Wishbone arms cotter pin removal
Claretannie
Hi Guys , I’m trying to get these cotter pins out and so remove the screw caps that go onto the bottom of the stub axle . I seem to be only able to press them in a vice about 1/8 of an inch until they’re solid . Do I have to turn the screw cap to a certain position to enable the cotter to come out ?
Thanks
Richard
red57
Hi Richard,
From the outside it looks like the cotters should push out after removin the nut & washer but they don't. The pins actually have a curved section cut out in the center of the length - this curve matches the diameter of the screw caps and sit in a groove cut into the circumference of the cap.
So what you need to do is loosen the nuts and then tap the pins up just a little, maybe a 1/16 or so, and then you can unscrew the caps. IMG_1890.jpg
Apologies for the very crude sketch but hopefully you get the idea.
Dave
Hi Richard,
attachment.php
Dave
Elaborating a little bit on Dave's sketch, here's a look inside the outer end of a lower control arm, where those cotters and cups reside. You see I've made on a note of my findings, so DO READ THE MANUAL (preferably, the Bentley Complete Austin-Healey 100/6 & 3000 version) to set up the clearances correctly (those threaded caps HAVE TO have room to unscrew & screw in during full range of travel__this is best done before the springs are installed).
warwick-steve
Thanks guys for this explanation. By coincidence I was trying to work out the function of those cotter pins and now I know.
The reason for my interest is that I noticed that the restorer of my car seems to have used on one side of the car one correct cotter pin and a bolt and nut which I presume he modified to have the correctly positioned concave form when he assembled the unit.
Everything seems well set up and well greased also there is no slack in the suspension. The car has done 18000 miles since restoration, 9 years ago.
I did note that the amount of exposed thread on the centre positioned fulcrum pin to swivel pin cotter pin is sufficient only for a nut, not a nut plus spring washer.
cheers
Steve
L TR2/3/3A Bent lower wishbone arms Triumph 6
J TR4/4A confirm upper wishbone arms Triumph 11
X Wishbone a arms MG 3
jerrybny Upper wishbone arms question Triumph 6
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
P Wishbone Pin Bushes Austin Healey 5
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
R TR2/3/3A Upper Wishbone Bushings Triumph 12
B TR2/3/3A lower wishbone installation Triumph 5
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
Jeepster Lower wishbone bush replacement. Austin Healey 33
matmire wishbone mounting bracket repair. Spridgets 3
B TR2/3/3A Inner wishbone bushings Triumph 5
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
Keith_M Lower wishbone recondition? Spridgets 5
CJD TR2/3/3A Lower Inner Wishbone Bushings Triumph 2
R Lower wishbone bushing installation trouble Austin Healey 9
S TR2/3/3A sleeves that go on the lower wishbone Triumph 5
M Getting the wishbone with bushings back onto the frame... Spridgets 2
K TR2/3/3A Front Suspension Top wishbone refit? Triumph 4
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
K TR2/3/3A Lower wishbone inner steel bush rusted to spindle? Triumph 2
T TR6 Physical size comparison of TR-4/TR-6 lower wishbone pieces ? Triumph 2
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
T Question on removing drivers front lower wishbone Triumph 7
Willie_P Trunion/lower wishbone washer HELP Triumph 3
Tabcon Paging Kai Radicke of Wishbone Classics!!! Triumph 11
Willie_P HELP: vy. hrd time remvng lwer wishbone bshngs Triumph 10
1 Inner Wishbone Bushes Spridgets 5
CinneaghTR TR6 TR6 Lower Wishbone Arm Question Triumph 3
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
H Inner wishbone removal Austin Healey 12
N Spitfire Spitfire Wishbone bushing question Triumph 3
K Further to wishbone clearance at steering box... Triumph 1
K TR2/3/3A TR3 Front end..wishbone assembly end float??? Triumph 2
K TR2/3/3A TR3 front end..mounting wishbone near steering box Triumph 9
K TR2/3/3A TR3 thrust washers wishbone arm to trunnion ? Triumph 6
I TR6 TR6 spring pan/wishbone arm help Triumph 2
T TR6 Question on TR6 lower front inner wishbone bracket Triumph 1
T TR6 OK - TR6 wishbone question part deux Triumph 0
bigjones TR2/3/3A TR3A Upper Wishbone - Bush R&R Triumph 16
19_again GT6 GT6+ wishbone strut rivets Triumph 12
A TR6 TR6 Front lower wishbone mount [rear] broken Triumph 1
K TR2/3/3A TR3 Wishbone bush ream spec? Triumph 8
K TR2/3/3A TR3 ..front lower wishbone removal question.... Triumph 6
