Lighting Switch Question
Bill Young
Reference the 3 position lighting switch on the Sprite Mk II. It looks to have a resistor connected between terminal "1" and "2" for the purpose of dimming the turn indicator lamp connected to terminal "P' on the flasher when the switch is on. The connection drawing shows that this resistor is bypassed in the "off" position, allowing the turn indicator lamp to be full brilliance. My question is .. does this switch also bypass the resistor in the "side" position (parking lamps) or only in the "headlights" position?
B
Bill Young
This "turn indicator" lamp dimming feature must not be very effective since no one has responded yet on how it works. The design appears to dim the lamp at night when the headlights are on. I ask if it also dims the lamp when only the parking (side) lamps are on. Thanks
B
Bill Young
As I am preparing electrical diagrams in "ladder logic" format for the various Healey models for publication in the Healey Marque, I am try to be sure I don't have too many errors... For the Sprite Mk II & III, I am going to assume that the lighting switch dims the turn indicator lamp in the "headlight" position only. I have attached the diagram for comment. Cheers.
SaxMan
I have a Sprite IV. It appears they did away with the dimmable turn signal feature, as my turn signal indicators stay at full bright, whether the headlights are on or off. So, it appears even BMC realized this was really an unnecessary feature. Rigging it up to sit works might be more trouble than it's worth.
On my IV, I did the LED lighting upgrade, both internally and externally. I figure the lower power draw with LEDs is one less "rock in the rowboat" for the generator to deal with. The brighter likes actually make the gauges legible at night, and the brighter external lights are definitely a safety improvement.
nomad
I have a Mk3 Sprite and a Mk2 Midget and am not aware of a resistor in this location. Don't have a Bentley at hand right now but will check for a resistor that I may have overlooked. The only dimming feature that would make sense would be for the indicators on the dash.
Kurt
KVH TR4/4A Lighting Switch Triumph 3
BN6_2197 Details on Lighting Switch Austin Healey 5
F TR6 Tachometer lighting Triumph 8
D Shop lighting suggestions. Restoration & Tools 8
Dnickels Spitfire Spitfire lighting issues Triumph 4
T Decreasing Intensity of LED Lighting Austin Healey 3
M Lighting issue Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
steveg Improved Instrument Lighting Austin Healey 2
C TR4/4A left brake lamp not lighting TR4A Triumph 4
B Instrumentation Lighting Austin Healey 12
RAC68 Dash Lighting [cost and access of incandescent Bulbs] Austin Healey 37
DerekJ Lighting circuit - the smoke's escaped from the wires.! Austin Healey 12
C TR4/4A Interesting Lucas lighting issue??? Triumph 5
U Spitfire Lighting issues on 1980 Spitfire Triumph 2
Boggsy64 MGB Dash lighting question MG 4
I TR6 TR6 lighting questions Triumph 4
L BJ8 additional interior lighting Austin Healey 7
B dash lighting options Triumph 5
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
memphis Rear License Plate Lighting Austin Healey 2
I Bugeye lighting/electrical help Spridgets 17
I lighting problem help Spridgets 14
L Lighting/Ignition issue MG 6
T MGB MGB Instrument Lighting MG 7
TimK Gauge lighting Austin Healey 7
Moseso TR2/3/3A TR3 Brake/Turn Lighting Improvement Discussion Triumph 12
K Gauge lighting Austin Healey 14
Atrus Additional Lighting [headlights] Spridgets 24
newmexTR3 lighting relay question Triumph 2
ModifiedBJ7 Rear License Plate & Lighting Austin Healey 3
angelfj1 TR2/3/3A TR-3A exterior lighting - best source Triumph 4
kyreb1862 MGB Hot Lighting Harness 77 MGB MG 4
D xjs heater conrol lighting Jaguar 2
delisaj Dashboard lighting Triumph 16
drooartz Pictures, and lighting questions Spridgets 1
K Dash lighting Austin Healey 2
P Lighting issue on my "under restoration BT7" Austin Healey 8
A interior lighting-guages Austin Healey 8
I TR2/3/3A TR3A - Forward Lighting Triumph 6
R6MGS Lighting Jaguar 0
S Interior lighting Austin Healey 1
Joe Reed Garage lighting? Restoration & Tools 36
R Bugeye ignition switch Spridgets 2
K TR2/3/3A Old school battery shut off switch....... Triumph 3
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
F Wanted Dipping switch cap Triumph Classifieds 1
L What does this column switch do? Spridgets 4
G Brake Light Switch Failure Austin Healey 24
