TR2/3/3A TR3 wheel studs
windsor
I'm working on a TR3A that came with 2 sets of wheels . One set of wires and one set of discs . I'm going to have to replace a couple of wheel studs in the hubs , and am debating whether to change them all to short studs , which would mean that I could only use the wire wheels . ---Or changing them to long studs and then using spacers if I wanted to use the wire wheels , and could also use the discs . --I'm just not sure how satisfactory the spacers are when used with the wire wheel hub adapters ? Any input ?
martx-5
My car originally came with wire wheels and the short studs. If it weren't for the crazy design of the rear studs, I would have replaced them with longer studs and used spacers with the wires. This would give me the option to go with steel of alloy wheels if I wanted to. I wouldn't change or cut long studs.
Keep the long studs and use spacers. Have done this numberous times. Buy the spacers from Joe Alexander, they are designed for this purpose and fit well. You can swap wheels back and forth in minutes.
Marv
Geo Hahn
I have used the spacers for more than 20 years with no problems. Nice to be able to change the look from time to time.
TR4nut
Agree spacers work fine and also Joe Alexander’s work very well.
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
O TR2/3/3A TR3 Wheel Studs, Couple of Hinges Needed. Triumph 2
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
K TR2/3/3A Installing wheel studs to hub TR3 Triumph 2
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
T TR2/3/3A TR3 wiper wheel boxes Triumph 5
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
B TR2/3/3A TR3 Steering wheel restoration Triumph 4
O TR2/3/3A TR3 Steering Wheel Swap Triumph 1
Number_6 TR2/3/3A TR3 Wheel paint Triumph 8
K TR2/3/3A Wheel Lug Nut Torque for a TR3? Triumph 2
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
T TR2/3/3A TR3 steering wheel and indicator Triumph 5
O TR2/3/3A TR3 Wheel Bolt Pattern Triumph 1
M TR2/3/3A TR3 Steering Wheel Repair Triumph 5
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
K TR2/3/3A TR3 wheel specs? Triumph 3
RedTR3 TR2/3/3A TR3 Wheel Track Spec Triumph 14
T TR2/3/3A tr3 steering wheel resto Triumph 5
mountainman TR2/3/3A TR3 Front Wheel Bearing Triumph 1
Marvin Gruber TR2/3/3A Early TR3 wire wheel set up. Triumph 9
T TR2/3/3A wheel spacers for TR3 Triumph 13
Brooklands TR2/3/3A Spare Wheel Door rubber gasket - TR3 Triumph 3
A TR2/3/3A TR3 steering wheel support Triumph 10
T TR2/3/3A TR3 wheel bolt pattern Triumph 7
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
S TR2/3/3A narrow wheel tr3 Triumph 13
K TR2/3/3A Who used 1/2" wheel lugs on their TR3 hubs? Triumph 1
NutmegCT TR2/3/3A TR3-4 owners: wheel poll Triumph 21
JPeter TR2/3/3A TR3 Rear wheel brake cylinders Triumph 7
fad64b TR2/3/3A TR3 steel wheel color Triumph 6
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
JFS TR2/3/3A TR3 Rear Wheel Bearings Triumph 13
A TR2/3/3A TR3 Wire Wheel painting Triumph 2
martx-5 TR2/3/3A TR3 Wheel Info Needed Triumph 1
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
S TR2/3/3A TR3 speedometer and wheel revs per mile Triumph 6
