Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Bugeye Radiator Tank Plug Size?
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #21
    Jedi Warrior BlueMax's Avatar
    Join Date
    Dec 2010
    Location
    Easley, South Carolina
    Posts
    701
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Re: Bugeye Radiator Tank Plug Size?
    Serck may have told me wrong, but calling them asking this particular question Tuesday? Then sending the photo and stating what size they machine their bungs is puzzling? My radiator is not made to the original specifications. My temp prob is threaded into the cylinder head, a more accurate temp reading. My thermo-fan switch is threaded into its specially machined bung at the standard bung location on side of tank.
  2. #22
    Yoda Trevor Jessie's Avatar
    Join Date
    Nov 2003
    Location
    Louisville KY
    Posts
    8,070
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Where did you buy the sensor that fits into the radiator? In my case, my cheapo aluminum radiator had 3/8 NPT threads so several aftermarket sensors matched but when I had a stock radiator i had troubles finding one with bspp threads.
    _____________________
    1970/2 MG Midget
    Datsun 5-speed
    Future Fuel Injection Turbo Project
    _________________
    1958/9 Sprite AN5L/1499
    1275 SuperCharged
    Datsun 5-speed
    _________________
  3. #23
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    263
    Thanks Thanks Given
    5
    Thanked in
    Blue Max
    Nice install. I love the silicone hoses.
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  4. #24
    Join Date
    Dec 2010
    Location
    Posts
    701
    Thanks Thanks Given
    Thanked in
    Trevor, my radiator that Serck build for me is way different then the eBay stuff. I had Roy move the core as far forward as possible to enable the 11” Spal electric fan to clear the front side of steering rack. The radiator has 4 brackets with studs attached so as the fan drops on to and bolts flush to the core. I also had them weld tabs it support the wiring harness for the fan. The bung was machined to fit a 1977 VW rabbit thermo-fan switch, I think it was 19 x 1.5 mm?
  5. #25
    Join Date
    Dec 2010
    Location
    Posts
    701
    Thanks Thanks Given
    Thanked in
    Thanks Joe, labor of love I would say!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
