companies go broke and reopen with better parts all the time. The problem they have is communication as to what exactly needs to be fixed. I truly hate to say this, but many of their products like tools, Milwaukee and Craftsman for example are made all over in Asia with parts coming from different counties and inner venders. If they knew they had to fix that rod in the Master cylinder to sell more, they would fix it.
steve
T 100 BN2 Possible Ignition Issue Austin Healey 7
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
M A possible problem with the clutch Spridgets 8
