Help to identify parts - BT7
Novamonte
I received some parts with my Tricarb. I have identified most of them, but not those on the attached pictures. If ayone knows what they are I would be greatful to be enlightened.
I don't think either of those--esp. the eye bolts--go on a Healey (at least, there aren't any of these on my BN2 and BJ8). The second one could be a brake cylinder piston, but not for a Healey.
Deleted member 21878
Don't remember seeing either of those on my Tri-carb. but there were some things like the gearbox that had already been rebuilt so i did not go in to them.
BBH
The second picture looks like an overdrive accumulator piston with an 'O' ring conversion - AH Spares part OVD202A
The eye bolts in the first pic, I think are part of the seat belt anchorage ( I have them in a box of bits from my tricarb, yet to be fitted, but can't see them in the parts list so far!!!)
N
Novamonte
Thanks! That can well be correct, the OD was rebuilt about a year before I purchased the car so the piston may have been replaced.
The second picture looks like an overdrive accumulator piston with an 'O' ring conversion - AH Spares part OVD202A ...
I think we have a winner, though it's curious that it wasn't installed since the O-ring is supposed to be superior to the metal-ringed type (at least according to AHS). The DWR uprated accumulator still uses the steel rings. The activating pistons went from steel rings to O-rings in later cars.
Healey Nut
Yes its an upgraded OD piston .
N
Novamonte
I believe that it was replaced for some reason (hopefully with another upgraded piston) when the OD was rebuilt. The one I received has been in a car, it can be seen on the top of the piston (not visible in pic though).
Any ideas on the bracket in the same picture as the eye bolts?
AngliaGT Help Me Identify These Parts Jaguar 6
P please help identify these parts Austin Healey 8
P Please help identify this tourer Spotted 13
apbos Help Identify this car chassis Racing 20
N Please help identify this car Spotted 22
C Help me identify this Heater Box, Please Austin Healey 7
C Help me identify the engine Austin Healey 16
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
N Can you help identify these shock absorbers? Triumph 6
W help identify a wire connection Triumph 5
E Help Identify This Part..... Spotted 13
M BN2 Please help me identify this bolt Austin Healey 6
angelfj1 TR2/3/3A TR3A - help to identify this hole. Triumph 11
QuickSilver Help Identify This B MG 22
A Spitfire luggage rack for a MK3 spit [help] identify Triumph 8
vping Help Identify this Wheel MG 11
vping Help Identify this hardtop please MG 21
Johnny Help Identify BJ8 rear mufflers Austin Healey 14
vping Help Identify this part. Jaguar 2
Stig Help identify this part. Triumph 2
walt Help identify renault engine in 71 S2 europa Lotus 1
bighly Please help me identify this tonneau cover MG 10
bighly Please help me identify this tonneau cover Jaguar 1
bighly Please help me identify this tonneau cover. Austin Healey 1
TR4 Speedo Help Needed ! Please Identify this clip !! Triumph 5
vping Please help identify this steering wheel Other British Cars 4
P can anyone help me identify my mini? British Motor Corp 11
T Help Identify Bolt?? Triumph 4
R help identify this wire wheel Austin Healey 11
Webb Sledge Help me identify this healey Austin Healey 19
A Help me identify my unit MG 15
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
