Spitfire Clutch Issues
FlyingCat
To get up to speed, I have a 1980 Federal Spitfire, no overdrive. When I first got my car, the clutch master cylinder was dry, but there was fluid in the line. So I filled the cylinder, and today I bled the line. Before, it felt like the clutch was really doing nothing. I could shift the gears whether or not I pushed the clutch in. After bleeding the clutch, I can still shift the gears without engaging the clutch, but now the clutch pedal doesn't move at all. Any ideas?
STeve 1958
How long did this car sit unmoved. It sounds like a long time if the clutch cylinder was dry. The clutch may be stuck in the open position which would allow you to shift gears.
Usually clutches stick in the engaged position so you can't disengage it. But your sounds like it is stuck disengaged. You may have to open it up.
DavidApp
Presume the car is not moving when you are shifting gears?
Could be the MC is frozen up and not returning or something in the clutch is frozen up.
David
Andrew Mace
You may have multiple problems here! First, I would just either rebuild or replace both clutch master and slave cylinders. Once that's done, you might still find that the clutch driven disc is stuck (happens somewhat frequently on these cars when they sit for longish periods) and may require "creative" ways of freeing it up. You'll know this is the case once the hydraulics are ok but you get nothing but grinding gears when the engine is running and you try for a gear!
FlyingCat
FlyingCat
It hasn't been driven in at least 25 years. I fear "opening it up," but only because I haven't done that sort of thing before. But then, I've never done any of this before. Thanks!
FlyingCat
FlyingCat
I don't think this car has moved on its own in over 25 years. I have a new slave cylinder, but I haven't put it on yet. Sounds like I need a master cylinder, too. Sounds like a place to start. Thanks!
FlyingCat
FlyingCat
Well, then. I have my next project. Just when I thought I was getting down to being able to actually drive it. Oh, well. It keeps me out of trouble.
dklawson
As Andy said, bad stuff can happen when the car sits for long periods of time. When we brought our GT6 home it had been sitting for 15+ years. The brake and clutch masters were empty except for crystalline white/green crusty growths in the reservoir. I was able to get the masters apart but the bores were ruined. I bought generic aftermarket masters, slaves, and wheel cylinders. I did flush out the hard lines but replaced the rubber flex lines.
It was certainly worth it to replace everything. I knew everything was new. Confidence in your brakes is imperative and the clutch is certainly easy to do at the same time. If you opt to replace the parts listed above, that only leaves you the brake calipers as a component to "open up" and rebuild. Everything else will be new.
Andrew Mace
I have what's left of a Mk2 Spitfire that sat outside under a tarp for maybe 10 years before I got it. It's been in the barn now for well over 25 years. A couple years back, I took the master cylinders off the firewall simply out of curiosity, only to discover that there was still fluid present and the bores and other bits were in excellent shape. Shocked the living heck out of me, 'cause -- as Doug notes -- "bad stuff can happen when the car sits for long periods of time"! I'd have expected much worse, and 95% of the time, what Doug found is what I found!
I mention this mostly because, for whatever reason, both of the cylinders were the now-rare "tall reservoir" style. They have been cleaned up and rebuilt for use in my cars at some point in the near future. :smile:
G 79 Midget Clutch issues Spridgets 9
R TR6 Clutch issues Triumph 7
Lukens TR2/3/3A TR3 clutch issues Triumph 14
J Datsun 5 speed swap clutch issues Austin Healey 3
T TR6 TR-6 Clutch disengagement issues, recurring or solved ? Triumph 6
bugedd Rivergate clutch issues, need help Spridgets 9
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
K Clutch issues Austin Healey 2
T Clutch Issues continue. FYI Triumph 4
britndablood Clutch Issues Austin Healey 8
pipercollins Spitfire Spit 1500 Clutch Issues Triumph 24
T Having clutch issues? Triumph 7
Moose33 T-Series clutch issues MG 11
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
