Results 1 to 8 of 8
Thread: Help to identify parts - BT7
  1. #1
    Join Date
    Apr 2018
    Location
    Gothenburg, Sweden
    Posts
    64
    Thanks Thanks Given
    3
    Thanks Thanks Received
    4
    Thanked in
    I received some parts with my Tricarb. I have identified most of them, but not those on the attached pictures. If ayone knows what they are I would be greatful to be enlightened.
  2. #2
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,683
    Thanks Thanks Given
    1
    35
    Thanked in
    Re: Help to identify parts - BT7
    I don't think either of those--esp. the eye bolts--go on a Healey (at least, there aren't any of these on my BN2 and BJ8). The second one could be a brake cylinder piston, but not for a Healey.
  3. #3
    Jedi Warrior Drone Dog's Avatar
    Join Date
    Jun 2017
    Location
    Seaford, DE
    Posts
    530
    Thanks Thanks Given
    2
    8
    Thanked in
    Don't remember seeing either of those on my Tri-carb. but there were some things like the gearbox that had already been rebuilt so i did not go in to them.
  4. #4
    Join Date
    Dec 2013
    Location
    UK
    Posts
    58
    Thanks Thanks Given
    2
    2
    Thanked in
    The second picture looks like an overdrive accumulator piston with an 'O' ring conversion - AH Spares part OVD202A
    The eye bolts in the first pic, I think are part of the seat belt anchorage ( I have them in a box of bits from my tricarb, yet to be fitted, but can't see them in the parts list so far!!!)
  5. The Following User Says Thank You to BBH For This Useful Post:
    Novamonte  (02-17-2019)
  6. #5
    Join Date
    Apr 2018
    Location
    Gothenburg, Sweden
    Posts
    64
    Thanks Thanks Given
    3
    4
    Thanked in
    Thanks! That can well be correct, the OD was rebuilt about a year before I purchased the car so the piston may have been replaced.
  7. #6
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,683
    Thanks Thanks Given
    1
    35
    Thanked in
    Quote Originally Posted by BBH View Post
    The second picture looks like an overdrive accumulator piston with an 'O' ring conversion - AH Spares part OVD202A ...
    I think we have a winner, though it's curious that it wasn't installed since the O-ring is supposed to be superior to the metal-ringed type (at least according to AHS). The DWR uprated accumulator still uses the steel rings. The activating pistons went from steel rings to O-rings in later cars.
  8. #7
    Jedi Knight Healey Nut's Avatar
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    1,118
    Thanks Thanks Given
    2
    11
    Thanked in
    Yes its an upgraded OD piston .
    "If it aint broke ....dont fix it "
    " Thats not an oil leak ..........its a special automatic British rustproofing system "
    Best Healey in show ABCD Ottawa 2013
    Best Healey in Show Boot n Bonnett Kingston 2013
  9. #8
    Join Date
    Apr 2018
    Location
    Gothenburg, Sweden
    Posts
    64
    Thanks Thanks Given
    3
    4
    Thanked in
    I believe that it was replaced for some reason (hopefully with another upgraded piston) when the OD was rebuilt. The one I received has been in a car, it can be seen on the top of the piston (not visible in pic though).
    Any ideas on the bracket in the same picture as the eye bolts?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
