New [to me] Compressor - Water & Auto Drains
dklawson
I moved my old compressor last week. Its Harbor Freight auto drain had plugged leaving a couple of cups of water inside. Along with the water were a LOT of decent size chunks of rust. As the tank is 40+ years old I decided it was time to retire it. New tanks cost about 1/2 to 2/3 the cost of a new compressor. New cast iron pump compressors with the CFM I want are north of $500 so I found and purchased a good used one locally.
The "new" compressor looks showroom new and clearly hasn't been used much. However, I heard water inside and decided to carry out maintenance before using it. I opened the drain **** and all it did was slowly drip. I dropped the tank pressure to about 10 PSI and slowly unscrewed the petcock. Even with the petcock removed all the tank did was drip. I grew impatient and probed the port with a bent coat hanger. Then all heck broke loose. I disloged whatever had plugged the port and about a quart of muddy water geysered out against the floor splattering me and most everything close in the garage. That will teach me to be impatient. I should have at least taken the thing out to the driveway. Now that I have cleaned the tank, the garage floor, and me up, it is time to move on to different plumbing and a better auto drain.
I want a better auto drain than the Harbor Freight one... one less likely to plug (which is what I found wrong with the HF one). The electric timer based ones don't make sense for a home shop (adjustable drain time 1-10 seconds every 1 to 45 minutes). They can also be expensive (Chinese from about $25 to name brand U.S. for upwards of $160).
Now that you know the background it's time to finally ask my question.
I am considering buying a programmable timer and solenoid valve to make my own more flexible auto drain. Before I start that project, do any of you use auto drains and if you do, are you pleased, how is yours adjusted, and how much did you pay for it?
JPSmit
I feel like the "clearly hasn't been used much" might be the key - I am just in the habit of draining mine every time or two and have never had an accumulation problem. Can't really add to the solenoid timer bit except to say that my solution is free :grin: and works just fine. :cheers:
dklawson
dklawson
For the time being I have made up an 18" long, 3/8" diameter drain hose. It has an elbow fitting that screws into the bottom of the tank and a ball valve on the other end. That will make it easier to access and less likely to plug than the petcock. I'll use that until I decide to buy or make an auto drain.
JPSmit
I suspect that might be all you need. will the hose take 100+ lbs of pressure?
dklawson
dklawson
Yep. The hose I have can take 100 PSI.
However, I have also ordered a 2 foot piece of 6AN braided hose. I will install that in my homemade drain hose once it arrives. The braided hose is listed for something close to 1000 PSI.
TR3driver
Great Pumpkin - R.I.P
I picked up a used IR automatic drain (the kind triggered by the compressor cycling) on flea-bay for not much more than the HF one. But never have gotten around to plumbing it up; the manual ball valve works well enough. I brought the tank drain out with galvanized pipe and put the ball valve where I can open and close it with my toe. The pipe also provides a sump of sorts, so the first cupful or so of accumulated water sits in it rather than in the tank. If rust becomes an issue, it's a lot cheaper to replace than the tank. And absolute worst case, if it does corrode enough to burst (my compressor runs to about 180 psi), it's a lot less dangerous than the main tank, too.
The strange part is that this compressor setup (80 gallon vertical tank, mounted outdoors) seems to generate a lot less water than my old 20 gallon horizontal did sitting under the bench in the garage. I really have no explanation for that, unless somehow the water is accumulating in the crossover tube between compressor cylinders (new setup is 2 stage, old setup was 2 cylinder single stage) and getting blown out when the switch cycles.
dklawson
dklawson
Interesting. I considered getting a new vertical to replace the 20 gallon horizontal I had for the past 25 years. However, I really don't have a good place to put that in the garage. Also, the verticals in my budget seemed to have diaphragm pumps. After my last compressor I really want to stay with a cast iron piston unit.
Last night I purchased a used, ASCO (brand) high-pressure valve off eBay. I will eventually pair that with a digital timer from HF. As purchased the HF timer only provides on/off cycles in minutes, not seconds. I have used this timer before on a pet feeder. There are two solder pads inside that can be bridged to change the output timebase to seconds. My plan is to pair the modified timer with the ASCO valve for a homemade auto drain. I will set it to dump for 4 or 5 seconds sometime in the middle of the night.
