Results 1 to 19 of 19
Thread: Looking for the Voice of Experience
  1. #1
    Join Date
    Nov 2018
    Location
    Milford, MI
    Posts
    6
    Thanks Thanks Given
    2
    Thanks Thanks Received
    Thanked in
    I just bought a basket case 1960 TR, taking over a failed project. I was bored and needed a challenge and boy, I got one! My first month has been spent reading about them, inventorying the boxes of parts and uncovering patches of fiberglass and bondo covering ragged and rusty holes. There have been new floors, sills and quarter panels tacked in place. I have hung fenders and door on one side and everything seems to be in the right places. I have a plan for fixing the rear deck/wheel arch. What I'd like advice on is cage nuts. I have about 90 old ones to remove and replace. Any tricks of the trade? Is it worth buying a cheap spot welder or just tack them on?
    Leon
  2. #2
    Join Date
    Dec 2008
    Location
    Northern Cal
    Posts
    447
    Thanks Thanks Given
    Thanked in
    Re: Looking for the Voice of Experience
    Welcome Leon.... and you are at the right place to get the help you will be needing.
    You have started a long journey that many here have gone down.
    It probably won't be fast.... nor cheap... but will be rewarding... these are great cars!
    i am sure there will pretty quickly be response to your current question.
    Gil. NoCal
  3. #3
    Join Date
    May 2012
    Location
    Robbinsville, NC; Everglades City, Fl
    Posts
    590
    Thanks Thanks Given
    4
    Thanked in
    The cages I replaced, I just buzzed them on with MIG.
  4. #4
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,013
    Thanks Thanks Given
    8
    17
    Thanked in
    Hello Leon
    Sounds like me 3 years ago. Failed project, boxes of parts and fiberglass patches.
    Is the body still on the frame ? If it is and you plan to remove it be sure to brace the door gaps to retain the body dimensions.
    On the cage nuts I drilled the spot weld and then they usually came off easily. Just drill the cage nut not right through. You can get a spot weld drill but I used a regular drill.
    The hole will make welding it back easier or at least it did for me. Read the thread "Rear Tail light cutouts" He has a great home made tool for holding the cages while you weld.
    Never used a spot welder so I can not comment on that just used MIG. If I had it to do again I think I may have tried a TIG torch for some of it. My MIG welder will do TIG as well.
    As Gil said it is a long journey but well worth it. There is 3 years between the photos.
    David
    TR3A TS75524L
  5. #5
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,013
    Thanks Thanks Given
    8
    17
    Thanked in
    On the cage nuts I found the ones from one of the big 3 parts houses need work. The cage often allows the nut to fall out.
    Judging by the quality of the panel I got from K.A.S in Australia their nuts may be better. It sounds like their Rocker panels are a good fit as well.
    David
    TR3A TS75524L
  6. #6
    Yoda martx-5's Avatar
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,516
    Thanks Thanks Given
    3
    Thanked in
    If your not into strict originality, McMaster-Carr has superior caged nuts in the 1/4"-28 size. They are all one piece, not two separate items. Also, for those areas that are hard to MIG, I've used Pop-Rivets to hold the cage nuts in place. Also, there are a couple of places that have elongated cages to allow for more alignment, so you would have to use originals there. Macy's Garage also has the McMaster caged nuts. They are a little more expensive, but OK if you just need small quantities. McMaster sells by the 10 pack.
    https://www.mcmaster.com/90955a113
    Art
    '58 TR3A TS236xxL
    '92 Mazda Miata -- Supercharged
    '07 Mazda RX-8
    '11 Mazda CX-7
  7. #7
    Obi Wan M_Pied_Lourd's Avatar
    Join Date
    Oct 2008
    Location
    Newmarket, Ontario,Canada
    Posts
    2,357
    Thanks Thanks Given
    3
    Thanked in
    I’ve been using the Macy’s cage nuts in my projects. I’ve just been mig welding them on although I have a spot welder. Quite a few of the cage nuts are inaccessible as I’m sure you know. The rear wheel wells are a good example of this. In this case, I tried to move around and repair small areas at a time. Here’s an example of what I was doing on my 59 restoration to replace rusty metal and the cage nuts in behind.
    https://youtu.be/qkoQIPRUQ54
    Cheers
    Tush
    81 Alfa Romeo Spider Veloce, 81 Triumph TR8
    73 Triumph TR6 CF4874UO, 68 Triumph TR250 CD5228LO
    62 Triumph TR4 CT6716LO, 60 Triumph TR3A TS69891LO
    60 Triumph TR3A TS64870LO, 59 Triumph TR3A TS44836LO
  8. #8
    Jedi Knight Got_All_4's Avatar
    Join Date
    Dec 2004
    Location
    NEOHIO
    Posts
    1,486
    Thanks Thanks Given
    Thanked in
    Ok Leon congratulations you sound like me in 1976. Bought a 1960 TR3A and a Haynes Manual and some of the skills I learned from HS Vocational school small engine repair and taught myself how to rebuild a car. That's the Cliff Notes version anyway. Wish i had this resource (BCF) when building my first project as it probably would not have taken 7 years. Take your time ask questions before you do anything stupid. These cars are simple, great and easy to work on and if you get over your head get professional help. I had to twice because I got ahead of my skills at the time and no one to turn to for help. A man needs to know his limitations. I've heard that quote somewhere before. On those caged nuts I liked the extra adjustment you get out of the originals. Whenever possible save the old square nuts too and reuse them. They are thicker then the new ones you get with the cages. The new ones tend to fall out of the cage and are harder to start the bolt when assembling. Good luck!
