Valve Cover Gasket
vette
What is the best valve cover gasket for the 6 cylinder Healey? And where can I get one?
Thanks for the help. Dave C.
dougie
I used this one for a few years with success on my racer. https://mossmotors.com/austin-heale...-valve-cover-gaskets-by-gasket-innovations-12 After I rebuilt the motor last year I put a new one on and had some leaking, so I went back to the old school cork unit. I do use gasket sealer https://www.walmart.com/ip/Permatex...F26pToYEPlfXdP4waaXOyhuImlU4fgdQaAmhAEALw_wcB
to mount both the silicone and cork gasket to the cover and only use a little oil on the head side to create a solid seal.
John Turney
I put the silicone gasket from Moss this last time. It seems to be working fine. Need to follow the directions, though.
vette
vette
Thanks Dougie. I also have the blue silicone gasket on my '70 Vette valve covers and yes they leak a little. Not really happy with them. I have been running the cork gasket on the Healey for about 10 years. I also use the black RTV with the cork. The Healey valve cover gasket has weeped a little near the front right corner. I am going to adjust valves soon and was hoping to find a superior gasket this time around. Maybe I already have the superior gasket in the cork.
Thanks for the input. Dave C.
vette
vette
Thanks John. I'm curious, what directions need to be followed with the silicone gasket?
steveg
I've twice tried the silicone gaskets with my Ray Juncal valve cover - without success. Maybe they work better on the stock valve covers due to the lip around the periphery.
What's worked for me is to glue the cork gasket to the valve cover with weatherstrip adhesive, then weight it overnight on a plate glass tabletop so the bottom is flat. Install with a light coat of hylomar between the gasket and head surface.
RAC68
Hi All,
Dave, I made the same request a number of years back and was referenced to Gasket Innovations. Back then, I had been using cork gaskets and had never gotten the knack down for getting an oil-tight seal. After receiving and installing the silicone gaskets, without applying anything additional, I found all leaks eliminated (for the first time). I must admit, however, since my (initial) success I have been quite hesitant of removing the cover to adjust my valves (with tapping getting louder) as I don't know how they will fare when reapplied.
Has the Gasket Innovations gasket re-sealed well after some years of being in-place and is there a procedure?
Ray(64BJ8P1)
John Turney
There are two gasket styles, one for stock covers, one for aftermarket (alloy) covers. Use the correct one. Seal to the cover with red RTV, and set the cover, gasket down, on a FLAT surface until the RTV cures. Then install.
Michael Oritt
Ray:
You said "I have been quite hesitant of removing the cover to adjust my valves (with tapping getting louder) as I don't know how they will fare when reapplied."
Solution 1--Remove valve cover, adjust valves and if necessary get a new gasket.
Solution 2--Remove hearing aids and continue to ignore the issue.
fwtexasbj8
I have had the Moss silicone gasket, installed like John Turney says, for several years. I have had the cover off several times and never any sealing problems.
RAC68
Michael,
OK, no hearing aid but radio is on loud and valve tapping stopped. Engine valve cove remains oil tight. Thank you.
You must be a master mechanic.
Ray(64BJ8P1)
Keoke
Me TOO no problem.
RAC68
Dougie,
Sorry for he delay but I had to comment on how fabulous your engine/compartment looks in the posted picture. All I can say is WOW!!!!
Ray(64BJ8P1)
vette
vette
I guess it depends what ya got for valve covers.
Before and After:
RAC68
Hi All,
Removed my valve cover and adjusted the valves. Prior to setting the valves, I remembered something Randy Forbes posted a while back on setting valves. Randy indicated that he set the valves cold for consistency and, since the intake valves gain some cooling when Open, due of the passage of the air/fuel, he set the intakes to 0.012". However, since the exhaust gain any cooling Closed, when in contact with the valve seats, he set the exhausts to 0.015" to allow a small amount of extra time.
His logic seemed proper to me and have set my intakes at the high side of 0.012" cold and my exhausts to 0.015" cold. Also interesting, 0.015" cold translates to 0.012" hot. Has anyone tried this exhaust valve setting?
Although I have reinstalled my valve cover with the Gasket Innovations seal still in place, I have not yet started the engine but expect to have no issues when I do.
Ray(64BJ8P1)
pkmh
Ray,
Very interesting concept. The idea of having two different valve settings sounds interesting, though at the risk of sounding like an idiot on the issue, I am going to try answering (or bring up) with two more questions that come to my mind.
