Strange Oil Leak
steveg
Since my engine rebuild, I've had a small oil leak adjacent to each spark plug. Couldn't figure them out because my rocker gasket wasn't leaking.
Turns out the outer rocker pedestal stud holes are tapped all the way through above the spark plugs. These studs require a thread sealant.
Thanks for posting this, Steve. I've had oil stains around a couple plugs on a freshly-rebuilt engine; I believe this solves the mystery (not worth pulling the rocker pedestals, though).
steveg
steveg
Bob - You don't have to pull the pedestals.
Double-nut and remove the studs; blow out threads with carb/brake cleaner and compressed air. Seal threads - I used Permatex Thread Sealant but pipe dope or hylomar would also work. Re-install and torque nuts to 300 lb. in. (25 lb ft). I did all 6 in around 1.5 hrs.
Healey Nut
If its not leaking then theres someting wrong . Healeys are like dogs they leave their mark everywhere they go .
Like my signature says “ its not an oil leak its a patent pending rustproofing system”
steveg
steveg
Yuk, yuk. Yeah, "if it's not leaking, you're out of fluids," etc. etc.
Healeys can be made to be quite leak-free with perseverance.
I'm thankful I didn't buy a 356 at the time: I'd have nothing to do as it's already perfect - the Healey is imperfect, yet endearing.
Lin
Steve,
Not that you need validation - you always carefully observe and analyze what ever the topic of your attention is - but below you will note in the Technical Tip included in the paperwork for my Dennis Welch aluminum head that the Welch team recommends doing exactly what you did. Sealing the threads on the studs above the plugs is advised to avoid oil leaks.
Lin
KLUTZ I have a strange oil leak.. MG 10
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
E TR6 Strange Steering Rack Cap Triumph 3
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
jlaird MGB Strange daily question. MG 10
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
Musicman Strange Clicky/Tappy Sound Triumph 6
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
J Strange electric problem. Jaguar 11
racingenglishcars This is a strange one! Spridgets 9
