TR2/3/3A Vertical link
Snowkilts
I checked the runout on both my vertical links per John's method in another thread (https://www.britishcarforum.com/bcf/showthread.php?98354-Triumph-spindles). I have it chucked in a lathe rather than a drill press. Both read around 0.050 in.
One of them had bad threads so I'm scrapping it and bought a brand new one from Rimmer Brothers which arrived yesterday. It also has around .050 runout out of the box.
Here's what it looked like: https://drive.google.com/open?id=1N1y...FMxRjmM0YXS28s
Both old links turned easily before I took them out. The new link is noticeably more snug in the trunnion threads than either of the old ones. (Snug in a good way, not too tight.) Slop in the threads would allow the steering to compensate for runout in the link, but the new link doesn't have any slop.
I'm reluctant to start pounding on a brand new link with the 20-ton hydraulic press that Santa is bringing me this year. I'll definitely try it out on the scrap one first, but what do you guys think?
CJD
I think you are great with both. .050” is very close. If they were bent they would be much farther off than you are getting. I only worked mine closer because they were so far off to begin with, and I can often over-do it and spend time way past the point of reason!?! But I would have no worries using yours as they are.
TomMull
I don't know what the tolerances are but you might check the camber when all together. If that's within spec, and I have no doubt it will be, you're good to go, at least IMO. And thanks to John for publishing the procedure.
It would also seem that getting anything to turn true by less than a few thousands a foot away from the chuck on either the lathe or the drill press will take better chucks than mine.
Tom
S
Snowkilts
Tom
Yea, I've been shimming my chuck to try and get it to turn true. Got it down to .003" at about 6 inches out using the 5/8 reamer I bought for the trunnion bushings, which I assume is fairly straight.
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
banjojambo Triumph tr3 vertical link wobble Triumph 2
V TR2/3/3A Vertical link check Triumph 2
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
J TR2/3/3A Need a TR3 vertical link Triumph 1
T TR2/3/3A TR3B vertical link Triumph 13
T Help on ball joint - vertical link fit Triumph 20
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
T Vertical link questions Triumph 4
Bremer Help with vertical link assessment Triumph 6
B Vertical link question Triumph 1
M Removing Stub Axle from Vertical link Triumph 22
G trunion/vertical link seal Triumph 5
S TR2/3/3A vertical links Triumph 8
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
C Distributor shaft vertical play? Triumph 4
tinman58 Vertical Links Triumph 5
HEALEYJAG 100 vertical fin from apron panel set Austin Healey 8
GB1 Vertical Oil Cooler Lines Racing 6
svtmikey Front Vertical links Triumph 3
WALTER Vertical vs. Cross-flow radiator Spridgets 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
D MGB Rear Suspension Damper Link Arm MG 2
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
N Watts Link??? Spridgets 2
H broken sway bar link - again Austin Healey 8
T TR2/3/3A tr3a verticle link removel question Triumph 11
G BJ-7 Rear Shock Link Austin Healey 2
B Support bracket for the rear suspension damper link Austin Healey 5
D TR4/4A stubborn lever shock link Triumph 2
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
N Top link offset bushings?? Spridgets 6
T TR5/TR250 250 Sway Bar Link Triumph 0
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
DornTRoriginal TR2/3/3A Horizontal Link Assembly Install Question Triumph 1
D TR2/3/3A Vent lid link length Triumph 8
J TR4/4A 67 IRS Damper arm/link removal help Triumph 10
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
S TR4/4A Reversing upper fulcrum link Triumph 3
B Parts for sale on Panjo link Austin Healey 0
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
K Jaguar 140 Restoration Link? Jaguar 2
