side curtain felt placement in channel
maxwedge5281
refurbishing the side curtains for my 1959 bn6. i think i have done the hard part in replacing the outer rubber seal! i ordered new perplex pieces and new felt as well. ready to place the felt. the side curtains that i have do no have felt in place. and, it seems that healey spares only sent enough felt for one side.....how much of the channel for the inner sliding window is lined with the felt material? thanks for a quick answer as i am doing this job right now... well I just checked my invoice and it seems that even though I ordered for two side curtains that they only sent the felt for one side curtain!!!
steveg
Suggestions:
You may wind up putting the felt on bottom, front and rear channels. Mine came from Moss with the felt already installed. Had to remove the upper felt in the outer channel because the window kept popping out and didn't want to slide.
I found it helpful to trim the leading edge of the rubber to about 1/4" so it barely contacts the channel on the windshield post. Leaving it full width tortures it and contributes to early failure. The crack that seems to inevitably develop at the "point" can be filled with black weatherstrip adhesive.
I cut a piece of masonite the same overall shape as the sidecurtain - to insert in the bag to protect the plexiglas. This after I piled some stuff on top of the curtains in the boot - breaking one of the plex panels.
It's a good idea to take a rat-tail file and round off the sharp edges inside the "point" as they're good places for cracks in the rubber to start.
maxwedge5281
maxwedge5281
well I have the felt in place on one side and have ordered the felt for the other side. QUESTION ???? what type of adhesive is used to attach the small rectangular piece of perspex to the sliding Perspex panel??? thanks steve for the tips!
British_Recovery
Bronze
There is a solvent that actually welds the two parts together. Probably methylene chloride.
Good video on the Tap Plastics site: tapplastics.com
John Turney
Yes, Tap Plastics sells the solvent. You use a needle to apply a drop to the edge of the small rectangular piece and it is wicked into the gap.
BTW, when AH Spares sent my felt, they sent two pieces.
maxwedge5281 Side Curtain Felt Material Austin Healey 5
roscoe Side Curtain Hardware Austin Healey 2
W Need advice on installing new side curtain glass Spridgets 1
kodpkd Side Curtain Windows Austin Healey 11
C MGA Side curtain info MG 11
S Wanted Side Curtain Retainer for Swallow Doretti Other British Classifieds 0
PAUL161 T-Series TF Side curtain storage in compartment MG 3
H Side curtain seals Spridgets 0
aero3113 100-4 Side Curtain Sockets Austin Healey 2
D For Sale TR3A-B Side curtain set - white Triumph Classifieds 1
maxwedge5281 diy side curtain polishing Austin Healey 8
T Wind Wings for Side Curtain Spridgets Spridgets 21
K TR2/3/3A Side Curtain bracket Dzus screws. Triumph 2
B TR2/3/3A Side Curtain Frames Triumph 2
T TR2/3/3A Side curtain fit up Triumph 3
Kleykamp TR2/3/3A After market side curtain ??? Triumph 10
steveg Side Curtain Flange question Austin Healey 5
Kleykamp TR2/3/3A Two questions on side curtain installation??? Triumph 8
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
M Side Curtain Windshield Frame ? Spridgets 0
Rut Side curtain rubber seals Spridgets 5
toysrrus TR2/3/3A Re: Side Curtain Question Triumph 4
Marvin Gruber TR2/3/3A Need a pair of Wedge type side curtain mounts Triumph 3
I Bugeye side curtain bracket help Spridgets 2
3798j MGA Side Curtain Access MG 1
TRclassic3 Side curtain window Triumph 9
R TR2/3/3A TR3A Side Curtain adjustment Triumph 4
BobbyD TR2/3/3A TR3 Side Curtain Bags Triumph 4
K TR2/3/3A TR3 Cut Off Side Curtain. Triumph 18
Brinkerhoff TR 3 side curtain rebuilding Triumph 7
coj Removing side curtain protective paper Austin Healey 10
ekamm TR2/3/3A Tr3 Dzus style side curtain brackets Triumph 11
ekamm TR2/3/3A Tr3 Dzus style side curtain brackets Triumph 9
K Side curtain dzus screws and "Socket"? Triumph 4
Tinkerman Side Curtain Color Question Triumph 10
HerronScott TR2/3/3A TR3A side curtain costs? Triumph 10
V TR2/3/3A TR-3B Side Curtain Mounts Triumph 5
livinginthepast How to polish minor scratches out of side curtain? Spridgets 7
Lin Side Curtain Modifications to eliminate noise Austin Healey 25
M Side Curtain Rubber Has anyone tried MacGregor? Spridgets 2
G TR 3 Side curtain fitting Triumph 11
M BE Side Curtain Fitment Spridgets 31
M Bugeye Side Curtain Mystery Spridgets 4
George Zeck Side Curtain Re-Conditioning ??? Spridgets 14
bmurphy7369 TR2/3/3A TR3 Side Curtain Questions Triumph 5
L side curtain web site Triumph 3
T Side curtain information??? Triumph 1
M Side Curtain Rebuild ? Spridgets 1
B T-Series MG-TD SIDE CURTAIN FRAMES MG 1
N TR2/3/3A TR3A Side Curtain Rebuild Triumph 13
