TR2/3/3A Exhaust Header Fitment
JFS
Bronze
My new header mounting flange measures 3/16" thinner than my Weber Canon intake manifold mounting flange. The stud mounted clamp that secures the two is cast with two ears each with a protruding contact button. Do I compensate the difference by grinding down the higher ear or by shimming the lower ear? Or does it matter? I don't have the old header I am replacing and don't remember how that one mounted. My clamps have not been modified and I don't remember shimming the old header.
TR3driver
Great Pumpkin - R.I.P
The headers I've used had little tabs welded to them, for each of the clamps to rest on.
M_Pied_Lourd
I had to put a little bead of weld on mine.
Cheers
Tush
JFS
JFS
Bronze
A bead of weld it will be, Tush
Another problem: The collector does not clear a front brake line screwed into the 5 way brake line connector. Are the connector's line ports the same as that for the brake light switch? If so, interchanging the brake switch with the front brake line would provide adequate clearance since I don't use that switch.
M_Pied_Lourd
Do you happen to have a picture of your switch that you could post? I had no issues with interference here.
Cheers,
Tush
JFS
JFS
Bronze
My previous header was also the long runner type, but it hugged the block more closely.
charleyf
On my cars the outlet on the 5 way pointing toward the exhaust is for the switch. The outlet pointing forward is used for the brake line.
JFS
JFS
Bronze
The 5 way connector illustrated on the Moss site seems to show all outlets as identical, so I should be able to interchange the switch and brake line to provide the necessary clearance for my header. Hope changing the line's shape doesn't prove difficult.
martx-5
All the outlets are NOT IDENTICAL..., there are two different type outlets. See picture below.
Edit: One picture shows an outlet without a seat...It's there, it was just hard to see on my fitting. I posted it before I could correct it, and I couldn't figure out how to remove the wrong pic, so they are both there.
JFS
JFS
Bronze
Thanks, Art! Your pics show what I need to know. New plan is to disconnect the lines, rotate the 5 way so the switch points to the collector and connect the two brake lines to the appropriate seated outlets.
TR3driver
You might want to use a plug in place of the switch, for extra clearance and less exhaust heat into the brake fluid.
JFS
JFS
Bronze
Good idea. Now I’ll have to see whether to reshape that curved line or cut it off and reflare it.
TR3driver
If it were me, I'd replace it with a new one. Those old lines can sometimes get brittle with age, and it only takes a tiny crack on the inside to cause it to eventually fail.
The "Cunifer" alloy was developed specifically for use in brake lines. Very corrosion resistant, very easy to work with. Moss has sets (from Automec in the UK) that are already flared and have suitable nuts. Or you can buy parts to roll your own from many sources. If you do, be sure to get the Girling pattern nuts with the extended (unthreaded) tip, the American ones don't always seal properly. https://store.fedhillusa.com/britishgirling.aspx
JFS
JFS
Bronze
Thanks again, Randall, for another good suggestion! Moss price of less than $30 for a new pipe with fittings is the way for me to go.
CARSINC Please Identify this Exhaust Header Spridgets 2
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
M Muffler Options with Exhaust Header Spridgets 1
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
Boggsy64 MGB Three port exhaust header? MG 6
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
L Tubular header to ss exhaust pipe Spridgets 12
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
T Need exhaust header advice/source for Amos Triumph 49
PAUL161 Hap-- Exhaust manifold/header paint? MG 2
RJS Header/ Exhaust Manifold Wrap Triumph 2
D Exhaust manifold or header Austin Healey 2
M Crack in exhaust header... Spridgets 14
E TR6 TR6 "Tuned" Exhaust Header Triumph 8
YankeeTR Rare exhaust header? Triumph 7
healeyboz 1275 Header and exhaust Spridgets 25
B Exhaust header installation Spridgets 7
D exhaust header MG 5
jlaird Question - Exhaust header Spridgets 3
PeterK Exhaust header wrap Triumph 3
VelodromeRacer Exhaust header Austin Healey 7
D exhaust header wrap British Motor Corp 13
Alan_Myers TR2/3/3A Comments - TR3/4 Falcon S/S header & sport exhaust Triumph 1
Simon TR4a Exhaust header/manifold Triumph 8
S Exhaust header Austin Healey 9
J TR4/4A Exhaust a tad too loud... Triumph 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
