TR6 Boot lid thread plates loose in stiffener
blokey
I am refinishing the boot lid on my TR6 and noticed that the threaded plate for attaching the boot lid to the hinge is loose and rattling around inside the reinforcing stiffener. The factory must have used some sort of adhesive to keep the plate in position while allowing some movement for aligning the hinge to the boot lid. Can someone suggest a method for keeping the plates in place?
thanks in advance
trrdster2000
When you tighten down the hinges they will stop moving. Just get them sung enough to move so you can line up the seams around the lid.
Don't get upset if it takes a few tries to get it right and some towels around the edges wouldn't hurt.
G Wanted Tr4a boot lid Triumph Classifieds 2
AUSMHLY Boot Lid Identification Austin Healey 2
B Fitting the Boot Lid Seal Austin Healey 8
chicken Boot Lid Badge Austin Healey 8
A BN2 Boot Lid Austin Healey 4
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
toysrrus TR6 "how to un-lock a boot lid"??? Triumph 11
CLEAH Boot lid repair Austin Healey 2
Y TR6 Triumph TR6 Trunk Boot lid wanted Triumph 4
B Aluminium Bonnet and Boot Lid Austin Healey 6
Got_All_4 TR2/3/3A Is this the proper Boot lid seal? Triumph 9
J TR2/3/3A Boot lid seal. Triumph 3
brcree MGB Trunk lid..[boot] alignement MG 4
R 100-4 boot lid prop Austin Healey 2
PatGalvin TR2/3/3A Boot Lid Reinforcing Supports Question, TR3A Triumph 8
J BN1 Boot Lid Bracket Austin Healey 9
healeyblue Boot lid safety cable Austin Healey 10
angelfj1 TR2/3/3A TR3A - Boot Lid Handle Triumph 6
sundown boot lid Triumph 6
Jim_Newman Trunk/boot lid Austin Healey 9
PatGalvin Rusty Boot Lid Follies Triumph 24
K TR2/3/3A Fitting the TR3 Boot Lid Triumph 4
M BJ7 BOOT LID Austin Healey 6
G I need a Vermillion trunk [boot] lid. Spridgets 3
Tinkerman TR2/3/3A 3A Boot Lid Handle Triumph 4
Tinkerman TR2/3/3A Boot Lid Seal TR3A Triumph 7
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
King_of_England Mk 3 boot lid rubber replacemant... British Motor Corp 4
Lin Luggage Rack Boot Lid Shield Austin Healey 18
J Boot Lid Austin Healey 4
kyreb1862 Boot Lid Adjustment MG 1
Lin Austin Healey Script on Boot Lid Austin Healey 28
Lin Boot Lid rubber seal Austin Healey 10
69MGC Any tips for fixing a bent boot lid MG 7
John_Mc Second boot lid Triumph 0
weewillie boot lid British Motor Corp 3
kyreb1862 Boot Lid Needs Adjusting MG 19
Ed_K Correct way to fasten the boot lid gasket ? Austin Healey 4
Cain Boot Lid/Bonnet Alignment Triumph 2
Cain TR6 Odd Problem - TR6 Boot Lid Triumph 1
A Adjusting boot lid position Spridgets 5
Editor_Reid Bugeye with a factory [?] boot lid Spridgets 7
Editor_Reid Bugeye with a factory [?] boot lid Austin Healey 1
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
J Restoration Progress - Boot Installed Austin Healey 1
