TR2/3/3A Mystery Wood
JeffW
This wood piece is at least a mystery to me. I started removing the outer sill and as I did I noticed this wood piece between the B post and the rear quarter panel.It appears to be held in by the little metal tabs. It looks to be rotted but I don't see it listed by any of the vendors. Any help identifying it will be greatly appreciated.
Thanks Jeff
STeve 1958
I have that too and can't find a use for it. Sometimes triumph used wood to create a surface to staple to. Is there a door seal that staples on there. I don't have one but my car is not complete.
Steve
TR4nut
Tacking strip for the fur flex seal around the door. It’s kind of a weird cardboard like material. You can substitute wood or anything else to use to attach the seal if what you have is in poor shape.
charleyf
I agree with Randy. It is not wood but rather a cardboard like material that has been twisted and shaped to fit in that groove. Best to replace with wood or what ever will hold a tack.
STeve 1958
The fur flex seal tacks on and then the vinyl covered panel covers the ugly tacks. The panel screws to the steel.
That stuff is almost like the rope we used to use to seal cast iron pipe. Maybe cardboard mixed with glue. Use a soft wood like Douglas fir or pine.
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
J TR2/3/3A TR3 gas tank mystery Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
S MGB mystery wire MG 32
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
AN6-TX Application of Marvel Mystery Oil Spridgets 8
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
Y MGB A bellhousing mystery.... MG 3
P Mystery leftover BJ7 Pieces Austin Healey 18
warwick-steve Mystery Rattle Austin Healey 21
K Off Topic Mystery Windshield Brackets or ?? Triumph 6
warwick-steve Misfire mystery Austin Healey 28
ckeithjordan TR2/3/3A TR Mystery Thingy Triumph 13
S Marvel Mystery Oil Spridgets 7
D mystery Friday... Austin Healey 5
D mystery of the day... pedal block? Austin Healey 5
HighAltitudeTR3 TR2/3/3A Mystery Bracket Triumph 23
D TR4/4A water pump mystery hole Triumph 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
T TR2/3/3A Another Mystery Part Triumph 8
R TR2/3/3A Mystery part? Triumph 10
T 100-6 LHD/RHD mystery Austin Healey 7
T TR2/3/3A Mystery Heel Panel Holes? Triumph 6
