General Tech Electronic store for quality connectors.
sp53
I have been looking for some quality connectors that would have a more rubberized coating on them. All I can find online or local are those hard plastic common colorfully ones I see at like Home Depot. Does anyone know a place off hand on line that still has the black rubbery coated quick disconnect connectors?
steve
TR3driver
Great Pumpkin - R.I.P
You could always learn to roll yer own
martx-5
Rut
CJD
You can get the latest type sealed connectors...the type used on modern cars that make them so much more reliable than our old ones, through one of the national electronics suppliers. I have Allied and Mouser, which are local to DFW, but are so easy to mail order that I usually don't even drive to them. Mouser, especially, will get the order out same day and have it my door the next.
The downside...there are so many styles, with so many numbers of wires, with so many power ratings...it takes a good amount of time googling through their catalogues to find the style and size you want. Bosch has one of the best lines of sealed connectors, but tricky to navigate. They usually come with male and female separate...so finding the matching pair takes a while. Help, like Radio Shack used to give, is practically non-existent, so plan on taking an hour to find a good connector pairing.
The spade connectors, shown above, are convenient and available, like everywhere. They are on the bottom of my list for reliability, though. Our family '67 VW Bug used nothing but spades...on the entire car. After the car passed 10 years old (like, when I started driving it at age 16!) you could never get in it without something electrical acting up. It was never the component, but rather the crappy spade connectors. Wiggle, jiggle around and the component would start working, but OMG what a pain!! I still use spades, chiefly because they are often all you can get at parts stores and Lowes, but avoid them whenever I have time to order an alternative. VW broke me!
TFB
I used T&B ,Thomas and Betts bullet connectors and Klien crimper for My TR3 custom harness.But as Randall suggested the removal of the plastic insulator to be replaced with shrink tubing looks nicer.6 years,no solder,no problems.
Tom
Sarastro
I've bought a lot of stuff from Waytek https://www.waytekwire.com/ and Wiring Products https://www.wiringproducts.com/. If you need decent-quality spade connectors, their stuff is probably as good as it gets. Those things from Harbor Fright, Home Depoop, and probably your LAPS are beneath contempt. Spade connectors can be OK if properly made, with the right materials and plating, but you have to go to the right place to get them.
I always solder spade connectors and use shrink tubing on them.
That said, I plan to use Molex connectors wherever I can in my TR4A restoration. Those are the white nylon connectors used for your computer power supply, motherboard connections, and so on. You can get them lots of places, Digi-key and Mouser included.
bash
If you need a source in the US, I would suggest www.britishwiring.com - always happy with the components from them, including a couple of more unusual connectors. Also TRF carry the uninsulated connectors and covers.
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Basil Electronic Clutch [Deleted] Other British Cars 9
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
O Sprite Petronix Electronic Ignition Spridgets 10
S Fried electronic ignition? Austin Healey 22
F TR2/3/3A Timing with Electronic Ignition Triumph 14
B Crane Cams Electronic Ingnition Austin Healey 9
S Wiring connections for electronic ignition BJ8? Austin Healey 3
T MGB Vacuum advance and Electronic ignition conversion MG 5
rjc157 bn7 electronic choke Austin Healey 0
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
S TR2/3/3A Tr3/4 electronic distributor Triumph 2
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
T TR2/3/3A electronic distributor problem Triumph 3
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
F Swapping out original 1098 distributor to electronic Spridgets 13
L Electronic ignition? British Motor Corp 4
S TR4/4A Electronic Ignition Recommendations? Triumph 14
PAUL161 General MG Crane Electronic Ignition MG 9
S will old style distributer cap work with electronic ignition on AH Austin Healey 8
Keith_M SU Electronic Fuel Pump Spridgets 3
DanLewis Electronic tachometer for Bugeye Spridgets 18
R Electronic Ignition Distributor Spridgets 14
JPSmit Electronic Rust Inhibitors: works? - or snake oil? Restoration & Tools 8
D Electronic Ignition for 25D distributors Spridgets 15
D Timing with an electronic distributor? Triumph 14
S TR6 TR6 speedo to electronic conversion anyone? Triumph 15
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
bighealeysource LED bulbs and electronic flasher module issues Austin Healey 26
M Fuel Flow problem with new Electronic SU Pump Austin Healey 2
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
sundown TR6 TR6 electronic ignition Triumph 10
mountainman pertronix electronic ignition hepl please Triumph 10
D TR6 TR6 Electronic Ignition Triumph 16
PATR8 Wedge More TR 8 electronic questions Triumph 2
T Electronic Ignition Issue Austin Healey 6
wkilleffer Anyone familiar with GM Electronic Climate Control Other Cars 11
A Pertronics vs Electronic Distributor Triumph 23
D Installing Electronic Distributor Austin Healey 8
Tim_Creger need help with electronic distributor MG 7
drooartz Cheap electronic tach for bugeye? Spridgets 9
B What is best electronic ignition setup MG 19
T Electronic Ignition MG 15
