Air Deflector Assembly
BT7Doug
I have a '62 3000 tri carb BT7 which had an overheating issue last summer. The air temperature was 32C or 90F and the radiator temp at a highway speed of 65 started climbing towards 200F. Once in town the temperature came back to 190. The car has a new 160F thermostat and I just had the radiator checked and flushed with nothing found. At cooler outside air temperatures, the radiator temperature seldom exceeds 180F. I found an old thread on this forum which talked about the installation of an air deflector assembly which is completely missing on my car and I am wondering if this is the source of my heating problem. The first question is "do I need the air deflector assembly?" and the second is "how difficult is it to install?" The pictures on that early thread show the attachment at the top but the bottom is a bit vague. It appears to attach to a support bracket for the grill but there is little room back there especially once that deflector panel is in place. Also I have the radiator out at the moment which would aid the installation of the air deflector but that would make installing the radiator more difficult. Which should come first. Any and all tips appreciated
steveg
Definitely buy the air deflector assembly. Moss catalog section: "Cooling 100-6, 3000", item 20.
If you don't have them, also buy the Splash Panel Set with Stays, Moss section: "Inner Body Panels, 100-6, 3000", items 10 & 15.
You need these for cooling to keep air from recirculating forward.
When you get these items, if you need pictures of installation or other tips, I'll post pictures of my installation.
I like to use 1/4-20 u-nuts on the top holes, so get a couple of those, too. Otherwise bolting them through the shroud in front of the radiator with an assistant holding the nuts from below is a real bear. The lower stuff, crossbar, stays and the splash shields are more straightforward. Work is done from below and behind the grille.
B
BT7Doug
Thank you Steve, I will order the parts and get back to you when they arrive.
Doug Cavill
Gabriola Island, BC
Crankshaft TR2/3/3A Air deflector order of assembly Triumph 5
J Moss OEM AIR DEFLECTOR ASSEMBLY Does it do anything? Austin Healey 9
H Air Deflector Assembly Hardware Help Request Austin Healey 2
55modified need help with custom air deflector for BN1 Austin Healey 12
R Air Intake Deflector - Radiator Austin Healey 8
K Radiator air deflector Austin Healey 6
H Rad intake air deflector plates Austin Healey 6
af3683 TR2/3/3A Radiator Air Deflector / Shroud Triumph 31
I TR6 radiator air deflector recommendations Triumph 10
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
Stinger TR4/4A TR4A Air Deflector Duct Triumph 1
E Air Deflector Color Austin Healey 13
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
