Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Choke Cable Problem
  1. #1
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    222
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Choke Cable Problem
    Choke cable will not retract the jets. I can move the assembly and retract the jets by hand from under the hood but can't pull the choke cable out far enough to retract the jets from inside the car. I've lubed up everything to no effect. Any hints?
  2. #2
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    5,067
    Thanks Thanks Given
    4
    19
    Thanked in
    Re: Choke Cable Problem
    Remove the jets and polish the outer surfaces to a mirror finish. If still too hard then double check the linkages and cable routing. If still too hard, check the run of the cable for crimps, tight bends, or too-tight mounting clamps. Finally...if still not working, remove the entire cable assembly and disassemble it, taking care not to loose the locking key. Fully clean the inner cable with fine wire and reassemble. By step four above you will have a choke that works like cutting cheese!
    John
    1955 TR2
  3. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,899
    Thanks Thanks Given
    3
    68
    Thanked in
    +1 on polish the jets. All John's other suggestions are good, too, but dull jets seems to be the most common problem. Best I can make out, the originals were supplied slick, but modern replacements are supplied with a more matte surface that really drags against the glands. Any fine abrasive will do to polish them, I've even used white toothpaste. Obviously clean away all traces of whatever you use before reinstalling.
    Note that the linkage goes together in a non-obvious way. The two clevises on the link between the carbs don't straddle the arms, but instead hang out on one side. Seems crazy, but does work better that way.
    The joints all have to have a small amount of slop in them. If by chance you (or the DPO) has substituted bolts for any of the pins, they have to be left loose.
    Choke cable needs to be the type with a stranded inner core.
    If all else fails, disassemble the jet housings and check that the cup washers are turned the right way (the cupped side goes towards the seal). I would also replace the springs if I didn't know their history, since it's not uncommon to find that someone has stretched them trying to get the glands to seal.
    Same goes for the return springs; the next step after stretching the gland springs is to cut the return springs shorter to get the jets to return reliably
    Randall
  4. #4
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    10,715
    Blog Entries
    1
    Thanks Thanks Given
    37
    75
    Thanked in
    Does the cable pull smoothly and easily when it's *not* connected to the carb mechanism?
    Tom M.
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  5. #5
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    222
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by NutmegCT View Post
    Tom M.
    Yes, The cable is new as are the jets and all the bits in the bottom of the carbs. The assembly moves without restriction until the jets must move and then no matter how hard I pull on the knob, I'm not able to move the jets. I didn't have this problem before I rebuilt the carbs and replaced the cable. I also didn't realize the clevises are outboard of the arms.
  6. #6
    Jedi Hopeful Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    163
    Thanks Thanks Given
    2
    2
    Thanked in
    Can you take a photo of the cable connections when you have the choke pulled all the way out so we can see where its at
    Graham
    [SIGPIC][/SIGPIC]
  7. #7
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    222
    Thanks Thanks Given
    Thanked in
    The problem is that I can only pull the choke out about 3/4" but it won't stay. The springs will retract the cable and the knob returns all the way to the dash.
  8. #8
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    10,715
    Blog Entries
    1
    Thanks Thanks Given
    37
    75
    Thanked in
    A focused, close up photo of the connections will help.
    Also, disconnect one of the return springs, and see if the system pulls the jets down (and back up) properly. After I polished the jets as Randall mentions, I found that only one spring was sufficient to pull both the jets back up fully.
  9. #9
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,187
    Thanks Thanks Given
    10
    23
    Thanked in
    I had a problem with the choke cable not retracting the jets. It turned out to be that the cable outer case was sliding into the part that is secured to the dash. The crimp was not securing the outer part of the cable. It was also a brand new cable all be it bought in 1998 but still in the bag.
    As I pulled the choke out I noticed the loop in the cable under the dash would straighten out then return to a loop if I pushed the choke back in.
    I crimped a steel cable thimble ob the outer sleeve to stop the outer sliding into the dash part.
    Works fine now.