A. What happens to the "balance" of the two opposites--intake and exhaust? Like breathing in and out.
B. What can be said for gyration issues on the cam? Minuscule, probably, especially at low rpms. Any concerns at higher rpm's??
Again, not sure if my questions even make any sense. Just throwing it out there. Very curious about this approach!
I, myself for now, am leaving my valve settings all the same (.012", cold), as the good book says.
Paul
pkmh
I did some further investigation on this issue of creating two different valve settings.
After asking some folks I know who seem to have a better understanding of this sort of thing than I, they seem to suggest by creating a larger than specified valve setting (i.e.-exhaust), there will still be a tendency for more banging of the tappets and cam, leading to more wear over time. I understand there will be an advantage to creating a more firm seating of the exhaust valves, but that's all I can mustard at the moment.
I drive my Healey as an old fogy so for me, I am leaving my settings all the same which is 0.012" at cold setting, although it does specify in the Austin Healey Workshop Manual it can be set at .015" (cold) for "competition."
What more or truth can be said about the above?
Paul
vette
vette
Paul, I think your right on the money. But also know that many hi po cams (especially in small block V8 engines) have different specifications for the intakes and the exhaust valves. This is used to not only develop hp but to develop torque and at what rpms it comes in at. In todays world many of the cams are hydraulic so there effectively is no gap to pound the valve gear. But solid lifter cams are still used. Many small block chevy solid lifter settings were right around .018. The racers would play with the gaps to change the valve timing to see if they could pull more power out of an engine. Racers primary interest is to see how fast they can make it not how long it will last. If its your street car, keep it stock.
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
6inline Valve cover gasket woes Austin Healey 11
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
K TR4/4A The "silicone type" valve cover gasket? Triumph 3
mgedit TR2/3/3A Justin Wagner Silicone Valve Cover Gasket Triumph 2
Gliderman8 TR6 Silicone valve cover gasket Triumph 4
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
M Preferred valve cover gasket Triumph 12
Westfield_XI Best valve cover gasket? Spridgets 22
V Valve cover gasket & sealer??? Spridgets 11
bighealeysource Replacing cork gasket on BJ8 valve cover Austin Healey 3
T Justin Wagner's Silicon Valve Cover Gasket Triumph 7
T Silicon valve cover gasket Triumph 17
angelfj1 Valve Cover Gasket - Too Thin? Triumph 15
Ed_K Valve cover gasket choices ? Austin Healey 5
T Valve cover gasket - sealant needed? Triumph 7
Brosky Wagner's Silicone Valve Cover Gasket Triumph 8
B Upgrading valve cover - gasket sealant question Triumph 15
roofman TR6 TR6 silicone valve cover gasket Triumph 9
roofman TR6 TR6 silicone valve cover gasket Triumph 2
Brosky New Silicone Valve Cover gasket arrived Triumph 26
S Leaky valve cover gasket Triumph 5
B Advice on installing a cork valve cover gasket.... Spridgets 8
P Valve Cover Gasket Austin Healey 5
mrv8q TR2/3/3A tr3 valve cover gasket Triumph 5
B TR6 TR6 Valve Cover Gasket Triumph 5
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
S Price check on TR3A valve cover Triumph Classifieds 0
D TR6 Valve cover paint Triumph 5
B TR4/4A TR3 valve cover on TR4A Triumph 4
Ripper01 For Sale TR-6 Valve Cover/ Cap Triumph Classifieds 0
K TR2/3/3A Plugged valve cover breather Cap? Triumph 4
K TR2/3/3A Valve cover breather cap? Triumph 5
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
C How best to restore red script on valve cover? Austin Healey 7
Northcoaster TR4/4A Lost info on person interested in my valve cover Triumph 1
AH67 Wanted WANTED: Valve cover 6 Cylinder Healey Austin Healey Classifieds 2
AH67 Wanted WANTED: Valve cover 6 Cylinder Healey Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
NutmegCT T-Series Loose valve cover oil cap MG 4
D valve cover Austin Healey 7
wangdango 6-cylinder alloy valve cover Austin Healey 53
wangdango 3000 valve cover bolts/chrome/ss? Austin Healey 4
HealeyRick Rare Barn Find Valve Cover Racer Austin Healey 9
glemon General TR Simple Improvement Valve Cover Washers Triumph 2
M TR2/3/3A Valve cover question Triumph 6
