Midget Thrust bearing coonversion
JPSmit
Midget Thrust bearing conversion
In another forum, I have been watching a curious Midget project - the guy is swapping the engine but keeping the transmission (which is the opposite of what I would do) More to the point he has installed a contemporary thrust bearing. Thought it might be worth sharing here.
Thread is here: https://forum.retro-rides.org/thread/208938/1963-midget-nissan-cg13-project
thrust bearing is this:
Gliderman8
Is that a hydraulic throw out bearing?
when I did the 5-speed conversion on my TR6 I got rid of the clutch slave cylinder and installed a hydraulic throw out bearing. I like it!
JPSmit
JPSmit
do you have pics? Also, how did you determine which bearing to use? and, how do you bleed one of these puppies?
thanks!
Gliderman8
I will look for pics. Bleeding was super easy. As I remember, I let one hose hang down and pumped the clutch until the fluid flowed steady and then reattached the hose end. The hydraulic clutch I used came with the HVDA 5-speed kit that I bought. Here's the installation instruction sheet....
Gliderman8
I found a pic.... hope this helps.
Rut
JP, I researched this conversion and I really liked the idea until my son and I bought a 1993 Jeep Wrangler which comes stock with one. While asking advice on the Jeep forums it became clear that just about everyone had or wanted to change to an external slave cylinder set up because of access when it starts to leak. A lot of these folks are hard core off road people and they have getting home as a priority and a bad/leaking slave really makes that difficult to do considering the terrain. That said, for those of us willing to pull the engine/transmission to fix a leaky TOB it’s a consideration and it removes a lot of potential slop from our clutch system. I’m still on the fence on this one.
Rut
Gliderman8
Rut, no doubt that when/if I have a problem with my hydraulic throw out bearing the trans has to come out and I’m ok with that. Mine has been in for approximately 12-13 years.
A broken fork pin would also necessitate pulling the trans as well...
JPSmit
JPSmit
Elliot, where does the second line go in your picture?
Gliderman8
JP here's a photo looking up from the bottom of the car. One line goes to clutch master, and the other line (bleeder line) terminates in a mounting bracket attached to a mounting bolt on the bell housing.
JPSmit
JPSmit
Thanks for this! I wondered if that is what it was. I am tempted (one day) to plumb a similar line at the high point of the 1500 clutch line (higher than the MC)
D Trying to get back working on the 1974 Midget Spridgets 4
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
G 79 Midget Clutch issues Spridgets 9
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