Eventually I will make my own auto-drain with those two components. However, I will continue to use the manual hose and ball valve until I get around to the auto drain project.
LarryK
I bought an Industrial Air upright 60 gal, 2.7hp from Rural King for $399. Cheaper by $40 from Ward Tools and cheaper than Harbor Freight. Got the extended warranty and found a service center that comes to the shop for repairs and warranty. Had it for 3 months, very happy with it. I had a Craftsman 30 Gal 5 hp horizontal for 25 yrs that developed a pinhole in tank, replacement for approx. same ( as they aren't made anymore or no parts) would have been $369+.
dklawson
dklawson
Your pinhole experience is similar to what I experienced with my old compressor. Both my old compressor and the one I just bought are 20 gallon horizontals with cast iron, 2 piston pumps (both Campbell-Hausfeld but the older labeled as Sears). I've had to replace the reed valves twice on the old pump but that's not too much to ask every 10 years or so. I feel I did very well with the new compressor in that I only paid $200 for it and it really is like brand new. The current, comparable model sells for about $425 when discounted.
This week I received the high pressure diaphragm valve and 6AN braided hose I purchased for my DIY auto drain. I'm pairing that with the HF digital timer modified to operate on/off times down to a second. I have manually tested these components and they work well together. After I run the drain line outside the garage I'll run some test cycles before putting it into service. Per advice I received, I have put an additional ball valve inline with the auto drain solenoid valve. That will allow me to shut everything down when I am not going to be around to keep an eye on things.
The only thing I don't like about the new compressor is that it has a big hysteresis loop with its on/off pressure limits. It's rated as a 135 PSI compressor/tank. It does pump up and stop at about 135. However, when you start using air, it doesn't come back on until about 95 PSI. I'm sure that will be OK but I'm used to my old compressor which pumped up to 150 and came back on when the pressure dropped to about 125.
TR3driver
Frequently (not always) there is an adjustment for that inside the housing for the pressure valve. Remove the cover and look for a "big" adjustment and a "small" one. The smaller one is usually the pressure differential between start and stop (hysteresis).
For example (random image from Google), in this case it's the nut on the right.
dklawson
dklawson
I will take a look at the pressure switch assembly again. I was in there hooking up a new cord when I changed the motor over to run on 240V. I probably looked right at the part to tweak and didn't recognize it.
dklawson
dklawson
I have spent some time trying to narrow the on/off hysteresis of the compressor. Suffice it to say it did not work as expected. I could change the on/off trip points but they moved together regardless of which spring was adjusted. (Fixed on/off window). Compounding that, the threaded shaft supporting the "left" spring started spinning with its adjusting nut. I gave up and got the settings back close enough to where they were so I could use the compressor.
I am ordering a different pressure switch with better defined adjustment screws. My hope is that the new pressure switch will let me set the on/off trip points to a more acceptable 110 to 135 PSI range.
I put together my homemade auto drain with its final components. It works well enough. A brass street elbow screws into the bottom of the tank. Barbed fittings on each end of a 2 foot piece of SS braided hose connect the elbow fitting to an Asco (brand) 120V fluid valve. A modified Harbor Freight digital timer cycles the valve on for 1 second at 2 a.m. daily. That's enough for a big burst of air to remove the moisture from the bottom of the tank. A homemade muffler on the end of the discharge hose keeps the noise down to a VERY acceptable level. Each one second blast drops the tank pressure by about 10 PSI so I added a ball valve to the circuit to disable the auto drain when I am not using the compressor.
