Lift for Healeys
Bob_Spidell
Folks,
I need to get a lift in order to get under the various vehicles I now have to maintain for myself and my mother (and bury the not-to-code and ridiculously dangerous grease pit my dad installed many years ago). In watching all the various car shows, it seems the two-post variety is the most popular, but the drive-on four-post might be the most convenient (except when you need to remove the wheels, obviously, or raise one of the tractors). So, I'm leaning toward the 2-post--any and all suggestions on brand (American-made preferred) and size accepted--but I'm concerned about supporting a Big Healey at four points on their famously flimsy chassis rails. What are you all using? Any issues lifting a Healey by the chassis (assuming it's not fully swiss-cheesed)?
EDIT: So, in perusing the 'net for available lifts, it occurred to me that a 2-post may not work with a Healey's exhaust hanging so low; is it possible to get a 2-post's arms under the exhaust on the left-hand side?
Thanks,
nevets
I do not own a lift yet, however when I researched lifts a while back, I considered a 4-post a better choice for my needs, which included vehicle storage, one above the other. Not sure about the 2-post lifts, but the 4-post lift did not require anchoring to the garage floor, plus there are accessories such as drip pans and hydraulic jacks for raising the vehicle off the wheels. The brand I was considering was Backyard Buddy.
Bob_Spidell
Bob_Spidell
Backyard Buddy looks good--Made in the USA--but their website curiously emphasizes their use for car storage; is there something limiting WRT to getting under the car and doing work?
dougie
I installed a two-post Atlas unit in the shop/garage I built about 5 years ago. Very happy with it, I went with this brand because they have a warehouse locally and I could save the frieght and just w/c it. Installed very easy and has all the spacers to clear the Healey exhaust. I use it primarily for the maintenance of my vintage racer and not car storage. I needed to be able to service the wheels, brake, suspension, etc directly and didn't think a four post would allow this, plus a four post would have taken up too much space for me.
https://www.gregsmithequipment.com/Atlas-9KBP-Baseplate-9-000-lbs.-Capacity-2-Post-Lift
Scot
Bob,
Very timely thread for me! I have been looking at the MaxJax two post portable lift. www.maxjaxusa.com This one can be removed and installed again so you can have some space back!
It will fit in my spacious but low ceiling shop and accommodate my three sports cars, the BJ8 being one of them. There are a few electrical and concrete requirements but you can download the installation manual from their site to see if it works for you. I plan on ordering one in the near future. Not sure where on the Healey those lift pads go but I know others with Healeys are using this setup! Cheers!
vette
Bob, I am sold on a 2-post. I really don't think the cost is prohibitive. I bought a 10k lb. Danmar Lift. It is a clone to a Benpax which is very popular around here in many commercial garages. The Danmar was a little cheaper. When i bought it it was about $2400.
Two points I would like to make, well maybe 3, I bought a "clear floor" type meaning the connecting cable and bar is at the top. This leaves the floor clear, for 2 reasons to me. One is if you ever have to push a dead car into the lift bay you do not have to push it over the floor plate. Another reason is that if you are moving an oil catch tank under the car, or a transmission jack you do not have floor obstruction from the floor plate. This is very important if you think about it. A floor plate can be very annoying if not ridiculously in the wrong place at the wrong time. Another point is that I bought one that has rubber pads at the ends of the arms. Don't buy one with the metal flip up brackets as with low cars they may be impossible to deploy. My arms have a max low height of 4 1/2". I think that is as low as you will get them. They will go under the Healey with no trouble but because of the muffler depending how where you position the car, I have to use pad extenders to make sure the arm clears the muffler. You can see that situation in my picture. One manufacturer offers a pad that screws into and out of the arm for height adjustment. I almost bought that but I was concerned about its strength considering that I also lift heavier vehicles as well, such as a Land Rover, Ford Expedition, etc. But it may not be a concern, that is a personal decision. From my research I remember that to have these things certified by one of the "Authorities" and I forget which authorities they are, but they have to pass a test where they lift and hold for a certain period of time the amount of 1 1/2 times their rated capacity. One last point, in all the research I did before I bought one, I never realized that a "standard width" lift is not wide enough. With Danmar and many of the others ( they do obviously give their width spec) they offer what is called an extra wide option. I found out after I installed the standard width that I cannot put some cars on it because it is not wide enough. The angle brace on the arm hits the body of some vehicles before the arm swings under far enough. I can just barely get my C5 Vette on it, and I can not get some newer Vettes on it that have the wider body features. But if I jack up both ends and then swing the arms under and block up the pads then I can do it. This keeps the bodies away from the arms braces. So don't buy a "Standard Width", get the "Extra Wide". See pic. By the way, I usually put the pads on the frame just behind the engine mounts and as far back as the rear wheel will allow. If that frame holds it while is is going down the road, it will hold it on the lift.
