TR2/3/3A Starting my TR3 A restoration
JeffW
I picked up my TR3 A a couple of summers ago and I'm finally getting started on the restoration. I hope to be able to chronicle the build with lots of pictures.This is actually my first restoration but in the past I built a Factory Five 427 Cobra and a Daytona Coupe. I'm looking forward to the learning curve.
STeve 1958
The battery look good !
Actually that is about the shape my first TR3A was in when I bought it. This looks like a solid car. Hope there is not too much rust.
Good luck.
DavidApp
Hello Jeff
At least you are starting with the car all together so you can document all the parts as you do the work. I see you have a few extra parts as well.
Does it run and drive at the moment?
Good luck.
Keep us posted.
David
J
JeffW
David, it ran and drove when I got it. I will be rebuilding the engine also. Here are some picks as of last night. Most of the cage nuts were frozen so I had to cut them off which made for slow going.
M_Pied_Lourd
Looks like a great starting point Jeff. Good luck with the project. Please post regular updates. We’d all like to follow along.
Cheers
Tush
sp53
I would suggest if possible using WD40 and some heat form a small bottle on some of those caged nuts along with some vise grips to hold the cage tight, but sometimes they are fused together. keep posting it is better than TV!
steve
Crankshaft
Better than TV isn't too difficult. Sometimes I go to the barbershop and watch them give haircuts.
That's also better than TV.:welcoming:
sp53
<br>
I would suggest if possible using WD40 and some heat form a small bottle on some of those caged nuts along with some vise grips to hold the cage tight, but sometimes they are fused together. keep posting it is better than TV!<br>
steve
S TR2/3/3A TR3 Hard Starting Triumph 4
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
J TR2/3/3A TR3 needs starting fluid to start? Triumph 10
T TR2/3/3A TR3 starting with hand crank? Triumph 26
Tinkerman TR2/3/3A TR3 Tranny, Starting on it! Triumph 6
D TR2/3/3A TR3 Project Starting Triumph 5
txtr3 TR2/3/3A TR3 hard starting, but has been running ok Triumph 11
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
