TR2/3/3A Front coil spring recommendation?
Snowkilts
I'm going through the front suspension on my '60 TR3A and trying to decide what to do about the springs. They look fine, not broken or anything, no obvious problems. They were on the car when I got it in '96 and the PO did everything on the cheap, so it wouldn't surprise me if they are original. I'm inclined to replace them on general principles. What do you guys think? Should I replace with stock or get the longer ones and get rid of the spacer? I also see that Moss offers an "upgraded" spring made by Suplex, anybody try that? I'm not looking "performance" or higher rate springs, I think the stock ones are plenty firm. Thanks!
CJD
If you search the latest threads about problems with new springs I think you’ll be inclined to want to keep your current springs unless they are obviously bad.
TR3driver
Great Pumpkin - R.I.P
Amen! Why look for trouble if you don't have to?
Got_All_4
If it ain't broke don't fix it. If you decide to change them I have a weak one so I might be interested if they are good.
Sarastro
I'll join the chorus: don't replace them unless there is some reason to do so.
When I took apart my 4A's front suspension, I found that one spring was about 3/4" shorter than the other. That kind of thing warrants replacement, I think. Interestingly, the new ones looked very different from the old ones--they had thicker wire and 7 turns instead of 5. A little math showed me, however, that the new ones should have a spring constant virtually identical to the old ones. Most people are not geekoids like me, and if they had different constants, would not have known it until the job was finished and the car was too high or low. That's the kind of problem you can get into.
Alfred E. Neuman
The only springs I would buy new are from the higher end aftermarket suppliers like Richard Good or Neil Revington. The have the springs designed to a specific constant for a specific job, and they're QC is undoubtably better than the Big Three due to the nature of what they're selling them for.
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
KVH TR4/4A Front Coil Spring Spacers Triumph 1
PAUL161 General MG Front Coil Spring Comparison MGB verses a MG TF MG 4
G Choosing the correct front coil spring Spridgets 54
R TR4/4A TR4A Front Coil Spring Replacement Triumph 8
S front/rear coil spring diamaters. Triumph 4
K TR2/3/3A Front coil springs? Triumph 2
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A TR4 front coil springs Triumph 0
PAUL161 T-Series TF Front Coil Springs MG 1
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
PatGalvin Front Coil Springs Triumph 9
JamesWilson Front Coil Seat Dimensions? Triumph 0
PAUL161 Front coil springs MG 1
G Front Coil Springs Removal Spridgets 9
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
