TR4/4A Reducing Chassis Flex on TR4A IRS
JerryVV
A few years ago I saw a TR6 race car without a cage or any obvious additional strengthening that handled like it was on a rail. The only observation was a series of large pop-rivits spaced pretty closely thru the floor to the frame (the rivits followed the shape of the frame) TR6 frame and 4A frames are essentially the same. I asked the owner if that was his method for strengthening chassis flex and he just smiled. A few years later I again saw the car at Watkins Glen and asked him again, this time he was a bit more forthcoming and nodded his head in the affirmative. Sort of created a unibody out of a chassis on frame construction. He again was very competitive until his engine went up in smoke.
STeve 1958
There are three aspects to the rigidity of the frame.
Flexing
Twisting
and Racking
Racking is the easiest to reinforce with some diagonal braces or "X" braces in the frame.
Flexing is a little harder and usually requires additional depth added to the frame. Ive seen 2" x 2" x 1/8" square tube welded to the bottom of the frame or plate steel welded to the sides of the frame members.
Twisting is the toughest to cure. The idea of using the body to resist twisting is good as it gives you lots of depth, except at the door. A combination of riveting the body to the frame and reinforcing the frame in the area of the door might work best.
I'm a structural engineer but not an expert on auto frames.
Steve
M TR4/4A Reducing rear chassis flex. Triumph 3
M Reducing Revs at Higher Speeds Austin Healey 31
HealeyPassion Reducing Muffler Heat Austin Healey 2
A BN2 Chassis Alignment Austin Healey 8
RJS TR4/4A Chassis Buffeting(?) Triumph 10
apbos The next rabbit hole. Help ID the chassis. Racing 27
apbos Help Identify this car chassis Racing 20
5 MGA Body and Chassis Separation? MG 2
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
HealeyPassion Finally, paint on chassis Austin Healey 17
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
Pep Daimler SP250 A-spec vs B-spec chassis Other British Cars 9
M TR6 TR5/6 Engine Mount/Chassis Brackets Assistance Please. Triumph 2
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
Guido36 Chassis Number Issue Austin Healey 11
Editor_Reid Healey 100 Chassis Dimensions Austin Healey 5
F TR2/3/3A back half to chassis questions Triumph 105
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
B Chassis Suppliers Austin Healey 0
J Wanted MK VII/VIII/IX rolling chassis with or without drivetrain Jaguar Classifieds 2
J Wanted Jag MK VII/VIII/IX rolling chassis with or without drivetrain Other British Classifieds 1
J Wanted TR3/4 rolling chassis Triumph Classifieds 2
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B MGA Mystery MGA chassis part MG 3
V TR2/3/3A TR3A Chassis restoration Triumph 8
T TR2/3/3A Chassis paint color Triumph 10
BoyRacer Rig for storing chassis on its side Austin Healey 8
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
B General Tech Prime over Chassis Saver? MG 3
TomMull Numbers re Chassis project Lotus 4
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
TomMull CHASSIS SHIPPING Lotus Elan Plus 2 Lotus 22
P TR2/3/3A Chassis paint questions Triumph 8
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
C Chassis plate screwsize Austin Healey 6
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
K How would a new-chassis car be registered? Austin Healey 15
B GT6 Chassis color Triumph 4
PeterK TR2/3/3A Ebay rolling Devin body moded chassis - with O/D Triumph 1
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
BoyRacer weight of bare Healey chassis Austin Healey 8
I Chassis rotisserie..? Austin Healey 10
A Chassis front 'H-section' Mk1 Spridgets 5
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