Platinum
My "homebuilt" rig has a brass petcock for manual draining. The thing is an OLD one-lung piston compressor, belt-driven with a 240V well pump motor. What we did for space savings is made the storage tank(s) by using three older fire extinguisher tanks (think scuba tank size + 20%) on 3/4" iron pipe as a manifold, tanks inverted to drain any moisture into the manifold, with the drain petcock at the end. Slight angle toward the valve. Dryer and all controls; pressure switch, a separate line from "raw" output to an adjustable regulator at the "higher" end after the dryer. This compressor is three generations old, the tank arrangement built by dad and self back in the late '60's. Painted many cars, inflated many tires, used for about anything compressed air was needed for. Compressor and motor on a platform bolted to concrete floor with shock mounts, tanks and manifold bolted to the outside wall. All told it owns 14" of floor space, 4½' wide on the wall. Drain pipe is copper, routed to the outside through the CB wall. 30A D.P.S.T. light switch running from a separate 30A breaker in the panel, wall-mounted to turn it on and off. Industrial "Steampunk" air compressor!
dklawson
dklawson
I love the concept and implementation.
Though I have not kept any of these, we used to get small "scrap" diaphragm compressors out of the dumpster. They were used take-offs from medical equipment. I would outfit them with a cheap $12 pressure switch and a small fire extinguisher bottle for the receiver. They made great small compressors for tire inflation and air brush applications.
The timing of your post is great. Just today I finished customizing my new compressor. I replaced the factory pressure switch with one that is easier to adjust and replaced the factory pressure regulator with a much nicer filter-regulator from SMC. I now have an electromechanical manual drain, a regulator suitable for higher flow with filtration, and a pressure switch that operates in a narrower on/off band. I hope to just use the thing now and return my attention to reconditioning my old compressor so it can find a new home.
Platinum
:thumbsup:
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
B TR6 TR6 AC compressor bracket Triumph 15
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
TomMull Scroll Air Compressor Restoration & Tools 13
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
S TR2/3/3A Air compressor crud Triumph 7
wangdango air compressor? Restoration & Tools 8
Jim_Stevens Off Topic Saylor-Beall air compressor on ebay Triumph 3
G Portable 12V DC Air Compressor Austin Healey 6
TomMull Air compressor help needed Restoration & Tools 2
J How to sell a LARGE Compressor?? Restoration & Tools 8
KVH Air Compressor Restoration & Tools 2
TomMull Air Compressor Solution? Restoration & Tools 8
K TR6 Spring Compressor [Atlanta area??] Triumph 10
A TR6 Spring compressor Triumph 16
B Compressor plumbing and accessories Restoration & Tools 11
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
Got_All_4 Wedge TR7 AC compressor source? Triumph 21
F Who needs a Spring Compressor... Spridgets 12
ekamm TR2/3/3A Tr3 coil spring compressor Triumph 20
DNK Spring Compressor Triumph 9
H Coil Spring Compressor Triumph 10
M Air Compressor Noise Spridgets 16
M Sandblaster/air compressor Spridgets 22
T Air compressor min CFM for media blasting Triumph 14
Jim_Gruber Air Compressor Motor has crapped out-thoughts Spridgets 19
Mickey Richaud Strut/Spring Compressor Restoration & Tools 10
Lin air compressor Austin Healey 12
eejay56 Spitfire Spitfire spring compressor Triumph 11
ncbugeye Compressor requirement for MityVac bleeder Spridgets 3
I TR6 How do I use this? TR6 spring compressor help Triumph 15
J air compressor H2O problem Restoration & Tools 9
JPSmit RIDGID Compressor won't stop runing Restoration & Tools 6
Foghat73 MGB Spring compressor for MGB front suspension MG 45
K TR2/3/3A Need Pic & Dimensions of TR3 Spring Compressor Triumph 2
hilsideser any Kobalt compressor owner out there? Restoration & Tools 4
DNK Strut Compressor Triumph 16
CraigLandrum TR2/3/3A TR3 spring compressor Triumph 7
T Recommendation on coil spring compressor Triumph 6
S building front spring compressor Triumph 24
Tinkerman Air Compressor Help Triumph 22
L Compressor Question Restoration & Tools 3
Lin Electric power for compressor and car lift Austin Healey 6
angelfj1 Minimum Compressor Size for Automotive Use Restoration & Tools 6
jlaird Intresting compressor story Spridgets 6
jlaird Progress, air compressor Spridgets 7
bash Air compressor advice, please Restoration & Tools 18
M VALVE SPRING COMPRESSOR ? Restoration & Tools 5
