Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: New Tires or Keep Old Ones
  1. #1
    Jedi Hopeful CessnaTPA's Avatar
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    128
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    My 100-6 has 4 tires with less than 5k miles but are 12-15 years old. They appear to be in good shape with no visible cracks and run smooth. I'm in a dilemma if I should replace them since they are so old or just keep them and not worry about it. What brought this on is my spare tire needs replaced so I have 2 choices, 1- buy 4 new tires and use the best old tire as the spare, or 2- only buy a spare. What do you guys think? I'm only driving the car 1000 miles a year with speeds under 70mph.
    1957 Austin Healey 100-6 BN4
  2. #2
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,358
    Thanks Thanks Given
    73
    99
    Thanked in
    Re: New Tires or Keep Old Ones
    Wouldn't trust them. If the size is OK, keep the best one for the spare.
    If your car's a BN6, make sure the spare will fit through the slot in the bulkhead. Mine's a 25 year old 165 Michelin and it just fits.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  3. #3
    Yoda Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,127
    Thanks Thanks Given
    5
    22
    Thanked in
    Neither: Toss them all and get five--not four--new ones.
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  4. #4
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,731
    Thanks Thanks Given
    3
    37
    Thanked in
    Driving with aged-out tires is kinda like flying a plane that's out of annual--though I'm not aware of any specific laws (yet)--if anything goes wrong, you'll be at least partially at fault, regardless of circumstances. I think the states that have annual auto inspections would not allow them (anybody here live in such a state?).
  5. #5
    Jedi Knight nevets's Avatar
    Join Date
    Oct 2002
    Location
    Western MA
    Posts
    1,073
    Thanks Thanks Given
    Thanked in
    My Healey has 15+ year old tires on it and like you, I drive under 1000 miles a year at speeds under 70 (under 65 actually). I plan to replace the tires soon. One thing that concerns me about tire replacement is finding a shop that knows how to deal with wire wheels. FWIW, the owner's manual for my 2018 Honda HRV states that tires should be replaced 10 years after their date of manufacture regardless of condition.
  6. #6
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    128
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by Bob_Spidell View Post
    As a pilot that's a good analogy and I've ordered 4 new tires.
    I think the spare is 50+ years old, a Goodyear Custom Super Cushion.
    Thanks guys for the push to get new tires which I knew deep down was the right answer all along.
  7. #7
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,949
    Thanks Thanks Given
    15
    Thanked in
    Hi All,
    Although I can't argue with the suggestion to replace your running 4 tires (retaining 1 for a spare), living in a moderate climate (New Jersey), I would at least replace the tubes if intending to extend their longevity for a short period. However, your hot and humid Florida climate is highly conducive to tire case deterioration from rot and flat spotting as a result of long periods of immobility (indicated by low mileage). These potential conditions (even when not obvious) can produce explosive tire failures at any speed.
    Although I have kept tires in excessive of 10-years, I live in a temperate climate (New Jersey) and try to drive my Healey at least once a month throughout the year to assure a constant change in tire position when parked. I do change tubes at lest twice during the initial 10-years and again when considering extending tire longevity for a short period after. I find that a 165R15 is my preferred size to provide road height, the best fill of the well, and good maneuverability for my casually aggressive cruise driving. All in all, I can understand your question as it is difficult to get rid of tires that look good with little ware but it's incognito conditions that require tire-age replacement.
    Also, I have had no problems with my front WW hubs but have replace rears due to tooth rounding. Although normal ware can cause this condition, I must admit that, over my early Healey years, I had not properly tightened the knock-off after working in the area and spun the hub in the wheel on take-off. As a rear wheel drive, this condition is not uncommon and I would replace the rear hubs (at minimum), even if an inspection indicates they are satisfactory, if I were replacing Wire Wheels.
    Just my thoughts,
    Ray(64BJ8P1)
  8. #8
    Jedi Warrior Rob Glasgow's Avatar
    Join Date
    Feb 2003
    Location
    Lompoc, CA
    Posts
    745
    Thanks Thanks Given
    3
    Thanked in
    As tires age, the rubber can become hard and adversely effect the ride quality. I was pleasantly surprised with how much softer the ride was after I replaced some 12 year old tires on my BT7.
    Rob Glasgow
  9. #9
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,523
    Thanks Thanks Given
    7
    Thanked in
    WOW:
    Get five new tires even if they are cheap, Cheap new tires are much safer than expensive old ones especially 15 year old ones
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  10. #10
    Yoda tahoe healey's Avatar
    Join Date
    Aug 2002
    Location
    South Lake Tahoe, CA
    Posts
    3,473
    Thanks Thanks Given
    2
    Thanked in
    Check out Hendrix Wire Wheel. Send him the wheels with out tires (I left the inflated tubes on to protect the rims). He will supply the tires (he has good choices) and true the wheels and tires. They will come back with the tires rounded trued too. He will paint the painted ones. While you are shipping, throw in the rear brake drums and he can balance them too and get rid of the 62 MPH shake.
  11. #11
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,355
    Thanks Thanks Given
    34
    21
    Thanked in
    Yes, replace is the correct answer. I had an 11-year old tire that looked good disintegrate on me. Fortunately, it wasn't on the Healey.
