T-Series Lever ignition light switch / pull starter switch
TRMark
Bronze
You guy helped me several years ago identifying some of the T series parts that inhabit my very early 50's sports/racer. I put the project on the shelf for a few years and am now back at it. I want to keep/restore the car a bit quirky so I thought I would ask questions here. I noticed Moss is selling along with vintage motorcycle suppliers a keyed lever ignition/headlight switch, I also noticed Fordson tractors use a similar switch. How does the Moss unit mount, how big of a hole? I think T series use a pull cable for the starter, I would like to use a spring loaded pull switch, any ideas there? Ron Francis supplies a hotrod version but it is billet with color trim rings, not crazy about that.
Jim B.
The TD uses two switches for headlights. The key turns on the ignition and the lever which has parking/headlamp positions. there is a second, similar switch for dip and driving lights (and horn) . The holes are large. about 2", same as gauges.
Yes the starter is purely mechanical. A cable actually draws a V shaped bar into contacts to activate the starter.
I am guessing you want to use a relay. If you wish to keep originality, you could use the Moss cable and connect it to a momentary toggle behind the dash.
TRMark
TRMark
Bronze
Wow! That is a beautiful bit of work on the dash panel. My old sports/racer is a bit rude and crude, which fits my skill level, nothing like a close contemporary Lotus 9. Thank you for your help with the switches. I found one at Speedway that will work for starting. I will probably incorporate the TD key/lever switch into the dash. https://www.speedwaymotors.com/Spee...46894473&utm_content=All Products (Jan25_2019)
TRMark
TRMark
Bronze
Nother question Jim. I was doing some research the other day about my Cooper based special and noticed the engine turned dash in the famous Cooper-MG Joy500. I remembered the beautiful dash you had built for your TD. Did you make the engine turned material or did you buy it ready made and cut it to shape. The shape of the cowl and dash in my car is very similar to the Cooper-MG, I really like this look, note the TD like switches.
Jim B.
Mine are Stainless Steel
Moss used to sell them in the Mid 1960's. I have a catalog from 1966 wit the dash and other covers listed.
I found mine on eBay about 6 years ago. There were two at the time. I have not seen another sense.
I was also lucky enough to fine matching door sills.
There were also covers for the gas tank sides but I never wanted them.
I felt that the original steering wheel hub needed more bling, so I made one out of an Aluminum block. The MG logo is the center of a wheel cover.
I then felt that the gearshift needed work.
Moss used to sell similar knobs.
Yes there may be too much bling.
My Wife has Macular, she has to have very dark glasses when we go for a drive.
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
Celtic 77 General MG Lever shock oil refiller MG 0
shadowfever Seat runner with lever Spridgets 2
Gliderman8 TR6 Lever shock noise Triumph 18
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
RJS General TR Lever Shock - HD Shock Valve Triumph 2
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
S Removing Overdrive Shaft Lever Pin Austin Healey 7
K Missing spring clutch release lever Other British Classifieds 1
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 2
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
R TR2/3/3A Transmission Lever Assembly Triumph 9
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
J BN2 Shift Lever Bushing Replacement Austin Healey 6
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
AUSMHLY Lever Shock Oil Level Austin Healey 41
C TR2/3/3A Rotating shift lever Triumph 12
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
M Clutch fork lever Austin Healey 11
Graham H TR2/3/3A Gearshift lever chatter Triumph 7
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
W Gear Lever Boot for BN2 Austin Healey 5
C TR6 Shift lever Triumph 4
R TR2/3/3A Steering Hub Turn Indicator lever Triumph 7
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Shift lever issue [No Healey content] Austin Healey 0
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
K Austin A95 bonnet release lever? Other British Cars 0
69MGC MGC MGC Handbrake Compensting Lever MG 1
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
D TR4/4A stubborn lever shock link Triumph 2
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
69MGC MGC Lever Shocks are Toast MG 7
Rut 5 speed gear shift lever Spridgets 28
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
Rut MGB MGB OD gear shift lever MG 0
P Sprite Shift Lever Spridgets 20
