Results 1 to 9 of 9
Thread: Another trafficator issue
  1. #1
    Jedi Knight Lin's Avatar
    Join Date
    Apr 2002
    Location
    Bradenton, FL
    Posts
    898
    Thanks Thanks Given
    5
    Thanks Thanks Received
    3
    Thanked in
    Hi guys,
    I experienced a weird one today. When I move the trafficator turn arm to the right or the left the indicator will flash two or three times and then nothing happens. Any suggestions on what to check first before I start taking things apart?
    Thanks,
    Lin
    1959 AN5 Bugeye - now with my son 😀
    1960 BT7 3000 MKI
    1987 Alfa Romeo Spider Quadrifoglio
  2. #2
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,527
    Thanks Thanks Given
    7
    Thanked in
    Re: Another trafficator issue
    HI Lin:
    Replace the blinker relay may help.?
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  3. #3
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,954
    Thanks Thanks Given
    15
    Thanked in
    Hi Lin,
    Although I think Kioke's suggestion has a greater chance of resolving your issue, hear is another thought that I have experienced.
    Have you used any spray to clean and/or polish your dash, steering wheel or its hub recently? These sprays are non-conductive and can fall into the trafficator opening and cause your contacts to have greater contact resistance. I resolved my issue by getting a can of Tuner Cleaner and spray a modest amount into the Trafficator opening while moving the lever to clean the contacts.
    Just a thought,
    Ray(64BJ8P1)
  4. #4
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,366
    Thanks Thanks Given
    75
    99
    Thanked in
    Lin - I have the same problem but to a lesser degree. My setup works better (but not perfectly) since I loosened and re-tightened the wire-connection screws a couple of times each around the flasher relay.
    I think Ray's suggestion re the trafficator has merit. If mine stops flashing, often operating the switch again makes the flashing resume.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  5. #5
    Jedi Knight Keith_M's Avatar
    Join Date
    Aug 2012
    Location
    Logan, UT
    Posts
    983
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I would guess the blinker relay too. The new ones (at least the one I got) are solid state and seem much more reliable than old ones that work with contact points.
    They're not cheap, and it's not an easy thing to replace.
    Keith
    Keith
    '59 Bugeye (recently restored)
    '62 BT7 (recently restored)
    '65 Sprite (restored 30 yrs ago)
  6. #6
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,366
    Thanks Thanks Given
    75
    99
    Thanked in
    A lot of the old ones are working after 60 years, so they may be more reliable than the new ones.
  7. #7
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,954
    Thanks Thanks Given
    15
    Thanked in
    Hi All,
    Although I have used solid state devices to address some component issues (i.e. trafficator Relay rebuilt with relays), I must contend that, for the most part, I have experienced Steve's statement of having better luck with Original Healey devices. I am still running the same Lucas fuel pump that I installed in the 1970s and should have retained my original (given to a friend and still in use today). However, I did install a TSV diode on my pump that sets a limit on transient voltage generated by its coil and gates all exceeding voltage to ground. This provides control of power passing across the points and eliminates point burn. However, since the voltage limit chosen is sufficient to burn of winter-storage developed oxidation, the points will last indefinitely without maintenance.
    Again, I am not against the incorporation of modern technology but not without understanding its vulnerabilities where possible.
    Ray(64BJ8P1)
  8. #8
    Join Date
    Apr 2002
    Location
    Bradenton, FL
    Posts
    898
    Thanks Thanks Given
    5
    3
    Thanked in
    Replaced the flasher relay. All is now right (and left) with the world.
    Lin
    1960 BT7 3000 MKI
  9. #9
    Jedi Warrior roscoe's Avatar
    Join Date
    Jun 2004
    Location
    Esparto, CA
    Posts
    697
    Thanks Thanks Given
    1
    9
    Thanked in
    My wife chides me for signaling my intent to turn on the early side. Thinks I should wait until I'm closer to the turn...the reason....well, the blinker relays only have a fixed number of clicks in them and why use them up faster. Come to think of it that sounds like something I'd say that she would laugh at.
    Jon Robbins
    1956BN-2 (do it all yourself, you'll be glad you did)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
