TR2/3/3A Block deck height?
Bremer
Hello, just doing some engine building math here. There is one dimension that I can't seem to find anywhere, and hope that forum members here can help.
What is the block deck height of the TR2/3/4 engine? I am referring to the distance between the crankshaft center line and the deck (top surface) of the block.
Thanks, appreciate it!
TomMull
I'm no engineer or engine specialist but here is my take. While I'm sure the spec that you're looking for is available somewhere, there is another variable involved with the wet liner engine. The critical distance is from the center of the crank to the top of the liner. The deck must be compatible and the difference or protrusion is given as .003 to .005, I think. The liner height is determined by the machined surface at the bottom, the height of the deck and the thickness FO8 gaskets. The only number I've been concerned with is the liner height.
Tom
Bremer
Bremer
Hi Tom, yes, you are correct that liner protrusion above the block deck is critical. I would have just added 3-5 thou to the block deck height to come up with the relevant dimension.
I'm looking at possible combinations of rod length and piston compression height, and the block deck height is required to be able to calculate compression ratio (assuming compressed thickness of the head gasket and combustion chamber volume of the head are known).
TomMull
Do you require a published standard spec rather than measurements from an old engine?
Bremer
Bremer
I prefer the original spec, but a measurement, depending on accuracy, will get me in the ballpark and would be quite helpful.
TomMull
I'll see if I can come up with some kind of mandrel. If so I can give you a number. I won't guarantee the accuracy so it would be good if someone else chimes in. Tom
Bremer
Bremer
Thanks very much Tom, I appreciate it.
TomMull
I had a go at it without much success. I couldn't true up get the tube I intended to use as a mandrel as it was to big for my little Logan lathe, so I shimmed it. I managed to get the range within about .020 but that's not much use to you. I'll PM with the numbers that I have I have if you want and if I get some idle time I'll try a different approach.
What I or someone else could do accurately is give you the distance from the piston top (standard 86 mm pistons) at TDC from top of the liner or the block but although I have two bare blocks in my shop and one long block I do not have one with the head off and the crank and pistons in right now.
I also wonder if it might be helpful to post you question in the racing section of this forum.
Tom
DavidApp
Hello Tom
Could you use a straight edge across the main bearing housing in the block rather than a mandrill?
David
TomMull
Thanks for helping out here David. I'm actually measuring with a 12 inch dial caliper, a decent one that is quite accurate at least up to 3 or 4 inches but accuracy unknown around ten, which is near the deck height but it's the only thing I've got long enough. I did measure from the journal to the top of the block but if I measure from the apex of the cap and then the apex of the block I get a difference of + or - about .010 and that measurement differs from the mandrel measurement by about the same.
I did not use a straight edge and that might make it a bit easier with the caliper.
Tom
Bremer
Bremer
Thanks very much Tom, appreciate it. I sent you a PM.
I like the idea of measuring piston deck height. If the piston's compression height (distance from wrist pin centerline to top of piston) is known, then all the information is available to calculate block deck height.
Sarastro TR4/4A Engine block deck flatness Triumph 9
PatGalvin TR2/3/3A Wet Sleeve to Engine Block Deck Clearance, TR3A Triumph 4
sim A-series Engine Block Search Spridgets 2
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
B TR6 TR6 block decking Triumph 2
B TR6 71 block & crank Triumph 1
T Block Heaters Austin Healey 3
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
R For Sale 100 engine block w/head Austin Healey Classifieds 3
Sopwith_Camel what is this on the block? Jaguar 13
BoyRacer Mystery 3000 Engine Block Austin Healey 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
P TR2/3/3A Block treatment post cleaning Triumph 17
Bayless Ready for final block sanding Spridgets 5
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
R Rust in Block? Help needed! Austin Healey 6
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
nichola TR6 Classic Technologies front sealing block Triumph 7
nichola TR6 Aluminum block engine Triumph 8
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
Bayless Memory block Spridgets 3
D TR2/3/3A Coolant tap on TR3 block Triumph 3
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
T Oil filter block plate - really? Austin Healey 13
6 1275 Head to block dowel pins Spridgets 10
D New Fuse Block Configuration Austin Healey 21
KVH TR4/4A Block Water Outlet Valve Triumph 13
D 3000 engine block Austin Healey 0
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
S BJ7 frozen temperature sensor to block Austin Healey 17
D mystery of the day... pedal block? Austin Healey 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
simon1966 Numbers stamped into a BN1 block? Austin Healey 5
M TR6 Front sealing block Triumph 11
H Post-War Other Herald rear suspension lower block installation Triumph 3
D Engine Block Austin Healey 14
jfarris TR2/3/3A Head stuck on block Triumph 8
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
J Austin healey block Austin Healey 18
Zitch TR4/4A New fuel pump fitment to block Triumph 3
M About alternator bracket and cylnder block interface on BN1 Austin Healey 9
