TR6 Removing Left Rear brake line... help!
Gliderman8
Some help please....
I am in the process of removing the brake lines on my '73 TR6 and of course there's always one that gives you trouble.
Specifically I can't remove the Left Rear brake line. I have the hose disconnected from the caliper but I'm unable to remove it from the three-way connector. There's little room to get a wrench on the hose fitting and no room to turn the wrench. The hose is on TIGHT!
Any suggestions for getting the Left Rear brake hose off?
Thanks for any help!
sail
I remember swearing in that wheel well but if I remember right the 3 way was easier to get to from under the car.
Gliderman8
Gliderman8
Thanks Richard... It's not the three-way but the brake hose that has to come off. In the end, I just might have to remove the three-way connector so I can get the hose off :concern:
trrdster2000
Elliot,That''s it, remove the 3 way 7/16 bolt and the pipes from it. Be sure to use a line wrench, don't want to round those lines and have to buy new ones.
Be very careful with the line going from the flex hose to the wheel cylinder. That right angle bend at the wheel cylinder will turn and break if you look at it side ways.
charleyf
I have a friend who does not frequent the forums. He just changed his brake lines and yes the left rear was a bad one. What he used was a crows foot wrench with an extension and ratchet and then made up a piece of wood to use as a wedge to hold the 3 way in place as it tends to want to twist with the fitting.
Hope this helps.
Gliderman8
Gliderman8
Seems awful tight to get a ratchet in that space. This afternoon I hope to get back out to the car and give it a go once again... will let you know how things go.
charleyf
With a crows foot and an extension you do not need to get to close with the ratchet . So you can use a long enough extension to be able to use a ratchet.
Gliderman8
Gliderman8
OK, the job is done and it was a royal PITA. I ended up removing the 3-way connector with some wrenches, then removing the rubber brake line that was connected to it.
I replaced all the rubber lines with four new Goodridge braided brake lines. I only hope I'll be able to tell the difference after all this work!
Thanks for everyones help... it's appreciated.
sunbeam25
I took a razor knife and cut the flex hose close to fitting then removed the fitting with a 9/16 deep socket
Gliderman8
Gliderman8
Thanks, that’s one way to do it.
G Advice needed in removing front left fender. Triumph 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
