Results 1 to 18 of 18
Thread: Painting a BJ8 Radiator - any advice?
  1. #1
    Join Date
    Apr 2013
    Location
    Oakville, Canada
    Posts
    162
    Thanks Thanks Given
    4
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Last year, I stripped the radiator of my BJ8 down to bare metal (brass tanks) and then painted it using Dupli-Color Engine enamel. Last week, a significant crack in the paint appeared, and then pieces (size of a quarter) came cleanly off, exposing the clean brass below. Clearly, the paint did not adequately adhere, despite my having taken great pains to strip and then thoroughly clean the surface before painting.
    Had anyone had success painting their rad? What prep and products did you use?
    I looked at Radiator Paint on the Eastwood site and asked about prep. They recommended a ‘misting of self-etching primer first’, however the product spec for self-etching primer states that it is only stable to 170F....
    thanks
    Steve
  2. #2
    Join Date
    Nov 2012
    Location
    Warrington PA
    Posts
    516
    Thanks Thanks Given
    Thanked in
    Re: Painting a BJ8 Radiator - any advice?
    What did you strip with and was it neutralized after stripping?
  3. #3
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,891
    Thanks Thanks Given
    13
    Thanked in
    Hi Steve,
    Before I would have painted the tank, I would have applied a primer to get grater adherence to the cleaned metal. Also, CaptRandy had a good question, as if stripper sediment is not eliminated, it could cause those areas not to adhere to the metal. At this point, I would remove the present coating, wash the clean metal with water and allow to thoroughly dry, apply a primer and then apply the finishing coats.
    Yes, a great deal of work but I expect it will last longer then your present application.
    Just my thoughts,
    Ray(64BJ8P1)
  4. #4
    Join Date
    Apr 2013
    Location
    Oakville, Canada
    Posts
    162
    Thanks Thanks Given
    4
    1
    Thanked in
    1 Post
    Hi, the entire top of the tank was stripped with a methylene chloride paint stripper, then cleaned with Varsol then acetone. I roughed the metal up with 1000 grit before a final wipe down with acetone followed by compressed air. Only half of the top tank has had paint loss.
  5. #5
    Join Date
    Apr 2013
    Location
    Oakville, Canada
    Posts
    162
    Thanks Thanks Given
    4
    1
    Thanked in
    1 Post
    I think a primer is a good idea, but I can’t seem to find one that tolerates higher temperatures. I’d particularly like to use a primer that someone in this forum has used successfully rather than just find one on the Internet....
  6. #6
    Join Date
    Mar 2009
    Location
    ky
    Posts
    137
    Thanks Thanks Given
    Thanked in
    Hi-Temp header/exhaust manifold paint at Autozone, they have the primer too. I wouldn't do much sanding,
    just an etch with Ospho or even Naval Jelly
  7. #7
    Jedi Knight Bob Claffie's Avatar
    Join Date
    Feb 2003
    Location
    Dalton Mass
    Posts
    916
    Thanks Thanks Given
    Thanked in
    I think the 1000 grit is too fine to promote good bonding.
    Thank goodness the MG is finally gone, replaced by another Corvette
  8. #8
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,226
    Thanks Thanks Given
    53
    75
    Thanked in
    IMO high-temp paint is unnecessary on the radiator. I've painted mine a couple of times with Rustoleum or Krylon satin black and no primer. Still adhering several years later.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  9. #9
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,483
    Thanks Thanks Given
    7
    Thanked in
    Quote Originally Posted by dancrim View Post
    This is similar to what I have done for years.
    , except ,do not etch or sand.
    Additionally": send radiator to shop and have it stripped with instructions "DO NOT PAINT".
    Then follow dancrims advice on paint type or as I use Hi Temp Engine paint
    OH: immediately after spray painting the fan shroud red, have a brush handy to add the brush lines.
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  10. #10
    Join Date
    Mar 2008
    Location
    Michigan
    Posts
    146
    Thanks Thanks Given
    3
    Thanked in
    https://www.eastwood.com/ew-radiator...sol-12-oz.html
    I have used Eastwood's radiator paint on several radiators, without priming before hand, with excellent results. It comes in gloss and satin. To date I have only used the gloss.
    It covers well and has never flaked off.
    I do usually clean with wax & grease remover or similar.
  11. #11
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,228
    Thanks Thanks Given
    32
    15
    Thanked in
    Quote Originally Posted by steveg View Post
    Same here. I clean it with Prep-All first.
    John, BN4
  12. #12
    Join Date
    Dec 2014
    Location
    Middletown, New York
    Posts
    64
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    prep cleaned brass tank , sanding with 600 is better, use PPG DX 330 wax and grease remover,( Usually after I chemically strip tank I wash with warm water, scrub the crap out of it with scotch brite pads and tooth brush in crevises)
    then after compressed air drying , tack down and I use PPG DP epoxy primer(black) thinned out as a sealer, ( its really thin ,you do not want too much material such as a sanding primer or etching primer, this stuff sticks to glass ! )
    then I use PPG DCC 9300 ( black) with flattening agent to make it just under semi gloss , at this point you can also use your spray can of choice. The DP epoxy is what does the trick for adhesion. FOr the core part If radiator is out of car I would just use a spray can and keep it thin . The top is seen and regularly cleaned. If you do it right you cannot notice any color or sheen differences between the two and urethane will provide some protection paintwise to some abuse. Bottom of tank same way top is done. FWIW .
