MGB Gearbox Selector Shaft Tensioning
Simmo
There are three screws just behind the bell housing which bear on a spring and ball to put tension on the operating Rods.
Does anyone know how to manover the gearbox into a position in order to remove these bolts so that I can increase the tension on these springs with the introduction of a spacer.
At least one anyway, so as to hopefully stop the jumping out of top gear.
Any suggestions gratefully accepted
Joe Schlosser
I am guessing that increasing the tension on the detent springs will not correct the problem. Your issue is most likely a worn 4th gear syncro.
dklawson
Agreed. If not wear in the synchro it could be wear in the selector fork or the syncro hub.
B Problem with BJ7 gearbox selector Austin Healey 17
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Editor_Reid General MG Gearbox Identification MG 2
Editor_Reid Gearbox Identification Austin Healey 12
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
V TR2/3/3A I have a doubt about the gearbox Triumph 10
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
R Gearbox and Overdrive Oil Level Austin Healey 18
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