Healey Nut
I have a four poster drive on . I use it for storage and working on . You need minimum 9ft ceilings and if you have an up and over regular garage door with chain type pull opener then its not going to work .
In my old garage I had to have the tracks for the door modified to make the door open closer to the ceiling and go with a direct drive opener .
No such issues in my new shop as it has 13ft ceilings but I still went with direct drive opener to keep things cleaner looking . My hoist is 220 volt the 110 volt ones are way to slow to lift .
Make sure you have your power outlet installed in the ceiling to keep the power cord to the pump out of the way .
Look for a deal where they include a bridge jack and drip trays and if you go with drive on make sure you get aluminum ramps ...your back will thank you .
BTW my hoist isnt bolted to the floor , I put some rubber matting in between the steel plates and the concrete and it stops it “walking” as you raise n lower cars .
John Kuzman
I installed a BendPak 4 Post in my typical 2-1/2 car garage in FL. Here is the lift I bought. https://www.bendpak.com/car-lifts/four-post-lifts/hd-9st/
This is a narrow width lift to accommodate my narrower track Bugeye and Spitfire. The BJ7 fits with no problems.
I bought three of the drip trays and the jack bridges so I can do brake/tire work as well. Also bought the caster set for moving the lift. The casters work somewhat OK, but I only tried moving the lift with the Bugeye about two feet off the ground. No clue why the one picture is upside down!
Bob_Spidell
Bob_Spidell
Thanks for all the input, guys. Not surprisingly, the opinions were pretty much evenly split since both 2- and 4-post have advantages. I'm leaning towards a 4-post, since most of the work will be oil changes, bleeding brakes, etc. But, I think I'll spring for (at least) one of the scissor jacks for when I do need to do suspension work. Of course, I'll need an oil drain and some other toys/accessories.
Space isn't an issue; my dad built a large 'barn'--that's what it's shaped like, and what we call it--but it's really a large shop (a county bureaucrat realized it wasn't for agricultural use, and assessed extra fees accordingly). I think the ceilings are about 20', and it has 3 smaller and one large roll-up door. Here's a shot taken long ago, when we had a little party, with most of the local FD in attendance, to start the fire engine for the first time:
vette
Looks like a nice shop Bob.
Bob_Spidell
Bob_Spidell
It's a lot more cluttered now, unfortunately. When I moved, I stored a bunch of our stuff in there. Dad was a bit of a hoarder--we still have parts for Model As we sold decades ago--and I have to get rid of a couple old player pianos Dad wanted to restore. Since we're on a farm, everything gets a coat of dust on it. But I'm not complaining.
judow
Darth Vader - R.I.P
We have a 4 post lift from Gregg Equipment. It accommodates our modern car as well as the Healey and a ‘50 Didge truck.
It it does require a higher ceiling height. And it serves as a dinner table. :smile:
Bob, I'm a big fan for the 2-post type, because I am always working on the cars, mostly customer's M Coupes & Rdstrs, but I can occasionally squeeze in some work on one of my own cars (THAT is going to change pretty soon, as I wind down working for others...).
There are many advantages to using a lift, as you'll come to discover; raising the car a foot or two (12"-24") making any work in the engine compartment easier (I don't know if a 4-post offers the same benefit, since you're reaching from outside of the platform?); waxing the rocker panels while standing completely upright; I could go on...
On the left side, I use the body outriggers, but with a couple small blocks of wood so that I'm not lifting on the body-panel's flanges. On the RH side, the arms can reach farther inboard and the pads, while still under the outriggers, are adjacent to the maim frame rails.
This picture shows the Healey on my old "floorplate" lift (equalizing cables/hydraulic hose pass across floor) essentially the same as Dougie's, except mine is branded by Eagle (Chinese manufacture with American cylinders & pump unit).
Looks like in this shot, I was relying primarily on the sills (they're solid, I replaced inner/outer & rockers myself) while fitting an exhaust system.
Since you have the ceiling height, I highly recommend the 2-post with overhead cables/hose (typically 12' minimum ceiling reqd.).
Since moving to Florida, I put this Bend-Pak ( https://www.bendpak.com/car-lifts/two-post-lifts/xpr-10as/ ) which is likely one of the least expensive ALI Certified lifts on the market, at least it was 6-7 yrs ago when I was doing my research.
i.php
Another old picture taken in Ohio. For those of you with vertically challenged garages, note the tops of the columns poking slightly into the space between ceiling joists; these were eventually finished off with 1' x 3" trim frames. Note too the plastic drop-cloth so another car can be parked under The British One for the night without getting marked with oil drops!
