General TR Ethanol free gas
laneriddle
Just noticed a gas station near me that is selling ethanol free gas. Is that something I should use in my Tr6?
they may only have regular grade. I don’t know what octane it is. I currently use premium pump gas with ethanol.
NutmegCT
I am really looking forward to reading replies on this. Some folks feel any ethanol at all will wreck the car forever. Others, no problem with it. And there seems to be evidence for both sides.
Let the fracas begin!
Tom M.
CJD
If you can buy non-ethanol fuel, use it! Not only is ethanol hard on rubber parts, but it reduces your gas mileage.
M_Pied_Lourd
Yeah, I try and use ethanol free when I can...I’ll drive a little out of my way to do so if required.
Cheers
Tush
TR3driver
Great Pumpkin - R.I.P
If you're already running corn with no problems, might as well go on with it. All of the ethanol-sensitive components have already been replaced with ones that (presumably) are not ethanol-sensitive.
You will burn a bit more "oxygenated" fuel, but usually the price difference at the pump is enough to more than make up for the difference.
"Oxygenated" has been the law around here for over 20 years. Hasn't "wrecked" any of my cars, but I did have some fuel pump diaphragms that turned to goo. No trouble with replacements, though.
TomMull
All things being equal, I'd choose the non-ethanol fuel but all things are not equal, one being the price. It is also very difficult to find here in the Northeast and that makes running it exclusively very difficult. I've run regular gasoline with ethanol for quite some time in several old cars without any known issues and will continue to do so unless something changes.
Tom
ed_h
I'm not convinced that gasohol will do any damage to the car, but i wonder about tuning. Switching a non-ECU engine to a fuel with oxygen added (in the form of alcohol) should make it run leaner. Whether it's enough to matter, I don't know.
Ed
poolboy
My engine seems to prefer 89 octane 10% ethanol over 87octane ethanol free.
Do you think the engine's compression ratio needs to taken into account more so than the presence of ethanol or not ?
2long
I resurrected a sleeping Doretti and have used only non-ethanol gas since getting the engine going again. It may be silly (and it is definitely way more expensive), but my uneducated view is that the ethanol has some detergents or something that could loosen particles/flakes in the fuel system and muck things up. My TR2 runs fine on regular ethanol.
Dan
TR3driver
Ed
Until the next time you adjust the carbs. Unlike most carbs, the mixture adjustment changes the entire range, not just idle.
Years ago, I ran my TR3A on straight denatured alcohol (just as a test). Had to pull the jets down quite a bit (didn't bother trying to set the nuts since it was only a short term test); but it ran fine. Probably down on power, but I couldn't tell the difference by the seat of my pants.
charlie74
I found pure gas recently at a local station. 91 octane I believe and now I have run two tanks through my car so there shouldn’t be any more mixture left. It seemed to run better to me (butt dyno only mind you) but at least now that the car is parked for the winter I don’t have to worry about separation and water getting taken up...
tomshobby
Here in Wisconsin we have a chain of stores called Kwik Trip. They have premium gas that is ethanol free. We kept a log of gas stats each time we filled up for about 2 years. It turned out the non ethanol gave better mileage, ran cooler, and better performance. It also caused a comment from PB about how clean the carbs were inside. They have stores all over the State so finding them all over the State (3 of them within 4 miles of our home) so finding them is not a problem. The log was just a habit and told a convincing story. But your car might tell a different story so I recommend keeping a log for your car.
CJD
The only reason to run corn alcohol in fuel is to reduce emissions. There are no other reasons to do so. In fact, the non-alcohol gas in Texas that I have found is cheaper than the alcy gas. So pay more for worse mileage. That's a no-brainer for me, unless you think your little Triumph runs enough to affect global warming. I know mine does not.
ed_h
In some states, the gasohol is subsidized, so it is cheaper than straight gasoline. This of course makes it the popular choice, as intended.
Ed
Alfred E. Neuman
From a petrochemical input perspective, I'm pretty sure it's actually less efficient to grow and harvest the corn and then brew and distill it into ethanol than it is to just burn the fossil fuels in the engine. Corn ethanol is a subsidy for farmers, not any real effort at reducing reliance on fossil fuels or reduce GHG emissions.
pdplot
E10 is about all you can get around here. I've been using it for years with no ill effects. Back in the day, we sought out "lead-free Amoco". Who knew that our valve seats needed lead?
NutmegCT
Paul - here's a 1960s memory for you. Note the take-off on "The Bridge over the River Kwai" (Colonel Bogey) theme.
HAWAIICJ
Here in Virginia, Liberty gas stations are the only ones that carry ethanol free fuel. It is only one grade and I think it is 87.
When I woke my TR it was with Sunoco 94 that does have 10% ethanol. The parts that will degrade are the steel fuel tank and tubing, my last fuel tank rusted badly inside and the baffles collapsed from corrosion.
poolboy
Us, too,..for our Coleman Stoves and Lanterns
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
tahoe healey 15 percent ethanol Austin Healey 23
Lin Didn't realize ethanol had been available commercially for so long! Austin Healey 4
S No ethanol fuel or not Triumph 21
tahoe healey ethanol in gas Austin Healey 11
PeterK The Ethanol dilemma Triumph 28
AUSMHLY Ethanol in Petrol Austin Healey 3
S Legal issues regarding Ethanol Restoration & Tools 4
19_again ethanol MG 10
T Ethanol fuel & engine problems Triumph 21
F Ethanol Triumph 78
Nunyas MMMMMMmm... "Bio Ethanol" Lotus Lotus 3
Aldwyn Ethanol/Gasohol for Triumps? *DELETED* Triumph 7
G ethanol gasoline Spridgets 2
Baz Ethanol in fuel Spridgets 18
L Gasoline with 10% ethanol Triumph 18
tomshobby ethanol research Restoration & Tools 12
V How do you run on Ethanol Triumph 6
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
jfarris For Sale FREE 83mm flex hone - item claimed Triumph Classifieds 1
M T-Series TD/TF Steering Free Play Question MG 6
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
BritFullHouse For Sale 56 MGA engine parts for free!! MG Classifieds 2
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
TomMull Free Triumph Herald Headboard Triumph Classifieds 0
JimLaney For Sale 2 MK IIIs :Free to good Home Spridgets Classified 1
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
69MGC MGB MGB Driver Magazines FREE MG 4
Tybalt TR6 Free TR6? Triumph 3
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
Jim_Gruber Free Spridget Windscreen available - Dayton OH Spridgets 3
Rut TR4/4A Rust free TRs Triumph 4
bugedd Free header Spridgets 0
G For Sale Free - 4 Vega GT Wheels Spridgets Classified 0
Jim_Stevens For Sale TR3 Free frame Triumph Classifieds 0
Joe Reed General MG MG Driver back issues....FREE! Anyone want them? MG 4
AngliaGT MGB Two FREE MG B's - Hoopa,CA MG 4
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
CJD TR2/3/3A Free Frame Triumph 4
GTP1960 TR2/3/3A Free new parts: Triumph 10
T GT6 Opinions on what a rust free GT6 is worth Triumph 22
CJD TR2/3/3A Free Parts Triumph 41
