TR2/3/3A Mirrors.
DavidApp
I have found that the rear view mirror mounted in the center of the dash has a limited view and the wing mirror is even more limited,
It seems that a mirror mounted on the windshield stanchion would make keeping an eye on traffic behind you a bit easier.
Has anyone come up with a good solution?
I think that clamping to the strip that goes between the stanchion and the windshield frame would work but with the side screens on that may not work.
David
M_Pied_Lourd
Hi David,
There is a mod to use a Harley Davidson mirror (I think) in one of the windscreen stantion locating bolt locations. If this is something that might interest you, I think I saw it on the TR Register Australia or New Zealand website. Others here may know about it as well...
Cheers,
Tush
macilona
Hello......I purchased the HD mirrors on ebay....item captioned Harley Davidson universal 4 inch chrome mirror....you need both left and right because the stem is angled for each side. Cost about $20 each. They are mounted in the screw holes of the windshield. Hopefully the attached photo will be there for illustration!
TR3driver
Great Pumpkin - R.I.P
Might be worth mentioning that this trick only works for later cars, with bolts holding the stanchions to the scuttle. Won't work so well on earlier cars (like mine) that use Dzus buttons in that location.
But I get along fine with the convex wing mirrors. They're a PITA to keep adjusted, as people keep bumping into them in parking lots (and I do myself sometimes, when working under the hood). But properly adjusted, and combined with the center mirror, IMO they work quite well. One of the things I really like is when pulling out from a parking space with a big SUV parked behind me, I can pull up until just the mirror peeks around the SUV, rather than having to pull out far enough for a side mirror to get a view of oncoming traffic.
martx-5
I have convex wing mirrors on both sides. That helps. But, I also added a mirror screwed into the stanchion where the rear bolt goes. I used a convex wing mirror from the right side, and modified the length of the stud. The original stud is the correct size (5/16"-24 IIRC), but too short. Since it was part of the casting, I just cut it off, drilled and tapped a hole and screwed in a longer stud. With a couple of flat washers for spacers, the mirror just screws right on in place to the stanchion screw.
Edit: I tried using a clamp-on mirror on that strip. It lasted about 6 miles before it fell off and the car behind me ran over it! :sick: And, yes it will interfere with the side curtains.
6TTR3A
I'm fortunate to have an original set of Lucas convex wing mirrors.
The original ones aren't quite as convex as the aftermarket ones,
so there is a better field of vision.
I supplemented that by converting the scuttle mounted interior
rear-view one to a convex one as well. Went to a junk yard, got one
of the modern passenger side exterior rear-view ones (the one
with the little note etched in), took it to glass/mirror shop & had them
cut it to fit in my TR3A mirror. Between the three I have virtually no
blind spots.
Frank
ckeithjordan
I didn't like the wing mirrors, they were "too far away" to see properly. I did add a clamp-on mirror bought from Vintage Car Parts in England at: https://www.vintagecarparts.co.uk/categories/vintage-car-parts-accessories-mirror-exterior
It's stayed on so far, using set screws to clamp the windshield side tenon (it does vibrate, though). I have not tried the side curtains yet. Attached is a picture of the mirror and on my car. A better mirror is in the other photo of the TR2, but that would require drilling/tapping into the Dzus or bolting through the stanchion mount.
DavidApp
Well there is one of my problems. My wing mirror is flat not convex. So I need to find a convex one to start with.
Randall
I do notice that it is easy to move them as you walk past in the garage. If you leave them lose enough to adjust and they move easily.
Art
That was what I was afraid of with the clamp on type.
David
DavidApp
Hello Keith
Thank you.
