TR2/3/3A Hood oilcanning
joshsibille
I'm still in the process of taking my 61 TR3A down to bare metal. I started on the hood this weekend. As I removed the old paint and some bondo, I noticed the center of the hood has a some minor oil can popping. It isn't much and the metal is actually pretty straight. Before I start heating and shrinking I wanted to check to see if there is a normal amount of popping to be expected on such a large panel, or is this probably something I can work out. Thanks.
sp53
I can make mine oil can if I try. The hood does have some forming to help with that along the the sides of the center plus there is a piece of felt or I think horse hair about 3/16 think and 3 inches wide that runs the length of the hood between the last brace and the main sheet metal. The felt piece I believe is for anti-rattle, but should help with oil canning also.
steve
CJD
Of course, like Steve says, any flattish panel, like the bonnet and the boot lid, will oil can if you push hard enough. Even more...once it has been canned once, it will be easier every subsequent time. I had friends in high school that thought it was funny to invert every car's hood by jumping on them right in the middle. After that they would all oil can!
My TR2 bonnet was straight and clean, but had one spot that oil canned easily. That one spot started almost 2 straight weeks of work shrinking. Looking back, I wish I had some of Lionel's tools, so I could shrink metal while it is cold. Heating to shrink fixes one spot, but often creates more problem areas. It works, but can take a lot of work.
So, just saying...if you decide to fix it, plan on a lot of time to get it right!?!
TR3driver
Great Pumpkin - R.I.P
Somewhere, I think I've got a service note about adding more packing between the brace and bonnet, to reduce noise. So I assume many of them would vibrate, if not outright oil-can, when new.
A friend of mine came up with another slight mod that seems to help : he replaced the two fender bolts at the back with rubber buffers like the ones at the front. Adjusted so they just barely lift the bonnet against the hinge pins, they help keep it from vibrating at idle. Otherwise, it tends to rattle against the clearance in the pins.
DavidApp
Thank you Randall
I may have to get some rubber buffers on my next order. Seems like an easy solution to hood rattling. May not get concourse points.
David
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
S TR2/3/3A Hood Stick Cover Triumph 3
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
B BJ8 Hood Bow and Seal Austin Healey 5
B Hood Woodwork Austin Healey 2
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Stronger hood release? Triumph 4
MGTF1250Dave T-Series Hood Sticks MG 4
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
S Forward opening hood / bonnet Spridgets 10
D BJ7 Hood frame mounting plate Austin Healey 7
S TR2/3/3A Tr2 hood Triumph 8
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
steveg TR6 Hood release pictures needed Triumph 22
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
S Pre-War my hood problem got worse! Triumph 6
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
G Wanted WTB TR3 Hood Hardware Triumph Classifieds 0
B TR6 TR6 Hood Release Cable Triumph 7
A TR2/3/3A how do i fix this hood line? Triumph 5
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
L TR2/3/3A Hood / bonnet plinths Triumph 12
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
anarchy99 Bonnet / hood fit question... Spridgets 2
anarchy99 Wanted WTB: 64-66 sprite hood in decent shape. Spridgets Classified 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
L 100/6 Hood parts Austin Healey 11
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
G Fixings for liner assembly hood comparment -BJ7 Austin Healey 7
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
D TR2/3/3A Under hood Photos Triumph 7
4tecdog Modify frog hood frame Spridgets 12
S TR2/3/3A original tr3 hood wrench Triumph 15
