Correct side screen nut for early 58 BN4
Kainopong
Going to restore some sidescreens for my Feb 58 100-6 and I am stumped by which is the correct side screen configuration.
Derek’s Healey site on page 3 of Longbridge features indicates the Abington side screen change was made after car 47703.
Moment and Anderson’s book says that my car should have the single ear nut and star nut.
Which is correct and if I need that star nut, where is the best place to find two? I assume it’s 16tpi as well?
thanks in advance for the help!
DerekJ
You don’t mention the number of your car but given the manufacture date then it should have the early screens, the star shaped nut and also the single eared nut for the the other fitting. The first series 100-Six’s were manufactured at both Longbridge, until late 1957 and then at Abingdon until April 1958.
K
Kainopong
thanks!
It’s BN4LO56828.
i assume the star nut was 16tpi like the single ear? So I should try to find the Longbridge brackets as well that attach to the side Screen?
thanks,
john
DerekJ
Apologies for my previous post. It’s been a long time since I was researching the sidescreens. Whilst most of the ‘Longbridge’ features carried through to the first quarter 1958 production at Abingdon, the sidescreens did change in late 1957 so your car should have the Abingdon screens. My first car was 56053 and had them. You car is very close in numbers to the ones that had Morris Green engines but I think yours was produced just after that finished.
Sorry for the confusion.
K
Kainopong
Hi Derek -No worry. My car does have the Morris Green paint as well. So the sidescreen nut at the front is the two eared wing type or star nut? On page 99 of the Moment/Anderson book they write that the third style of frame was introduced after car 47704 but "...The star shaped nut at the front and the wing nut (single ear) at the rear were not changed". So whatever your car had mine should have too and maybe the book is incorrect? Thanks.
John
DerekJ
John,
Yes, I believe that is correct. My car also had the single ear and star shaped nuts. Your car has the latest number I know
of those with Morris Green engines.
K
Kainopong
Very interesting indeed. The build date was Feb 3-5, 1958 so the "mistake" in the painting must have been caught shortly after with the engine. My mechanic pulled the oil pan and the original bearings were in there and he confirmed the engine was not rebuilt. Once I get the car back I can send you a pic. Thanks for your help! J
John Turney
This is the nut you're looking for:
The thread is 5/16 - 24 (UNF).
healeyblue
I have made those and need to get them chromed. I hope to soon. Let me know how many are needed. I will sell them for 75.00 a pair or 40.00 a piece.
I also would like two. Let me know when you’re ready and we’ll go from there. Thanks!
healeyblue
I will not get to the chrome shop for a few weeks so bear with me. I do have a hand full already made so that will speed things up. I can sell them un chromed for 50.00 a pair if you have a local source of your own. PM me if interested to purchase now before I send the batch out next week or the week after. I do have some stock left to make a few more pairs if I run out.
Jim
BN6_2197 Correct alignment of BN6 side screens Austin Healey 11
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
