TR4/4A Why is the new voltage stabilizer I got marked with 'top"?
TuffTR250
I have a new TR4 voltage stabilizer from TRF and on the back it has an arrow with the word TOP beside it pointing in the opposite direction of the hole in the long mounting tab. Is there some reason it has to be installed with that arrow pointing up? Thanks!
dklawson
Orientation is important with the electromechanical voltage stabilizers.
Like the slow response Smiths gauges, the mechanism works by internal resistance heating of a bimetallic strip. If you mount the stabilizer "upside down" the effect of the resistance heating can be slightly different than when the unit was calibrated. This can result in slightly a slightly different output voltage than the desired "average" 10V.
The solid-state stabilizers sold by Moss are not subject to changes with mounting orientation and can be installed any way you desire.
T
TuffTR250
Thanks Doug! I made the assumption that the one I got from TRF was solid state, but since it is marked with the top it must be electromechanical. I was thinking the only thing made today is solid state. But I guess I was wrong.
TR3driver
Great Pumpkin - R.I.P
It would be interesting to find out. It may be that someone bought repro housings that were so marked, even though it makes no difference to the solid state regulator.
Also seems hard to believe that, given the lousy accuracy of these gauges anyway, that anyone worried about orientation affecting the readings. The heating coil is literally wound around the bimetallic strip and the case is sealed, so the difference would only be whether the weight of the strip pushed it closer to, or farther away from, closing the contacts.
CJD
But, that is the British way...over design the perfect system and then under-engineer it! American cars were the opposite...over engineer and under design. To the Brit designer that .001Volt was significant.
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR4/4A voltage stabilizer Triumph 2
S TR4/4A Voltage stabilizer and cable routings? Triumph 5
Mink TR4/4A Moss voltage stabilizer, part number 131-555 Triumph 15
M TR4/4A Voltage Stabilizer question. Triumph 10
M TR4/4A Voltage Stabilizer TR4A. Triumph 14
Bob Claffie Voltage stabilizer Triumph 10
B Gas Guage Not Working--Voltage Stabilizer? Spridgets 17
RJS Voltage Stabilizer [Mal]Function Triumph 3
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
Brosky Leaky voltage stabilizer Triumph 7
Raymond voltage stabilizer MG 15
L Voltage Stabilizer MG 20
middleagecrazy Voltage stabilizer Triumph 10
Got_All_4 Voltage stabilizer alternator upgrade problem Triumph 2
M Normal Temp and Voltage Stabilizer MG 9
Trevor Jessie Voltage stabilizer Spridgets 4
Mickey Richaud Voltage Stabilizer Question MG 14
Bruce Bowker voltage stabilizer British Motor Corp 6
Cain Fuel Gauge/Voltage Stabilizer Triumph 1
M voltage stabilizer Triumph 3
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Kurtis TR4/4A Voltage Control Module Triumph 15
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
S TR2/3/3A grounding the voltage regulator Triumph 14
S TR2/3/3A voltage regulators gap and oxidation Triumph 10
Jim_Gruber Voltage Regulator Question Spridgets 4
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
NutmegCT Voltage gauge Restoration & Tools 1
Bill_S TR4/4A Failing Voltage Stabilizers Triumph 1
S TR4/4A voltage regulator - digital Triumph 13
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
steveg Heater Blower voltage drop Austin Healey 8
M TR2/3/3A Voltage regulators Triumph 5
cmacmillan TR6 Losing voltage at + side of coil Triumph 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
Zimmycobra TR4/4A Question on Voltage Stablizer Triumph 6
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
Darrell_Walker High battery resting voltage - sign of imminent demise? Triumph 15