    John, BN4
  12. #12
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,358
    Thanks Thanks Given
    73
    99
    Thanked in
    My local America's Tire (same as Discount Tire elsewhere in US) has people trained for tubes and wire wheels. My neighbor has had his Ferrari Borrani wires mounted there. They order old-pattern Michelins & tubes from Coker.
    ...So there may be a tire shop near you that can do the job.
    I do not feel uncomfortable using a too-old tire as a spare, never having used it in the 19 years I've had the car. If I do have to use it, I'll drive slow. With BN6/7s there's a real problem getting a tire that'll fit in the spare slot.
    Steve Gerow
    Altadena, CA, USA
  13. #13
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    128
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by steveg View Post
    I ordered Firestone 165r15 tires from JEGS and they have a $50 gift card deal going on right now and getting the tubes off ebay. I'm going to attempt to change the tires myself with tire irons & spoons, I removed the spare tire yesterday and it wasn't easy but not that bad. I've always done my own tires on my motorcycles so we will see how it works out on the Healey. It's become more of a challenge since a buddy said I couldn't do it, we will see if he is right.
  14. #14
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,731
    Thanks Thanks Given
    3
    37
    Thanked in
    Any tire shop can fit up the tires, if they're careful. It's getting them balanced that is the problem; it's not tricky, but requires special adapter cones for the computer balancer and a lot of shops just don't bother to get them. I don't know if manual balancing works well enough to mitigate the dreaded 'scuttle shake.' The last couple wheels I had balanced were done by a custom bikes shop and they were done right.
  15. #15
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,523
    Thanks Thanks Given
    7
    Thanked in
    British Petroleum here in the North West US have the capability to handle tubed wire wheels I was surprised but grateful.
    1985 XJ6 Saloon
    1973 Volvo P1800ES
  16. #16
    Join Date
    Dec 2008
    Location
    Calgary, Alberta, Canada
    Posts
    874
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    The "rule of thumb" I've been advised to use is seven years (however, Honda's ten year advisement is something I can't disagree with, although I ride a Kawasaki triple and a Buell....).
    I've been told to look closely for cracks (sidewall and tread), but will go with the advice from a shop that did a lot of work on our BJ7 who mentioned that, in their experience, an exploding tire takes a lot more bodywork to repair than the cost of a new tyre. Heat kills tyres; flexing on the highway combined with a hot environment is defiintely a killer. I do like the idea of swapping tyres out at 8 years and keeping the best as a spare - coupled with the wisdom of putting a new tube into the spare. I surely don't understand the dynamics, but it also sure seems like a dang good idea. Plus then treating it like one of those mini replacment modern tyres and keeping it down to 50 mph/80 km/hr, or thereabouts. Life's a mystery. Same with women and tyres and a whole lot of other issues. Doug
    1959 pristine 948 cc Bug-Eye; DCOE, 5 speed; bought 1971
    1960 BE bought 1971 & stored since; body tub restored and reassembling (1275; etc.)
    1962 AH 3000 BJ7; 3rd owner (1982?); in shop Oct. 2015 for paint job - home soon!
    1962 VW Meyers Manx clone dune buggy; stripped last winter and being reassembled
    1969 Kawasaki 500 H1 Triple, orig. owner; stored since 1973, but runs again! 1999 Buell S3
  17. #17
    Yoda glemon's Avatar
    Join Date
    Jun 2007
    Location
    Nebraska, USA
    Posts
    3,251
    Thanks Thanks Given
    8
    4
    Thanked in
    I will second and add to what Keoke said, a modern, new cheap tire is better than an old tire of any kind. Say what you will about progress and quality, but I think we can agree that a modern tire, even a Kumho, Nexen or Nankang, is a better tire than a Michelin XZX or Dunlop GoldSeal, so you are going better than OEM on your car. Buy a set of cheap tires from Wal-Mart or whatever, and you shouldn't feel too bad about replacing them when they age out with plenty of tread left.
    Or autocross like a madman five or six times a year, then you won't have to worry about your tires aging out before they wear out, and you can have a little fun too.
  18. #18
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,731
    Thanks Thanks Given
    3
    37
    Thanked in
    I bought a set of Nexens for my BN2 from WalMart. The Walmart folks were terrific; the tire shop helped me load them up and the online sales manager opened his register early so I could pay (and not have to come back later). The Nexens handle fine, but I don't drive that car a whole lot.
  19. #19
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    128
    Thanks Thanks Given
    Thanked in
    Took the tire off and it revealed the manufacturer date February 2004 so I've been driving on 15 year old tires. New tires showing up on Thursday.
  20. #20
    Join Date
    Dec 2008
    Location
    Posts
    874
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    The rear tyres on our dune buggy are ten years old. Stopped at the shop and there's no cracking in either the sidewall or the tread sections, but we ordered replacements. Our climate is cooler and the tires don't have excessive exporsure to the sun, but tires are cheap compared to the value of the vehicle and the possibility of a catastrophic failure. I'm not planning on any long highway trips this year, but normal communting still gets us on the 110 km/hr (68 mph) roads.
    If had (a) more power and (b) IRS instead of a swing axle, I'd sure like to explore the autocross option for getting maximum value out of the tyres.
    On another note: the Austin-Healey Concours Registry scoring sheets state: "*Note: tires 15 or more years old are considered not roadworthy and will receive the full 5-point deduction." Doug
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
