Wiper motor '77
sparkydave
Hi all, it seems my wiper switch succumbed to the Prince of Darkness. Will have to see if Moss gets replacements back in, they are out at the moment. From my Googling I've figured out the low speed and high speed wires, but the diagram for the switch is very poor on how the parking wire figures in. I used a clip lead to energize the low and high speed wires and the wiper motor works with the switch unplugged. If I wanted to park them properly in the meantime, would I energize the parking wire, or jump that to the high or low, or ground it? I suppose I should measure it and see if there's voltage present on it with the switch unplugged; no voltage present might mean that energizing it will park the wipers.
Joe Schlosser
I am suprised no one has answered you.
I cannot help as I have the old single speed wipers.
However, inside the motor is a semi circular metal strip that keeps the current flowing after you kill the main power. Motor continues to run till the end of the strip which is the parked position.
sparkydave
sparkydave
Thanks Joe, I figured it out. The parking switch wire from the motor gets 12 volts on it when it's not parked. Jumping that to the low speed wire got them to park and stop. Now to find a replacement switch...
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
R TR2/3/3A TR3 Wiper motor Triumph 10
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
J TR2/3/3A Wiper Motor bracket Triumph 5
T TR5/TR250 TR250 wiper switch and motor Triumph 1
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
J TR2/3/3A Wiper motor wiring Triumph 4
D TR5/TR250 Windshield wiper motor Triumph 9
J TR2/3/3A Wiper Motor Gear Triumph 11
S TR2/3/3A Wiper Motor Troubleshooting Triumph 6
R grease for windshield wiper motor- BJ7 Austin Healey 4
steveg Wiper motor install error - warning Austin Healey 9
P WANTED: Bugeye Wiper Motor Spridgets 0
S TR2/3/3A Wiper Motor Parking Question Triumph 8
P Bugeye Windshield Wiper Motor Spridgets 3
Jim_Stevens TR2/3/3A Wiper motor mount Triumph 4
maxwedge5281 TR6 tr6 wiper motor wiring Triumph 15
maxwedge5281 wiper motor upgrade to two speed Austin Healey 16
Scotsman TR4/4A TR4A wiper motor rebuild Triumph 8
Scotsman TR4/4A TR4A wiper motor questions Triumph 2
K TR2/3/3A Wiper motor testing? Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
rjc157 wiper motor Austin Healey 0
Rob Glasgow Wiper motor rubber mounts Austin Healey 5
J Wiper motor 100 degree sweep gear ??? Restoration & Tools 7
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
rjc157 wiper motor Austin Healey 6
D Wiper motor mounting Spridgets 0
T TR2/3/3A wiper motor parking Triumph 7
alanjohnturner TR4/4A Rebuildiing a wiper motor Triumph 8
G TR4/4A wiper motor Triumph 7
