Diameter of Washer Bottle Hole in Parcel Tray
Kainopong
Can anyone confirm the diameter of the early BN4 washer bottle hole vs the later 6 cylinders? I read that the early ones were slightly larger but have no reference or means to confirm. Thanks!
healeyblue
I have reproduced the bracket that holds the bottle and the bottle is about 4 inches in diameter. The bracket is about 4 1/8 inches outside diameter. So the hole should be somewhere between those dimensions. I have one more reproduction bracket left if you are in need.
healey106
I just measured the the hole in the package tray after I removed my bottle and bracket in my Longbridge BN4 and the opening for the bottle appears to be 4 1/4" wide. I hope that assists you for the information you needed.
:driving:
Chet Zerlin
If you still have that reproduction bracket I want it. Let me know?
Thanks!
Chet
SNClocks Master Cylinder Bore Diameter Spridgets 0
BN6_2197 BN6 Pulley Diameter Austin Healey 3
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Rhodyspit75 Generator pulley diameter Spridgets 2
R TR2/3/3A Clutch Diameter 1957 TR-3 Triumph 1
Foura TR4/4A Universal joint diameter Triumph 9
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
Geo Hahn TR6 Alternator Shaft Diameter Triumph 6
Sarastro T-Series TD connecting rod big end diameter MG 4
Z BN1 Tyre Diameter Austin Healey 8
Westfield_XI Master cylinder diameter for big brakes Spridgets 23
PatGalvin TR2/3/3A Steering Wheel Diameter with R&P Steering, TR3A Triumph 9
RickB MG Rostyle cap diameter? Spridgets 14
RickB MGB MGB Rostyle cap diameter? MG 0
Bremer Trunnion pin diameter Triumph 3
R Magically increasing bearing diameter Triumph 20
T Fuel line internal diameter Spridgets 5
TexasSprite Inner Brake Drum Diameter? Spridgets 6
healeyboz Gen pulley diameter Spridgets 20
BritCarFan 180mm or 190mm clutch plate diameter? British Motor Corp 1
J clutch master cylinder bore diameter? Triumph 1
Brosky TR6 Diameter of crankshaft pulley on TR6 Triumph 17
T overdrive check ball diameter MG 3
N TR6 Inside diameter for TR6 rear brake drums Triumph 6
S steering wheel diameter Austin Healey 7
T Servo Hose Diameter? Triumph 7
Woodie air filter diameter Spridgets 0
E HS4 SU carb inlet diameter? MG 15
1 Found a picture, q. regarding wheel diameter MG 7
1 MGB Steering wheel diameter? 74 MGB MG 13
K TR2/3/3A Picture of the Zinc washer. Triumph 3
W Glass Washer Bottle Lids Austin Healey 0
T Tudor Washer Bottle Holder Austin Healey 1
J Thackery Washer Austin Healey 3
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
W Tudor windscreen washer bottles Spridgets 0
J TR4/4A Washer bottle bracket screws Triumph 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
M TR6 Wiper washer knob Triumph 5
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
B TR4/4A Thrust washer issue Triumph 11
4tecdog Fibreglass bonnet washer fittings Spridgets 5
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
R Windshield Washer Pump Repair Austin Healey 9
M TR2/3/3A Standard Engine Trust Washer Thickness Triumph 18
B TR6 Winshield washer bottle location Triumph 2
