twas_brillig
Okay: I'm trying to convert a 1972 BMW 2002 from carbs to EFI, using gutted Weber DCOEs as throttle bodies and a dual side draft intake manifold out of the USofA.
The car is metric; the carbs are metric; the studs connecting the Webers to the manifold are coarse 5/16" x 18 TPI and their other half connecting to the carbs are fine thread 5/16" x24 TPI.
I'm assuming that using the coarse threads into the manifold maybe are for manufacturing ease (but would appreciate comments from someone more knowledgeable than I), but why in heck switch over to fine threads for the nuts holding the webers to the manifold? Fine threads are stronger, but why switch? Any wise persons out there?
I guess I can just be thankful that they aren't British Standard Whitworth combined with goodness knows what.
Thanks,
Doug
Thanks,
Doug