    David
    TR3A TS75524L
  10. #10
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,899
    Thanks Thanks Given
    3
    68
    Thanked in
    Quote Originally Posted by frankfast View Post
    That would be a separate problem. The locking mechanism in your choke cable must be worn out (or missing) as well as whatever is keeping you from pulling it out farther.
    IIRC, the factory version has a piece of brass shaped kind of like a Woodruff key. There is a spring around the outside that holds it against the shank, which should have notches in it.
    But there are others. With some of them (like the aftermarket cable I use), you turn the knob to lock the shaft in place.
    Randall
  11. #11
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,044
    Thanks Thanks Given
    16
    Thanked in
    On the original chokes the knob turns to the right to release and when pulled straight it clicks. The travel on the cable is small. Just look at how much cable is exposed before the inner cable bottoms out on the holding arm. I am thinking you bottoming out your choke travel before the choke pulls down the jets. Try putting some preload on the cable and some preload on the lower arms to cheat some more travel out of the cable by taking up the slop.
    steve
  12. #12
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    222
    Thanks Thanks Given
    Thanked in
    I've ordered an original style cable from Moss since I've frayed the end of the replacement cable I was using. Besides, the replacement cable did not have stops and a release. You had to hold it out while pressing the stater. A real pain especially since it did not retract the jets. When I get the new cable I'll try to set up the whole thing the way it was meant to work.
  13. #13
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    222
    Thanks Thanks Given
    Thanked in
    The pin on the rear clevis is not long enough to allow the the clevis to straddle the arm. There is no problem with front pin. Do they make a longer pin for the rear?
  14. #14
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,899
    Thanks Thanks Given
    3
    68
    Thanked in
    Weird. All the vendors seem to have the original part number 108326 cross-referenced to a shorter pin. Revington shows it crossed to a 9/16" pin, TRF shows 31/32". But the official cross-reference I have is silent (meaning they didn't know of one).
    Anyway, if all else fails, you can get a box of 11/16" pins from McMaster Carr. Your choice of plain steel
    https://www.mcmaster.com/98306a103
    zinc plate
    https://www.mcmaster.com/97245a218
    or stainless
    https://www.mcmaster.com/92390a109
    Randall
  15. #15
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    222
    Thanks Thanks Given
    Thanked in
    Thank you. On order.
  16. #16
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,044
    Thanks Thanks Given
    16
    Thanked in
    Just in case you did not know, I put the pin on the cable first and the have the brass arms pointing straight down and the push arms back a bit and then the pin through the hole in the arm. That way I do not have to fiddle with cable and all-- at once. This puts a little preload on the arms too. I hook up the out sheath last. The picture of just the pin and arm is 180 out, so after the pin is clamped; I roll the pin over and, put it in from the fender side.
    steve
  17. #17
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    222
    Thanks Thanks Given
    Thanked in
    Polishing the jets with a household brass cleaner did the trick. I think the replacement seals offered by Moss instead of the cork seals may be more restrictive. The action on the choke is still not as free as I would like but it does work now. The car starts cold without a problem. Thanks for all the help.
  18. #18
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,899
    Thanks Thanks Given
    3
    68
    Thanked in
    Yeah, it's always a little hard to pull, in my experience. I kind of prop my ring finger on the dash, and twist my wrist to pull the knob out.
    Didn't particularly notice any difference when switching from cork to O-rings, but YMMV.
    Randall
  19. #19
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,044
    Thanks Thanks Given
    16
    Thanked in
    I can easily pull mine out with one hand, but yes there is resistance from those big return springs. Does your choke click and lock ---then release by turning to the right?
  20. #20
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    222
    Thanks Thanks Given
    Thanked in
    No. I bought an original style cable from Moss but it doesn't lock in the choke position and wants to return because of the springs, so you have to keep it pulled while pressing the starter. It's a two hand operation. Maybe I'm not able to pull it out far enough for it to lock. I remember the first choke cable I had and it did work like yours. It locked and then released by turning it. Don't know why the cable sold by Moss shouldn't work that way. It wasn't cheap. I had a cheaper cable before this one and it worked the same as this one does but didn't have the thingy (???) that held the original knob. It came with its own knob without writing on it.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
