Wheel bearing question
metropolisman
Good evening
my bj8 has scuttle shake, the wheels have a few broken spokes and are not true. ( 60 spoke chrome)
and the tires appear to be older than 7 years. The hubs have wear. I have replaced those items and I’m getting ready to install them. I’m thinking it would be prudent at minimum to clean and repack the wheel bearings and inspect the shim packs. The right front hub seems to have some backlash in it and spins very freely. I think these bearings may need to be replaced. I assume I will need to buy new grease cups , inner and outer bearings, a new grease seal and possibly replace the shims. Is moss a good resource for these items? Or perhaps someone can recommend a better avenue, perhaps timkin bearings? Your thoughts would be greatly appreciated. Thanks
Jeff
re: "I assume I will need to buy new grease cups"
I think you might be referring to the metal caps inside the hubs that protect the bearings? If so, you can fashion a puller with a suitable coupler and some all-thread or long bolts.
"... possibly replace the shims"
Shims can be used indefinitely (unless damaged). With new hubs and bearings, your shim pack will probably change a little; typically 0.030" of shims gets you close; if you have a micrometer, 'overpack' the shims and measure end play, then remove shims to eliminate the end play (with no binding or grinding). Or, if you have a lot of thin shims overpack them, then remove them one at a time until the bearings run free, with minimal to no end play. Determine the shim pack with only light oil on the bearings (not grease). You'll be tempted to fill the cavity with grease, just grease the bearings well and leave it at that.
Healey hubs should have a spacer between the inner and outer bearings; it's where the shims are placed. Some cars may have the spacer missing, and the bearings adjusted like a typical American car. The necessity and purpose of the spaces is subject to some debate, but you should have them.
Places like McMaster Carr might have the correct shims, but you'd need to get the ODs and IDs. Tom's Import Toys in Portlandia gives a 10 or 15 (?) % discount on Moss parts, and probably has shims on the shelf; great people to deal with:
https://tomsimport.com/new/index.asp
Rob Glasgow
no you you do not need to buy new grease cups. Just put out the old ones, do the bearing/shim work and reinsert the old cups.
Their only function is to hold in some of the grease and hold out some dust/grit. Much like a standard front axle hub cover on an American car.
pkmh
I have the real McCoy tool I've used to remove my stubborn dust caps, but here is the actual drawing I readily have and used to make the tool. And as my note indicates, $3.00 was about all that was needed to make this. Hope this helps a bit...
steveg
The extended nut above is a 5/16-24 fine thread coupling nut if asking for it at a hardware store. Somewhat hard to find - usually they are 5/16-18 coarse thread. Bolt Depot has them:
bob hughes
I made my cup remover too, and a hub remover, but found that I did not have to use the hub remover - not on the fronts anyway.
Assemble the hubs dry onto the car without shims, check the end float and provide shims to suit, you will have some already but get a few more of each size, I keep a stock of sizes as, in the past, I have removed hubs at least once a year on my 'rolling restoration' ( you always go over the ground several times when carrying out rolling restoes) it sounds a PTA but doing them the other way - by guessing, is a nightmare and very rarely works properly.
:cheers:
Visual aids to what Bob has described.
BJ8Healeys
Without the spacer ("distance piece") and shims, there is no way to be sure the load on the bearings from torquing the hub nut is not too light or too heavy. Too light can leave a lot of play in the bearing, too heavy can cause the bearing to bind or lead to early failure.
I have a detailed procedure for installing and adjusting the front wheel bearings, but BCF won't let me attach a Word document (30.0 kb) and if I save it as a .pdf it is 71 kb and exceeds the size limit of 48. Anyone who would like to have it, please contact me directly at sbyers@ec.rr.com.
Morris Another wheel bearing question Spridgets 3
tomshobby front wheel bearing question. Spridgets 9
bigjones Wheel bearing replacement question Spridgets 60
B TR2/3/3A TR3A front wheel bearing question Triumph 5
Luke_Healey Question about rear wheel bearing seals Spridgets 11
C Spitfire rear wheel bearing Triumph 2
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Lin Cause of burned wheel bearing? Austin Healey 5
A Front wheel bearing issues Austin Healey 11
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
Bayless Need wheel bearing advice please Spridgets 4
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
R Front wheel bearing - end float Austin Healey 40
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
KVH General TR Front Wheel Bearing Felt Seal Direction Triumph 9
C Rear wheel bearing or other cause? Austin Healey 18
T TR2/3/3A Another wheel bearing thread Triumph 5
G TR4/4A Front Wheel Bearing Seal Triumph 19
B TR2/3/3A anyone else had trouble with TRFs wheel bearing dust covers? Triumph 5
B Wheel Bearing Race Installation Austin Healey 7
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
steveg Spun wheel bearing traced to gasket thickness Austin Healey 16
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
S Problem removing front wheel bearing retaining nut Austin Healey 9
N Spitfire Front wheel bearing seal??? Triumph 11
Morris Wheel Bearing Shims Spridgets 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
7 General TR Chirping front wheel bearing Triumph 6
B Rear Wheel Bearing Oil Seal Spridgets 7
Morris Front wheel bearing installation Spridgets 4
H excessive wheel bearing shims? Austin Healey 11
NutmegCT TR2/3/3A TR3A wheel bearing? Triumph 7
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
TulsaFred Front wheel bearing grease packing Spridgets 26
G XKE rear wheel bearing replacment Jaguar 4
M Rear wheel bearing Spridgets 4
S Wheel Bearing Grease/Repacking Austin Healey 1
mountainman TR2/3/3A TR3 Front Wheel Bearing Triumph 1
D MK2 front wheel bearing adjustment Jaguar 8
PatGalvin Wheel bearing grease seal blues - they continue Triumph 15
T TR6 TR6 front wheel bearing ? Triumph 5
tomshobby specific front wheel bearing questions Spridgets 8
N Spitfire Spitfire Timken wheel bearing numbers Triumph 5
ekamm Need Timken wheel bearing #'s Triumph 13
GBRandy Wedge TR8 rear wheel bearing noise / replacement Triumph 5
Jim_Gruber Wheel Bearing Grease/ Impact wrench on hubs Spridgets 11
bigjones Wheel bearing nut torque Spridgets 11
T Bad front wheel bearing. Triumph 81
