Memory block
Bayless
What do we call the little can that the gearstick protrudes through?
Stan Kowznofski
If it holds the rubber grommet around the shift lever it's called the cover (948, 1098 and 1275 thru '69), if it's the later model that adds support to the leather boot it's called the support (1275 '70 thru '74).
I call it a "hat" ... dunno why.
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
Rut Help a bad memory out... Spridgets 6
GTP1960 Drive down memory road. Other Cars 14
NutmegCT Memory test Other Cars 9
F Sharing Memory Lane in an Austin Healey Austin Healey 7
PAUL161 Happy/Sad Memory, My Old Austin Other British Cars 2
Nelson Senior memory aid Spridgets 12
Morris Refresh my memory... Spridgets 5
K Memory Refresh:What oil to use after break-in? Triumph 1
K SU Mix Adjust Memory Refresh Triumph 7
10musketeer Clutch Peddle Box- Refresh my memory Spridgets 7
B A sad memory of a fellow Midget Owner. Spridgets 5
jlaird Someone jog my old memory Spridgets 20
Cain Stereo Memory Wire/Speakers Triumph 4
sim A-series Engine Block Search Spridgets 2
1 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 4
B TR6 TR6 block decking Triumph 2
B TR6 71 block & crank Triumph 1
T Block Heaters Austin Healey 3
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
R For Sale 100 engine block w/head Austin Healey Classifieds 3
Sopwith_Camel what is this on the block? Jaguar 13
BoyRacer Mystery 3000 Engine Block Austin Healey 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
P TR2/3/3A Block treatment post cleaning Triumph 17
Bayless Ready for final block sanding Spridgets 5
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
R Rust in Block? Help needed! Austin Healey 6
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
nichola TR6 Classic Technologies front sealing block Triumph 7
nichola TR6 Aluminum block engine Triumph 8
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
Bremer TR2/3/3A Block deck height? Triumph 10
D TR2/3/3A Coolant tap on TR3 block Triumph 3
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
T Oil filter block plate - really? Austin Healey 13
6 1275 Head to block dowel pins Spridgets 10
D New Fuse Block Configuration Austin Healey 21