  9. #9
    Join Date
    Nov 2018
    Location
    Milford, MI
    Posts
    6
    Thanks Thanks Given
    2
    Thanked in
    Funny thing about knowing your limitations, when my customers asked if I could do something we didn’t quote my motto was “given enough time and money I can do anything”. Which usually included finding someone to help!
    The body is on the frame. I don’t have the room to separate them plus I don’t trust any of the welds even if I braced between the pillars. After the body work is done, before prep & paint, is it too late to lift off the body?
    I took some pictures showing before and after hanging the door and rear fender. Any thoughts on if it is close enough to start welding. In the close-up of the B-pillar, what the heck is missing? The dome shaped part? He bought a new B-pillar but I can’t find that part.
    My first build was a 1976 Bradley GTII. Buying a basket case is like a kit car with no instructions. But the TR is not fiberglass and will be worth something when I'm done.
    Thanks, Leon
  10. #10
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    64
    Thanks Thanks Given
    2
    Thanked in
    Looks good. I bought my first 1960 TR3A in 1974 with no money left and no available parts. Made it work somehow.
    I never had to weld steel so the best advise I can give you on that is "Don't weld the door shut" ;-)
  11. #11
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,943
    Thanks Thanks Given
    11
    Thanked in
    Can you take a picture of the B post quarter panel looking down? There should be a channel of sheet metal to reinforce the top edge.
    steve
  12. #12
    Join Date
    Nov 2018
    Location
    Milford, MI
    Posts
    6
    Thanks Thanks Given
    2
    Thanked in
    Steve,
    Hope you can see what you need from these. If not, let me know. it's hard to get light in there!
    Leon
  13. #13
    Join Date
    Jul 2018
    Location
    Perth Australia
    Posts
    117
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Hi Leon.
    Is this what you are looking for?
    Hard to see in the photos but that rounded over bit that sticks up at the top is several layers thick (apart from the leading on this one) and tabs to the rear for about half an inch where it is welded to the top of the inner panel.
    Lionel
  14. The Following User Says Thank You to LionelJrudd For This Useful Post:
    LeGrande  (02-17-2019)
  15. #14
    Join Date
    Nov 2018
    Location
    Milford, MI
    Posts
    6
    Thanks Thanks Given
    2
    Thanked in
    Lionel, That is exactly what I'm looking for. Appears to be a stamping over another piece. Apparently it is going to be a problem getting it welded in with the quarter and inner panel already in place. That's if I can find the parts. They are not shown in any catalog I have found. I'm attaching a couple pics of the drivers side. I think it's OK but not really sure.
  16. #15
    Join Date
    Jul 2018
    Location
    Perth Australia
    Posts
    117
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Leon find attached a tracing of the B post on the right side of my car. The four circles are the door latch mounting holes for reference distances. Shaded indicates where the panel has been leaded for shaping. As you can see, there is a L shaped section that joins the vertical part to the top of the inner panel. Just edge welded. I think you only need to add the lower part of that to the passenger side of your car.
    It looks like you have most of the B post and its only the flat and vertical section on top that needs to be redone.
  17. #16
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,943
    Thanks Thanks Given
    11
    Thanked in
    Here is a couple of shots of my car. I have been waiting for summer to do that part of the interior among other things. But anyways, there are a couple of pieces that make up that end piece. I tried to get some pictures, but my camera is not high quality. I know what iam seeing so it makes sense to me. Lionel is a true fabricator and he basically is building a whole car. You are probably going to need to make those pieces and all I can suggest is the size of the end cap is the size of trim opening of the dog leg piece of trim if you have that piece in your collection.
    steve
  18. The Following User Says Thank You to sp53 For This Useful Post:
    LeGrande  (Yesterday)
  19. #17
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,013
    Thanks Thanks Given
    8
    17
    Thanked in
    The Top "D" shaped piece seems to be made from a thicker piece of steel. Maybe 1/8" thick. At least that is what mine looks like.
    David
    TR3A TS75524L
  20. #18
    Join Date
    Oct 2018
    Location
    Adelaide South Australia
    Posts
    7
    Thanks Thanks Given
    Thanked in
    Hi just came across this thread. I have done quite a bit of work especially around the rear quarter panel and B pillar of late. I have added some photos on my website
    http://colbtr2.wixsite.com/triumph-t...l-and-b-pillar
    which illustrates a few things about the construction I hope although I can't locate an image of the inner panel with the 'pocket' welded on the inner panel before fitting. I will look further tonight and see if I can add it in
  21. #19
    Jedi Hopeful Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    123
    Thanks Thanks Given
    1
    2
    Thanked in
    If there is any lead left in that top piece it will melt when you weld that corner or rear bracket on, I just used soft solder to build it up again.
    [SIGPIC][/SIGPIC]
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
