TR2/3/3A Seat back angle
cluker
Hi,
I have a 1960 TR3A and would like to install TR3 seats (currently have modified TR6 seats), but I find the seat back angle uncomfortable; they're too upright.
I was wondering if anyone thought it feasible to take the forward tilting type of seat (like this one) and modify the hinge assembly or mating parts to give a permanent rear angle that is about 10 deg tilted further back.
Any thoughts? Has anyone done that? Is there a better way to get a more comfortable angle while retaining an original(ish) look?
thanks, Craig
Seattle, WA
GilsTR
Craig.... just this past week I was looking thru some old Road and Track
magazines. Loved finding Triumph's ad dated about 1958. It listed 6 reasons
why someone should buy a Triumph. Number 4 on the list:
SEATS: Orthopedically designed for comfort.
While I can't hold a candle to Randall's butt time in a TR3 seat....
I know I have over 100,000+ miles there... and I have to say the
advertising department stretched things W A Y too far with that one!
Gil. NoCal
RJCOX
I'm just a newbie, but could raising the front of the base accomplish it? Maybe weld or bolt in a wedge from the floor or onto the seat. It would maintain a stock look, and would be reversible if done right.
STeve 1958
Raising the front of the seat would result in your knees rubbing on the steering wheel unless you install a smaller wheel. I already reduced to a 15" wheel. The Simplest thing I found was to add more padding towards the bottom of the seat back. This helps but only and inch or so.
C
cluker
I had thought of simply tilting the whole assembly too, but the steering wheel almost brushes my thighs already.
So what about my idea for a little surgery on the tilting seat back? I don't mind experimenting, but I'd like to know from more experienced folks if it's a goofy idea before I start.
Thanks, and Merry Christmas!
Craig
charleyf
Craig,
so your TR6 seats must not have the option of reclining? I use TR6 seats in my TR4's. The primary reason I use these seats is to use the reclining position. I agree that the stock seats are way to far forward. However as a young man in my twenties I did not have a problem with them.
TomMull
It seems to me that the TR3, as well as many period cars, had seats that were designed with a driver position that is quite different than today's semi relining with arms straightened style. (NASCAR still uses the old position with the steering wheel close and in your lap.)
I'd suggest that you consider adapting your driving style to the period seating. It's awkward at first but you get used to it and it suits the car.
Tom
STeve 1958
Simply relocating the bolt hole for the seat hinge will work for one seat, not the other. It will cause some added stress on the bolt and on the bottom of the seat back. These could be reinforced a little to keep the back from buckling or the holes from elongating. My car has a roll bar which the DPO located to close to the seat so I have no more room to adjust.
C
cluker
Tom
I have been doing that and agree that it's possible to get used to that "close in" position. The problem is that my back doesn't like the very upright angle.
Thanks to everyone of the replies. I think I'll risk ordering some new seats and will attempt some modifications on them.
Craig
RAC68 Front Seat-back Angle Austin Healey 15
C BJ8 Seat back angle Austin Healey 14
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
J TR4/4A TR4A seat retaining clip Triumph 5
R BJ7 Back Seat-Rest Austin Healey 1
A TR2/3/3A Seat position Triumph 2
jlaird Wanted One Bugeye seat Spridgets Classified 0
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
J TR4/4A Seat install, Spring clip Triumph 0