  13. #13
    Join Date
    Apr 2013
    Location
    Oakville, Canada
    Posts
    162
    Thanks Thanks Given
    4
    1
    Thanked in
    1 Post
    I painted the rad in the spring of 2018 and the finish was fine until 3 weeks ago when we hit a major cold snap. The car resides in my garage, which is attached to the house, but it was probably subjected to temperatures as low as -15F.
  14. #14
    Jedi Knight nevets's Avatar
    Join Date
    Oct 2002
    Location
    Western MA
    Posts
    1,069
    Thanks Thanks Given
    Thanked in
    Just a thought...brass sheet metal expands /contracts with heating/cooling...just wondering if the engine paint you used is made to flex that much? There are paints (in spray cans) specifically for automotive radiators.
  15. #15
    Join Date
    Apr 2013
    Location
    Oakville, Canada
    Posts
    162
    Thanks Thanks Given
    4
    1
    Thanked in
    1 Post
    I think you could be right. That said, I think an appropriate primer is essential too, since the paint came off in fairly large shards, despite surface prep being meticulous.
    My inclination would be to use the radiator paint from Eastwood but use an etching primer with a broad temperature stability range.
  16. #16
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,891
    Thanks Thanks Given
    13
    Thanked in
    Hi Steve,
    In your first attempt, I think you did a job more appropriate for painting a fender. However, as you have indicated, the radiator does expand and contract so the paint needs something more to grab and your 1000 grit sanding made the surface to smooth to provide sufficient grip. I agree with Steveg as the radiator gets hot but within the limits of standard
    Rustoleum or Krylon spray paints (I used a satin black Rustoleum last painted around 15 years ago). I roughed up the tanks with a medium grit paper for the primer to grab. The primer filled in any roughness and provided a good adhesive surface for the final paint to grip.
    Considering the red fan guard originally had brush marks in the paint from the factory, I would suggest you not overdo the finish on the tank.
    All the best,
    Ray(64BJ8P1)
  17. The Following User Says Thank You to RAC68 For This Useful Post:
    SteveHall64Healey (02-13-2019)
  18. #17
    Jedi Knight dougie's Avatar
    Join Date
    May 2008
    Location
    Portland, Oregon
    Posts
    1,482
    Blog Entries
    1
    Thanks Thanks Given
    14
    Thanked in
    This system has work for many years on all my radiators, including my vintage racer
    - Stripe & Scruff sand with 320 grit
    - Solvent wipe with Xylol (acetone too fast)
    - Apply one light even coat .5 dry mils. http://www.tcpglobal.com/SEM-39673_5...2#.XGSm71VKjIU
    - Apply two coat medium coats 2 dry mils. sanding between coats with 400 http://www.tcpglobal.com/SEM-42003_6...0#.XGSoU1VKjIU
    - Apply two medium finish coats 2 dry mils. no sanding between https://www.eastwood.com/2k-aero-spr...ack-47968.html
    Dougie
    '65 BJ8 3000 MKIII GN.29
    '57 100-SIX MM Vintage Racer GN.1 #414
    Team Healey PDX
  19. #18
    Join Date
    Apr 2013
    Location
    Oakville, Canada
    Posts
    162
    Thanks Thanks Given
    4
    1
    Thanked in
    1 Post
    Update:
    I removed the radiator and found the paint on the lower tank came off quite readily too. The parts of the rad made of steel held the paint quite well, while brass areas had little/no adhesion.
    I took a piece of brass sheet metal and did the following:
    1) sanded smooth with 325 grit sandpaper.
    2) washed with warm soapy water. Dried thoroughly.
    3) cleaned with Eastwood prep (contains xylenol as main ingredient). Allows 30 minutes to dry.
    4) gave two coats of Eastwood self etching black primer, leaving 15 minutes between coats.
    5) waited 4 hours, then gave two coats Eastwood radiator black paint in satin, waiting 30 minutes between coats. (note: primer and finish coat applied per instructions on label).
    6) allowed to dry for 24 hours.
    7) baked at 220F for one hour. Paint finish appears to be unaffected. Allowed to cool to room temperature.
    8) placed piece outside at 20F for two hours, then allowed to return to room temperature. Paint finish unaffected.
    9) attempted to scratch surface with my finger nail - paint did not come loose.
    10) bent piece - again paint unaffected.
    Looks like this process results in a temperature-stable finish, so will repeat the process on the radiator itself.
    Note: the satin finish is quite nice but it is actually quite low gloss - too close to flat to look factory correct, so will use the Eastwood radiator paint gloss on the radiator.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