Bob_Spidell
Bob_Spidell
Geez .... You guys were supposed to make it EASIER to pick a lift :wink-new: I was all but sold on 4-post but Randy, as usual, makes a good case for the 2-post. I guess I'll just have to keep pondering (of course, buying one of each would solve the problem, but it's a bit more dosh than I want to spend right now).
Deleted member 21878
I have a scissor lift that raises to 6’. It works very well and no posts in the middle of the garage. But if I had your room, I would go with the 2 post.
PHulst
Bronze
I've been using 4 post lifts for years, and work on several Corvettes on a regular basis.
I've used a jacking bridge and a 2-bag air bag jack when I need to work on wheels or suspension.
I also have an aluminum floor jack from Harbor Freight that I can easily lift up onto the Lift if I need to jack up a vehicle from the side.
You can work around the "down" sides of a 4 post, but you can't use a post for storage.
Healey Nut
I think the big decider is if you plan on using the lift for storage of cars .
Personally I would not store any car on a two post lift with all the suspension components hanging .
A four poster is perfect for storage and working on cars and as to Randys comment about leaning over into an engine bay . Make a small standing platform to put alongside the car to give you a little more height to lean over . Problem solved .
I also have a good quality office type chair on wheels so can happily scoot around under the car so Im not standing for long periods .
You cant do that as easy with that bridge plate hump on the floor that two posters have .
Jack T
An important consideration for a two post lift with a Healey is the reach of the arms. A full-size lift may not be able to reach far enough to get to the best lift points. Because of height limitatios i have a MaxJax and had to position the posts closer together for the Healey and Jag than for my daily drivers.
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
drooartz Bugeye fits on the lift! Spridgets 14
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
HighAltitudeTR3 Wanted TR3 Hood Lift Assembly Triumph Classifieds 2
I General TR Hydraulic lift opinions/info needed Triumph 34
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
NutmegCT TR2/3/3A SU-H "lift button" Triumph 12
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
R General Tech Car Lift Triumph 5
R Car Lift Austin Healey 10
Rut HF lift Spridgets 1
S TR2/3/3A Question on the lift dot fastener, Triumph 3
Rut TR4/4A Shop with lift ideas Triumph 21
T TR6 TR-6 Wheels Wobble & Lift Triumph 4
N TR6 Lift Question Triumph 4
GTP1960 TR2/3/3A Ranger Quickjack lift for TR3A Triumph 5
jfarris TR2/3/3A Problem with lift-the-dot fastener on door Triumph 4
Popeye TR4/4A TR4A rear engine lift point - photos? Triumph 14
F Any Experience with BendPak MD-6XP Scissor Lift? Austin Healey 8
T TR2/3/3A Lift the Dot question Triumph 4
CJD TR2/3/3A Stock Valve Lift Triumph 3
angelfj1 NORTHERN TOOL - Ranger QuickJack Portable Lift Restoration & Tools 3
J TR2/3/3A Hood lift to front apron, what size are the screws that go from bottom up? Triumph 10
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
60TR3A Looking for Recommendations for Garage Lift Austin Healey 9
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
T TR2/3/3A tr3a hood lift spring assembly Triumph 11
T TR2/3/3A Question on TR3A hood lift assembly Triumph 2
trrdster2000 Garage lift, which direction?? Triumph 40
stretchit2 New Lift/Hoist for my Hardtop Austin Healey 11
martx-5 Lift for the Garage Triumph 28
Lin 4-post lift hydraulic fluid Austin Healey 5
T building a single tower Sprite storage lift? Spridgets 21
mcguijo TR2/3/3A TR3 Hood Lift Assembly Triumph 1
M Tennax and Lift A Dot? Spridgets 2
GBRandy Wedge TR8 Headlamp lift motor repair Triumph 17
M Lift-the-dot peg Triumph 3
bighealeysource Anyone use a EZ Car Lift brand on your Healey ? Austin Healey 6
Tinkerman TR2/3/3A TR 3A Lift The Dot Studs Triumph 3
J New lift tool for my garden tractor Restoration & Tools 0
RAC68 Rear Spring Lift Austin Healey 9
DNK Lift THoughts Restoration & Tools 14
M Removing Lift-the-Dot Fasteners Triumph 8
SCguy TR6 Tr6/Scissor lift? Triumph 4
M Raising the car without a lift Triumph 14
luke44 TR2/3/3A TR3 Lift the Dot Studs - 2 styles? Triumph 4
bigjones Door panel face lift Spridgets 8
Johnny Tenax and "Lift-the-dot" fasteners, plus Austin Healey 4