How long is the stem? It looks like the mirror may stick out a bit and easily get bumped by clumsy pedestrians in parking lots. (or Owners in garages)
David
Graham H
Hello David,
The side mirrors are still available from the tr-register.com.au look in the for sale section,
as you can see fitted to my car I can't remember how much I paid but they fit well and don't get in the way of the side screen
ckeithjordan
David,
I can’t tell you at the moment as my car is at Macy’s Garage getting a drive-train rebuild. I should have it back in a couple of weeks and can check then. I can’t say I really had a problem bumping it.
ckeithjordan
Got_All_4
Cant tell you how many times I took a lot of time to adjust the mirrors just perfect just to get out of the car the next time and smack it with my wrist walking buy. In a car show you might as well plan on taking time before you go home to adjust your mirrors. Here is how I got ride of a lease 50% or more of the problem with original mounted mirrors. All i did was just slightly turn them in towards the bonnet. If you were standing behind the driver mirror (US cars) loosen up the screws and turn it counter clockwise which puts it more in a upright position instead of hanging past the fender. Too far and the bonnet will will hit it when raised. Course turn it clock wise on the passenger side.
Now if I'd seen this tread before I restored my car the 2nd time I would have filled in the fender holes and did the windshield post mount. doesn't look as cool but functionality is what I'd be looking for.
PeterK
Yes, I have Tex "spring back" mirrors on my wings. They have a spring mounted stem so if I knock it, it springs back into position. Need to keep the head tightened after it is adjusted to keep that from moving if I hit it too hard. But they do work and spring back nicely.
K TR2/3/3A Side view mirrors again Triumph 8
K TR2/3/3A TR3's without the fender mirrors........... Triumph 6
S Bakerlite Wing Mirrors Other British Cars 2
maxwedge5281 one more time.....mirrors! Austin Healey 14
mrv8q TR2/3/3A Side view mirrors Triumph 7
T Post-War Other Door mirrors Triumph 8
I General TR Source for glass mirrors Triumph 5
J Please identify these bullet mirrors - Need base and gasket Austin Healey 5
Tinkerman TR2/3/3A Bullet Mirrors on TR 3's Triumph 7
maxwedge5281 1963 bj7 carpet install and mirrors Austin Healey 3
T TR2/3/3A Mirrors at night. Triumph 3
drooartz Question on Bugeye Harley mirrors Spridgets 28
B BT-7 Rear View Mirrors Austin Healey 5
Stinger TR4/4A TR4A Dealer Installed Mirrors Triumph 5
H wing mirrors Austin Healey 11
M Mirrors '56 Austin Healey 100 4 Austin Healey 23
I Stock Bugeye Mirrors. Spridgets 11
S Preferred Side Mirrors Austin Healey 35
T Base for bullet style mirrors Triumph 16
T External Mirrors - advice requested Austin Healey 10
RickB Side mirrors for early cars? Spridgets 32
mountainman TR2/3/3A TR3 Fender Mirrors Triumph 25
L Two screw or single bolt side view mirrors? Austin Healey 8
Johnny AH convertible rear view mirrors Austin Healey 9
H auxillary rear view mirrors Austin Healey 4
E old wing mirrors Triumph 5
tinman58 Wing Mirrors Triumph 11
Brosky Baby Vitaloni mirrors/new paint/tires and Konigs Triumph 39
Brosky Final panel fitting & new mirrors Triumph 38
I Where do I get one of these mirrors? Spridgets 20
bighealeysource Where to mount fender mirrors on BT7 Austin Healey 26
3 TR6 tr6 fender mirrors Triumph 4
bcbennett OEM side mirrors still available? Triumph 10
JPSmit Parts I need - Mirrors Spridgets 11
Raymond Fender Mirrors MG 27
R Body Rear View Mirrors Austin Healey 3
SilentUnicorn Fiat mirrors. . ya Gotta e Kidding.......right? Other Cars 9
T TR4/4A 4A Mirrors Triumph 1
M Non body mounted mirrors Austin Healey 17
19_again self dimming mirrors MG 15
swift6 Mirror question, Tek Mirrors... Triumph 3
C MGB 1979 MGB door mirrors MG 4
Bret New Titan truck; What no power mirrors? Other Cars 1
healeyneil mirrors Austin Healey 0
ArtQ Side View mirrors Austin Healey 4
M TR2/3/3A TR3 mirrors Triumph 12
W Fender Mirrors - install or plug? Triumph 19
G Side View Mirrors Austin Healey 18
A Mounting Fender Mirrors MG 4
Kim de B Location of side mirrors MG 16
